Technical 1962 Pontiac Frame Numbers
Discussion in 'Traditional Hot Rods' started by 31hotrodguy, Jun 2, 2019.
  1. 31hotrodguy
    31hotrodguy
    To all my Pontiac friends, my 62’ Pontiac has been “in storage” so to speak for years and I need to get a vin verification to get the paper work started. Where are the numbers on a Pontiac frame? I did a not so quick search online and didn’t find anything. Any advice??
    Thanks in advance
    Scott. [​IMG]
  2. AngleDrive
    AngleDrive
    from Florida
    I believe they are stamped on a metal plate and attached to the left front door jam by the hinge with rivets.
    Unique Rustorations likes this.
  3. Bird man
    Bird man
    from Milwaukee
    Stamped on top of frame, usually visible with a mirror. I think drivers side?
    31hotrodguy likes this.
  4. Unique Rustorations
    Unique Rustorations
    I don’t know if these will help since they from a ‘68. You should have a data plate and a Vin plate as well as others have pointed out and poss a partial vin number on the drip rail for the trunk (good luck with that one:). Regards, Randy
  5. 31hotrodguy
    31hotrodguy
    I’ll clarify. Our DMV has a silly policy where they want two numbers when they do a vin verification = 1. the vin tag and 2. the frame number. This why I’m trying to locate the frame number.
  6. 31hotrodguy
    31hotrodguy
    Any idea about where so I don’t have to wire brush the whole top of the frame? For example tri5’s are typically right under the front seat area on the driver side.
  7. stuart in mn
    stuart in mn
    If the engine is original, it has the VIN stamped on the front of the block on the passenger side, next to the engine code. If they accept it that would be easier than trying to find one on the frame.
  8. 31hotrodguy
    31hotrodguy
    That would be a good start and a heck of a lot easier. I’ll break out my wire brush this afternoon
  9. Unique Rustorations
    Unique Rustorations
    From 1968 onward. This won’t apply to a ‘62. Randy
    earleg and 31hotrodguy like this.
  10. 31hotrodguy
    31hotrodguy
    I found the 140903 number but that doesn’t correlate with the vin tag. Am I close? I’m not seeing any other numbers on the front of the block.
  11. Unique Rustorations
    Unique Rustorations
    They didn’t start stamping the Vin into the blocks until 1968. That is a EUN (engine unit number) and won’t help with your Vin number. Randy
  12. 31hotrodguy
    31hotrodguy
    That would explain that. Thank you. I did however; learn that my car was made in South Gate CA and has 62’ heads.
  13. 31hotrodguy
    31hotrodguy
    I took the car down to AAA anyways but with no luck. Usually I get someone with common sense that is not interested in climbing under the car to look for numbers. The person helping me had no desire to climb under the car (I don’t blame them) but also had no intent of passing the car. So now I have to find another number. The cowl tag doesn’t tell me anything in regards to a vin and I haven’t found a corresponding engine number. So we are out looking for numbers on top of the frame near the trunk.
  14. vickckik
    vickckik
    CHP used to have, and most likely still does, an auto theft unit that had books from manufacturers that gave locations of ID numbers for all American cars and many foreign ones. A friend of mine who recently died was assigned to the unit. Maybe you can hook up with a Chippie who will help you out. I suggest you appear in person at the local office and begin your inquiry.
  15. treb11
    treb11
  16. sunbeam
    sunbeam
  17. evintho
    evintho
    I had my '54 VIN verified and they only wanted the VIN # off the VIN tag. Remember, if you ask 4 different DMV clerks the same question, you're gonna get 4 different answers! Our local CHP does VIN verifications every Tues and Thurs. I suggest you call/visit your local CHP office and ask them exactly what is required and then have them do the actual VIN verification.
    gimpyshotrods and 31hotrodguy like this.
  18. gimpyshotrods
    gimpyshotrods
  19. gimpyshotrods
    gimpyshotrods
    Do you have "supporting documents" that show some numbers?
    If you do not, a private, or DMV VIN verification won't do. The car will have to go to CHP. They will know where the numbers are.
  20. 31hotrodguy
    31hotrodguy
    Thank you. I haven’t checked them out yet but I will!!
  21. 31hotrodguy
    31hotrodguy
    Sadly I don’t. But in the past (like 3 months ago) the person at AAA didn’t want to climb under the car so the vin plate was good enough.
    I don’t mind going to CHP. From my experience The guys down there are actually really cool about it is just another appointment and having to tow the car which means I can’t do a whole lot to it until that happens.
  22. gimpyshotrods
    gimpyshotrods
    As of November of last year, vehicles without supporting documents MUST go to CHP.
    It might be a hassle, but make the appointment, and get it over with.
  23. 31hotrodguy
    31hotrodguy
    I should work out okay in the end. I think I was just grumpy the other day because it was over a hundred degrees and the person helping me seemed completely lost. I called chp and I am just waiting for a call back to schedule an appointment. I’ll probably have to call him back next week. Hopefully he is not too worried about the rear frame number that doesn’t exist.
  24. Pontmerc
    Pontmerc
    from Finland
    I have a strong feeling, that if you ask them: Frankspontiacparts.com
    They will know where to look frame stamped vin.
  25. 31hotrodguy
    31hotrodguy
  26. 421-6Speed
    421-6Speed
    This is my 1960 Ventura frame. Vin located on the passenger rear top of the frame rail.
  27. 31hotrodguy
    31hotrodguy
    Thank you very much! From everything I have read the 61/62 is on the drivers side but either way it gives me a very good idea of where to hunt for it. Much appreciated!
    Ps. If you get a chance I wouldn’t mind seeing pictures of your 60!
  28. 421-6Speed
    421-6Speed
    I have done several 55-62 GM vehicles and everyone has had the vin in that same location. Granted they were all Van Nuys plant.
    I did this car in 17 months finished in July 2016.
    Hurst Shifter 3734734 installed.jpg 60 Ventura 389.jpg Masking pulled.jpg Dr Front.jpeg Dash.jpeg floorpans.jpg
  29. 31hotrodguy
    31hotrodguy
