Picked up a older Offy tri power intake today. It has 3 large base 2 jets on it. There are NO numbers on the carbs except the center does have a 7032270 casted into it, with no returns from a Google search. Also the spring return hook for the outboard carbs is casted into the center carb with a small bracket bolted to it. Would like to get the proper kit for these...
Just a guess, they look like proper 3 deuce carbs. I would guess if you got a kit for 67 GTO carbs you would be ok. Most kits have all the different bits for all the different carbs that are the same base
That is what my best guess was... 65 GTO. 66-7 changed where the inlet on the primary was. but what throws everything off is the bracket on the base of the primary for the return spring of the secondary's.
The front and rear carbs appear to be front and rear carbs from a 1959~1963 Pontiac tripower. The carb in the center is not a tripower carb. Best guess - 1963 Pontiac large car with modifications. http://www.thecarburetorshop.com/Tripowerspecs.htm Jon.
