Projects What about pipe nipples in brake system?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jun 7, 2019.
  1. I’ve not seen it,,,
    but SOB there’s a bunch of inverted flair to NPT, then NPT to inverted flair on this one we’re redoing. Sure would be less fittings, less flairs and a way cleaner install.
    Just a few short nipples here and viola!
    1887B8E0-AE2E-4DE8-A7C9-7E3F0180934E.jpeg DAE25B7E-0832-4C0D-8B3C-8B8B8131A7B9.jpeg BED81CBA-0123-4F65-AF98-0351FD1BAB80.jpeg
    We’re redoing this crap
  2. deathrowdave
    deathrowdave
    from NKy
    Just a reminder pressure is rated in Lbs . Per square Inch. That 3/16 x 1/8 NPT fitting actually does not have the amount of force or pressure on it that one may think is on it at any given time .
  3. rustythumb
    rustythumb
    but NPT in a brake system may work, but just seems wrong!
  4. Hnstray
    Hnstray
    from Quincy, IL
    why?
    firstinsteele and sunbeam like this.
  5. jaw22w
    jaw22w
    from Indiana
    Not much else you can do when every unit, brake pressure switch, residual pressure valve and proportioning valve are all tapped for NPT. I'd say it is the manufacturers making cheaper units by omitting machining for IFF threads.
  6. Here where I live, pipe threads in a braking system are illegal. The funny thing about that is, you can still use a pipe thread pressure switch for brake lights. Go figure.
    porknbeaner likes this.
  7. Rich S.
    Rich S.
  8. The old hydraulic pressure brake light switch is 1/8" NPT, I believe.
    Phil
  9. sunbeam
    sunbeam
    A brake system will generate 1200 to 1600 psi many farm hydraulic systems use pipe in hydraulic system that see 2500 to 3000 psi.
  10. ISO Bubble type is easier and cheaper yet.
    VANDENPLAS likes this.
  11. jaw22w
    jaw22w
    from Indiana
    Stii
    Still gonna have to use some type of adaptor on those NPT tapped units.
    chryslerfan55 and Hnstray like this.
  12. Yep,
  13. Bandit Billy
    Bandit Billy
  14. ..??o_O...??
    With a nipple you could stack the RPV and bias adjuster right?
    That saves two joints and save a few inches of space right?
    With a nipple you could stack the pressure Switch Tee and the RPV as well
    That's another two potential leaks and another Three inches.
    That all sounds like it could be really good thing.
  15. bschwoeble
    bschwoeble
    In that same area, It grinds me to see numerous fittings on the master cylinder to attach 3/16" or 1/4" lines. Get the fittings the factory uses, please. All it takes is a little time to find them. Jegs and Summit both carry them.
  16. 79BB8A42-5CD2-406D-9A6F-857EFD9121EF.jpeg 6 Adapters from NPT to inverted flair in the area that’s the size of your fist.
    Nipples ,,, we need nipples.
  17. The shortest brake line I can make today -
    2-1/2 inches
    chryslerfan55 and gimpyshotrods like this.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I suspect some sort of visual trauma from the past is the reasoning for such a dislike.
  19. Rich S.
    Rich S.
    chryslerfan55 and Happydaze like this.
  20. You ain’t right
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No, I had my self tested. I only suffered from anxiety do to childhood brain washing.
    theHIGHLANDER likes this.
  22. Rich S.
    Rich S.
  23. Hnstray
    Hnstray
    from Quincy, IL
  24. Hnstray
    Hnstray
    from Quincy, IL
  25. Rich S.
    Rich S.
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What is the P.S.I. rating of what you've looked into? Fitting are thicker than nipples.
  27. Rich S.
    Rich S.
    The line from the proportioning valve with the red union and adapters. If that goes back to the MC, maybe replace the whole line and get rid of the red union and adapters.
  28. Are you being funny?
    That union is kind of important
    The red one is the 10 psi residual valve.
    The blue “union” is the 2psi residual valve
  30. Rich S.
    Rich S.
    Nope, I didn’t realize that. I was looking to simplify and get rid of the adapters and have less joints. Thanks for telling me that.
