Fresh 271 flathead, 8ba rods used with 4" crank. This is a 59 factory relieved block. It has all the machine work done, including acid dipped. Very clean block to start with. Build includes rotating assembly, new valve seats, lifter bores drilled for adjustable lifters, new cam bearings installed, head studs removed. I would include an oil pan, front cover and stock bead blasted heads if desired. There is no cam or lifters installed, I left that for the next owner. This was bored .100, including 4 cylinder sleeves, acid dipping showed pits we didn't want to chase after. See the attached pics and ask any questions. I would work with you on delivery options, i'm willing to deliver within 100 miles of me. I would gladly wrap it up and deliver it to a Fastenal office for shipping, buyer arranges and pays.
