Technical Why do armrest screws angle up?
Discussion in 'The Hokey Ass Message Board' started by radarsonwheels, Jun 11, 2019.
  1. radarsonwheels
    radarsonwheels
    from Philly
    ABC73A8E-907D-4A1B-B1CE-98E8F67DA3B3.jpeg I have no door pulls or armrests on my ‘54 dodge pickup. I just finished making luaon cards that are getting covered in black diamond pleated marine vinyl and I’m also making armrests/door pulls. It’ll be nice to have someplace to set my elbow but even better to have someplace to grab the door. Despite a couple afternoons spent improving the door fit it still needs a gentle lift and a snappy pull in order to latch.
    I have the armrests mostly made. I just have to figure out the angle of the screws. I’m using the stock stamping in the door that has holes to use 1/4”-24 clip in nuts.
    All the armrests I’ve taken off old cars had screws that angle up. Anybody know why? It seems like that would help them stay tight against elbow weight pulling down but I anticipate more force pulling in and up?
    All I gotta do to finish these is figure out how to make the angled screw heads hit flush- maybe a drilled wedge of ironwood to match the pad? Or a metal solution welded in? Or a piece of tubing cut at angles and tigged on?
    My fine thread wide panhead screws should be coming from McMaster today and I have some time tomorrow to work on them- any suggestions are welcome!
    Here’s my sketches and what I got done so far. Changed a little. The ipe/ironwood matches my parking brake handle and bed wood. I’m going for a hotrod look but might be veering into ‘70s RV cup/map holder territory with the woodwork ED13C1A4-1CCC-4619-B8F2-4BADDF474CD1.jpeg 46EEFF2F-49A2-4AB7-B6A5-2F9330A0353C.jpeg
  2. squirrel
    Being angled up, makes it so you won't be as likely to see the unsightly screw heads.
    jimmy six and belair like this.
  3. Jokester
    Jokester
    Also less likely to drill a hole in your window glass.
    .bjb
    belair likes this.
  4. sliceddeuce
    sliceddeuce
    Also puts the screw in tension rather than a bending moment when pressure is applied from verticle.
  5. Mike VV
    Mike VV
    from SoCal
    Not really. They are only a coupla/few degrees, not enough to miss any glass if you drill too deep.
    Again, not really..! A screw at about a 5° or 6° angle is NOT really in tension..! It's still in shear (or bending as you call it).
    Mike
  6. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    As to support weight.....
  7. My thoughts exactly.
    Think about it, if the screws were attached straight in it would be logical if using the arm rest to pull the door shut the non angled screws would eventually loosen up and pull out, the angle just gives the screws a better chance of staying tight.
    When I was removing the arm rest on the Ranch Wagon they were very tight and after almost 5 decades the screws put up a fight taking them out, verses some of the straight screws holding trim which had no resistance at all. HRP
  8. sliceddeuce
    sliceddeuce
    That was far too easy...………………..Lord I am good.
  9. Ebbsspeed
    Ebbsspeed
    If a screw is tight, no matter the angle, isn't it in tension?
  10. DDDenny
    More contact area or thread engagement so to speak, the same reason for using fine threads on thinner sections of stock.
    302GMC likes this.
  11. 41rodderz
    41rodderz
    from Oregon
    Because that is the way factory design engineers came up with . Mike :D should not be able to say , "Again, not really..!".
    catdad49 likes this.
  12. They're screwed up
    s55mercury66, Truck64, 56don and 6 others like this.
  13. radarsonwheels
    radarsonwheels
    from Philly
  14. So why are turds always tapered?? So your butt hole don't slam shut....
  15. Terrible80
    Terrible80
    Good spot for nutserts.
  16. radarsonwheels
    radarsonwheels
    from Philly
    Welp I guess the angle is helpful for keeping the screws tight under constant elbow pressure. My truck has clip on nuts so it’s not a thread engagement in sheetmetal issue.
    I am thinking little angled chunks of tube tigged to the base will be the best easiest and wood wedges with countersunk holes would be the cleanest.
    I like the hamb because lots of responses always come fast- part of that is all the smart-assery which ia fun too. I guess since it went straight to potty jokes instead of making fun of my armrests they must not be too ugly or wierd looking!
    Thanks all for the input
  17. catdad49
    catdad49
    Hey, those engineers get payed Big bucks to get this shit Right! Well.............most of the time.
    Bandit Billy likes this.
  18. Bandit Billy
    Bandit Billy
    Having worked on my daughters VW van last night, there is an overpaid German out there somewhere.
  19. goldmountain
    goldmountain
  20. DDDenny
    Farfegnugen!
  21. catdad49
    catdad49
    Billy, they just worry about the design aspect (on paper). The Techs (or us) are the ones that have to deal with the result (in real life)!
    OLSKOOL57 likes this.
  22. KenC
    KenC
    Yep, the angle causes your elbow weight to create additional tension, instead of a bending force.
    All ones I recall working on are at a near 30 or 40 degree angle, not the 5 or 6 I saw in another post.
  23. Think VW is bad....ever work on a Renault? Cheapest crap I ever saw.
  24. Bandit Billy
    Bandit Billy
    LeCar is LeCrap Nes pa?
  25. 1946caddy
    1946caddy
    from washington
    The angle of the head of the screw is set so the head is flat with the curved bottom of the arm rest.
    radarsonwheels likes this.
  26. rjones35
    rjones35
    Just to make it harder to get the screws started. Some engineer got a good laugh out of it I bet.
  27. Here in Oz the guys at T J Richards who were the Oz mopar body builderswelded a piece of 3/16th plate onto the door shell where the armrest lives, drilled and tapped 2 1/4" UNC holes and the brackets that hold the armrest against the door are slotted so the armrest can be adjusted forward and back about 1&1/2 inches then you just tighten the screws against the door card...........the screws have a large molded on plastic head so they can easily be turned & tightened by hand...........this is the only pic I can find that you can just make out the plastic headed screws......andyd
  28. radarsonwheels
    radarsonwheels
    from Philly
    05B6149D-5A81-41FA-97F8-803D6044E6FB.jpeg EF37FED2-5591-4EBE-B56B-B2CEF1A06708.jpeg I got the armrests done- ended up making 30° angled washers/spacers out of 3/4” round stock.
