Hot Rods How do you tie down hoses, cables and wires up under the hotrod?
Discussion in 'The Hokey Ass Message Board' started by testdepth, May 18, 2019.
  1. testdepth
    testdepth
    As I am under my truck installing the new emergency brake Wilwood cables kit I start looking around at the way the wires and hoses are routed and tied down to my truck. Most of it is held together with plastic zip ties. How do you guys keep it all neat and in place under your hotrods?
    Do you zip tie as well or something else?
  2. Black_Sheep
    Black_Sheep
    These frame clips are often used on semi trailers, you can see how I used them to secure the split loom along the frame rail. On the opposite frame rail the same clips with tubing clamps secure the fuel line at numerous points along the frame. For brake lines I use small stainless steel tubing clips screwed directly to the frame. 36810078_1720394307998043_3823688450234646528_o.jpg
    Where my battery cables pass over the frame I used a hydraulic tube isolator to be 100% sure they couldn't rub on the frame. you can also see spiral wrap pairing the cables together and protecting them underneath the vehicle.
  3. David Gersic
    David Gersic
    from DeKalb, IL
  4. Flathead Dave
    Flathead Dave
    from So. Cal.
    Duct tape
    iwanaflattie likes this.
  5. The good zip ties ,,,, :p:D
    loudbang and iwanaflattie like this.
  6. Frankie47
    Frankie47
    from omaha ne.
    Adel clamps.
    charleyw, jnaki, egads and 2 others like this.
  7. Wtf dude ,,
    You broke my phone
  8. Frankie47
    Frankie47
    from omaha ne.
    Yeah, I had to delete that long winded script....lol.
  9. Do you know where I can find the clips for the frame rails? That looks like a great solution.
    Matt
  10. Black_Sheep
    Black_Sheep
    4woody and Bandit Billy like this.
  11. 42merc
    42merc
    Caddy Clip - Found at your local electrical supply house.
    Frankie47 likes this.
  12. Awesome, Thanks.
  13. olscrounger
    olscrounger
    Found some similar to ones black sheep shows at NAPA on the help board. Slide on frame and bite into metal
  14. Blue One
    Blue One
    from Alberta
    Look at Made for you T clamps.
    I’ve used them everywhere on my RPU and they’re really good.
