Projects 47 sedan delivery
Discussion in 'The Hokey Ass Message Board' started by Reman, Mar 26, 2019.
  1. Reman
    Reman
    from Florida
    Question for all you GM guru's. We are looking at picking up a 1947 Chevy sedan delivery with a very bad, and rusty driver side quarter. Will a 46-48 2dr sedan quarter (lower section) fit this? If not an exact fit, can it be altered to fit? Thanks, Ron
  2. mgtstumpy
    mgtstumpy
    EMS make rust panels for coupe, tudor and Fleetline aero bodystyles however they'd be too short for a SD, you'd need to splice a filler panel in to get the required length. Ask the EMS guy here on the HAMB to see what he can do for you.
    You may also need these inner patch panels
    Chevs of the 40s has this larger patch panel for 2 door models, you'd need to use the door panel and wheel arch pressings.
    Hnstray likes this.
  3. Reman
    Reman
    from Florida
    Thank you stumpy. I will check both those sites.
  4. ems customer service
    still waiting for your call
  5. Sporty45
    Sporty45
    Be aware if you order the 1/4 panel repair patch from EMS the door jamb radius edges are much more rounded than the original door jamb area and will need to be reworked to match the original.
