Technical 56 Lincoln windshield gasket made of unobtanium?
Discussion in 'The Hokey Ass Message Board' started by indcontrols, May 14, 2019.
  1. indcontrols
    indcontrols
    It seems that a new windshield for the 56 and 57 Capri and Premiere is available everywhere, but I think I have called all of them and no one has the gasket / seal... The MARK II seal is available, but not the Lincoln...
    Anyone have one, know of one, or even have a piece /sample of one that I can use to match up something close ?? I foolishly threw away the old one at some point in time - which is weird because I really never throw away car parts - I'm sure I'll need them at some point !
  2. coilover
    coilover
    from Texas
    If you can find even a small piece to get a cross section Metro Molded Parts in Coon Rapids Minnesota can make you one. Might be worth a call to see if they have a pattern in their library. Guess you have already tried Steele.
    Bigblue61 likes this.
  3. indcontrols
    indcontrols
    I was thinking the same thing if I could get a piece, could possibly even extrude it myself if it came to that... I did try Steele - they don't have it, but they do have plenty of profiles that I might me able to match up to... I think I ended up using a Grady White seal on the Rambler back window, it was really close. !!!
  4. gatz
    gatz
  5. mgtstumpy
    mgtstumpy
  6. 5window
    5window
  7. indcontrols
    indcontrols
    Still striking out - anyone have a piece of one ?
  8. BamaMav
    BamaMav
    from Berry, AL
    Did you try Boos- Herrill?
  9. indcontrols
    indcontrols
    Looks like they are are 36-48 only, actually looks like you could build one from scratch with just their parts ! No 56 stuff, but I will try them nonetheless...
  10. 56premiere
    56premiere
    I have some pieces ,pm an address I'll send you one. I think Bobs classic glass was showing the seals,about 500 each
  11. indcontrols
    indcontrols
    Awesome, thanks !
