Technical anyone ever think of a fire extinguisher for garage ?
Discussion in 'The Hokey Ass Message Board' started by The Bomber, May 16, 2019.
  1. The Bomber
    The Bomber
    from mass.
    Planning on building a new garage, thought came to mind the other day. I thought of all the things i'm thinking of doing when finished, shouldn't the first thing I get is a fire extinguisher? You see them in cars, but I've never noticed them in garages, even here. Maybe I don't see them but thinking of all the things that can happen and have happened, would make sense to me....it's a cheap preventative if a fire breaks out. Thanks for any feedback.
    KoolKat-57 likes this.
  2. BJR
    BJR
    Just installed one last week.
  3. The Bomber
    The Bomber
    from mass.
    cool! smart thinking
  4. squirrel
    I have 3 or 4, I think...never had to use one, but you never know.
    nunattax, rockable and KoolKat-57 like this.
  5. I’ve got 6
    Always make sure the hose is on and works before doing hot work.
    Not had to pull the pins or run the hose.
    Air and a squirt bottle
  6. Flathead Dave
    Flathead Dave
    from So. Cal.
    Always have one in my garage.
    31Dodger likes this.
  7. I always have one in my garage and my car....just in case....
  8. DDDenny
    They need to be checked/recharged periodically.
    alanp561, juan motime and KoolKat-57 like this.
  9. JC Sparks
    JC Sparks
    from Ohio
    It's the type of thing you don't need until you need it. And then you sure better have it.
    j3harleys and Atwater Mike like this.
  10. belair
    belair
    Damn right. There is no such thing as a little fire.
    rockable likes this.
  11. The Bomber
    The Bomber
    from mass.
    very good hambers, guess i'm a little late catching up to that smart thinking...i'm guess I didn't look hard enough at the garage pics here for the idea....i'm embarrassed...lol
  12. Atwater Mike
    Atwater Mike
    Ugh. Little fire spark big one.
    I have 2, one's empty. Time to call Jeremy and get it filled...
  13. 31Apickup
    31Apickup
    Always keep one with the welder and have a second by the door to the house.
  14. Relic Stew
    Relic Stew
    from Wisconsin
    The weld shop at work used to have two 125 cf CO2 bottles on a cart connecting to a single hose. Made me kind of want one for the home shop.
    Extinguisher bottles are different from regular gas bottles, as they send liquid from the bottom out the hose.
  15. Gman0046
    Gman0046
    You bet I have an extinguisher handy. Just noticed the one we've had in our pantry for the last 10 years was pointing to empty without ever being used. Glad I noticed it.
  16. 41rodderz
    41rodderz
    from Oregon
    About four and a water hose handy.
  17. Rusty O'Toole
    Rusty O'Toole
    I always have one mounted by the shop door. That way if I have to run for the extinguisher I will be running for the exit, and when I turn to fight the fire I will have the exit to my back.
    It's good to have another one by the welder but I find a squirt bottle of water handier, and cheaper.
    In the last 50 years I have needed an extinguisher 3 or 4 times but use the squirt bottle nearly every time I weld something.
  18. X-cpe
    X-cpe
    Have had them for years. Hope to keep on never needing them.
  19. I have 2 in my garage, I take them to the local safety equipment shop and have them checked out when the charge starts to drop. HRP
    OLSKOOL57 likes this.
  20. CruZer
    CruZer
    Almost burned my 34 coupe up in the garage. I had an extinguisher and put the fire out. Tip them upside down once in awhile so the powder doesn’t pack.
  21. 2935ford
    2935ford
    I've had one in mine for years.
  22. KoolKat-57
    KoolKat-57
    from Dublin, OH
    No shop or garage should be without at least one.
    1 in a work area, and 1 by the exit/entrance door.
    I have 20 pounders in my garages.
    They should be checked at least every couple of years by a certified fire extinguisher company.
    You should eyeball the gauge at least once a week, just in case you need it in a hurry!
    Just my experience and thoughts on the subject.
    KK
    BigChief and alanp561 like this.
  23. Casey Riley
    Casey Riley
    from Minnesota
    Gotta smack the botttom with a rubber mallet a few times while upside down too.
  24. mgtstumpy
    mgtstumpy
    Yep, like insurance. You never want to use but when you do, it's there!;)
  25. It's a no brainer.
  26. Have four small ones in the garage. Another 2 1/2 gal water that I put soap and water in to kill the wasps. Shoots a long way.
    alanp561 likes this.
  27. Jimbo17
    Jimbo17
    I have two in the shop and a few under the sinks in the kitchen and bathrooms just in case.
    I do not bother recharging them I find it faster to just replace them with New ones.
    How about smoke detectors in the garage? You should have one!
    I also have an alarm system with camera's installed.
    Jimbo
  28. Boneyard51
    Boneyard51
    Alway have fire extinguishers in my shop and home. Have several different types. The dry powder are good but make a mess. I have collected several water extinguishers. Good for some fires but not all.....cheap and easy to clean up!
    Bones
  29. Rich S.
    Rich S.
    I have 3 on the wall and a loose one that I bring over to where I’m cutting or welding. Never needed it, but that’s what I do.
  30. I have several, of different types. If you have a fire in a confined area, like an engine bay, a CO2 extinguisher is mighty handy, as you won't be cleaning up afterwards. Just make sure the place is ventilated. Also, a fire blanket is good for smothering small fires. There are charts to show you what type of extinguisher to use with different type fires (fuel, electrical, etc). Using the wrong type of extinguisher can be useless or make it worse. FE-USE-e1552046424248.png
