I have a pair on the shoebox, the 32 Ford Sedan and the 59 Olds wagon. On board compressors on the 49 and 32 make it nice to be able to adjust them while moving
I have the same setup on my 52 Ford Mainline. I've been running closer to 50psi. Sent from my iPhone using H.A.M.B.
Ah, the days of everyone piling in the car and driving around with the L60s scraping on every bump and turn while trying to find a gas station with enough air to pump up the shocks.
Had them on my '55 Chevy for decades but not mounted in the stock location which is the trunk floor. Air shocks poked a hole in many a tri five Chevy trunk floor.
Yes, I had them on 1 or 2 cars back in the day, but they went out of fashion. Engineering the car to sit low was the next evolution of hot rodding. Back in the early 80's air assisted suspension was used a lot on motorcycles, to fine tune the ride. My 82 Yamaha XV920 had air suspension, front & rear. I had to buy a special pump to air them up accurately.
A lot of oversized tires on the rear of cars not designed for them and air shocks became the solution, it kept the tires from getting cut up bu the fender lip. HRP
It also helped to have the adjustable shackles on the leaf springs... All I did was raise the ass end up 2 more inches and tried to maintain 30-40 psi in the shocks...
Come to think of it, my last rod, the '32 p/u had them when I got it. Only one had air to level it I suppose. You can see in this pic that the left one has air, and the right doesn't even have a line hooked to it
I have two cars that have had Highjackers since the beginning and are still on the cars today. A 70 Camaro and a 70 Challenger. Have an extra pair on a shelf. They still work so they are still on.
I have a set of HJ'ers in my Shoebox, put in for drag racing and plumbed indiviually for coming out strait if needed..Never used as such but there is supposed to be 10/15 # kept in them to keep the bags from "chaffing".
I put a pair on an OT pickup a few years ago because I was doing some hauling and wanted to level it out. I fully expected to return to normal gas shocks but they road well with just the recommended twenty pounds in them and they stayed on it.
I was going to post about that! Worked in a service station in '60 and saw more than one of those. Usually on Sat night when us kids loaded up the car with friends and cruised main street. They'd stop at the station, jack up the car, hit the gas and railroad tracks too hard.
I have had 3 sets of Gabriel’s on my 57 wagon since I got it many years ago. Installed a shock bar with the first set of high jackers. Last set I installed separate fillers. Keep 20 pounds all the time, more when taking friends along.
Had them on my '57. It rode fine with 20# of air and if I wanted to haul something it hit the axle on the bump stops hard. Load it, air it up and drive like normal. Worked great. SPark
You might look at this chart and figure out what you need. https://www.summitracing.com/search...rdMatch&SortOrder=Ascending&autoview=SKU&ar=1
My latest project 57 Chevy p/u had a set on them, might put them back to help out the old parts hauler.
Have had a set of Hi Jackers on my 65 Barracuda since 1983. First mode I did to run taller, wider tires. Never let me down yet, and rides pretty good. Also installed a set on my 66 F100. A little air helps keep it from bottoming out on big bumps. Sent from my SM-G950U using The H.A.M.B. mobile app
well i am here to tell you i absolutely hate them. ever single set i ever bought would leak. i even have a new pair in the boxes i will probably never use. i am a gluten for punishment. i bought those just a couple of years ago. i built my heny j to use them so i could tow my race car. i would fill them up and by the time i got there they would be flat. i have bought new hose kits and they leaked. please don't ask me if i used the seals or any other way to stop them from leaking because i have tried everything. i think the first pair i bought was for my '54 ford mainline back in '63 and they leaked!!
This place list air shocks for Oldsmobile wagons. HRP http://www.shocks2springs.com/OLDSM...TSAIRASSISTEDLOADLEVELEROVERLOADBOOSTERSHOCKS 1957-60 ALL OLDSMOBILE STATION WAGONS - air shocks # 4015
I don't have a clue but you can call and ask, they seem to have a huge range of applications. HRP A-1 Shock Absorber Company 970-513-8283 or 9800-344-1966
They came stock on my El Camino. I use them when I take crap to the dump. They're Gabriels, they work OK.
I used them on the Pusher. Gabriel's as I recall. Mine mounted before the axle and I used them for traction control at the strip and weight control when I was hauling a big load. I did not use them to gain rake.
