Technical Suggestions on a HVLP turbine systems
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Jun 25, 2019.
  1. Dino 64
    Dino 64
    from Virginia
    Been looking online and was wondering if anyone has used one, and their opinion of them. Seems like the Fuji models are highly recommended and Apollo is making one for Eastwood.
    Thanks in advance
  2. hrm2k
    hrm2k
    I bought the one from TPI tools. Nice unit ……………….I have not used it yet
    Dino 64 likes this.
  3. Dino 64
    Dino 64
    from Virginia
    Thanks I looked at them too. Hope it works well for you
    hrm2k likes this.
  4. hrm2k
    hrm2k
    My first victim will be my 99 Miata...…………...next victim will be my 1917 roadster pick up...…...and all that learning will go to the paint on my V8 '65 Corvair. I know I will post my experience.
    Just Gary, belair, oj and 1 other person like this.
  5. Dino 64
    Dino 64
    from Virginia
    Please do post your results thanks
  6. oj
    oj
    I have a good idea, lets go help hrm2k! I'm sure he would welcome sage advice from us'ns, maybe we can round up Don too! that'd be epic!
    Just Gary, Dino 64 and hrm2k like this.
  7. hrm2k
    hrm2k
    Anytime you want oj. My door is always open for you !!!!
    Dino 64 likes this.
  8. Dino 64
    Dino 64
    from Virginia
    Sounds good to me
    Just Gary likes this.
  9. Blue One
    Blue One
    from Alberta
    Dino 64 and Just Gary like this.
  10. Dino 64
    Dino 64
    from Virginia
    Thanks that’s the one that gets the best reviews online. I thought the higher stage would be the best. Does it handle primers well ?
  11. Blue One
    Blue One
    from Alberta
    I sprayed epoxy primer and then polyester high build primer surface after that with no issues.
    For my color I sprayed acrylic urethane.
    Pictures of the spray booth I built and some paint pictures are on my build thread or on the painting at home in the garage or driveway thread.
    Just Gary and Dino 64 like this.
  12. goldmountain
    goldmountain
    It looks like the TP units are single stage . Anyone satisfied with the result? I bought a single stage Lemmer and haven't got to painting yet.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    Dino 64 likes this.
  13. Dino 64
    Dino 64
    from Virginia
    That’s great. What’s the link to your build ?
    Wanna check it out
    Thanks
  14. Dino 64
    Dino 64
    from Virginia
    Higher the stage the more air volume and pressure to push the heavier primer
  15. Blue One
    Blue One
    from Alberta
    I would not have had any luck with a single stage turbine the 3 worked well enough for primer but better atomization from the 5 stage meant smoother flow for the final coats of paint.
    https://www.jalopyjournal.com/forum/threads/26-t-roadster-pick-up-build-thread.460009/
  16. Dino 64
    Dino 64
    from Virginia
  17. Blue One
    Blue One
    from Alberta
  18. belair
    belair
    Sooo... $1720.00 Canadian -that's like $47.00 U.S.? :p Seriously, @Blue One -you got the stage 5 and it barely pushed the primer?
  19. Blue One
    Blue One
    from Alberta
    No, I started with a 3 stage and it worked reasonably well with the epoxy primer.
    But even being an inexperienced painter as in never having done it before it was obvious to me that I needed a little bit better atomization.
    The 5 stage turbine worked really well and allowed me to do a decent job considering my experience or lack of it.
    66DABC05-5DFE-4A1A-876C-D95ECC661A5F.jpeg A2FAE9F8-E38C-47A2-91A8-2F53888B8E0D.jpeg A63DDBAC-1845-482A-ACE4-9F393A9A6BC5.jpeg 8021D889-3E29-4E0B-9374-6AB47387BF10.jpeg
    belair, Just Gary and Dino 64 like this.
  20. Dino 64
    Dino 64
    from Virginia
    Great job
    Blue One likes this.
  21. belair
    belair
