Projects #25 model A coupe
Discussion in 'Traditional Hot Rods' started by slinginrods, Oct 2, 2016.
  1. slinginrods
    slinginrods
    from florida
    It just depends on the length of the column . I left about 6” of the original shaft and welded the joint to that then slide the dd column into the other end
  2. slinginrods
    slinginrods
    from florida
  3. slinginrods
    slinginrods
    from florida
    IMG_8029.JPG IMG_8042.JPG IMG_8043.JPG IMG_8044.JPG IMG_8040.JPG IMG_8041.JPG
    Started tackling the rusty crusty rotten roof wood and panels. This girls seen some genuine hackery ,like the galvanized metal “patch panels” . It should be a good time getting her back in shape before the chop.
    Nailhead A-V8 likes this.
  4. slinginrods
    slinginrods
    from florida
  5. Stovebolt
    Stovebolt
    My bad - I meant how much diameter of the original shaft was left after it was reduced for a double -D coupling?
  6. slinginrods
    slinginrods
    from florida
    I didn’t grind the steering shaft
    I used a joint with a 3/4”round opening on one end and a DD on the other. The steering shaft is a touch bigger than 3/4” so I opened up the joint so it would slide down over the shaft
    Stovebolt likes this.
  7. Francis bruno
    Francis bruno
    Ive been reading this post before i ze
    Ive been reading post not realizing this is you until i saw the tank i built, guess im getting old
    slinginrods likes this.
