Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. Drained my fuel system in the 41 in preparation to change out fuel pump, regulator and ad a return line.
    Cleaned up a tri-five disc brake kit to put on craigslist and also cleaned the 41's rear rims, killed enough brain cells today with all those fumes.
  2. ...drove my 55 pickup for the first time today, about 8 miles, everything seems good so far...
  3. jimmy six
    jimmy six
    Finally got the adjustment right on my neutral start switch. Been fighting it ever since I replaced the Ford-0-Matic with a Cruise-0-Matic. Making an additional spot on the indicator added to the problem. IMG_2066.JPG IMG_2069.JPG
    62rebel likes this.
  4. Here's the trick.
    Open the hood as far as it will go then screwdriver it. Plenty of room with the hood on.
    Hamtown Al and Bandit Billy like this.
  5. 62rebel
    62rebel
    Be my luck to catch that screwdriver with my elbow, knock it out of the stay, have it land point down on the fender and punch a hole in the 'glass. Meanwhile, trying to catch it, I'd drop the radiator on top of the fan and slice it AND my hand open. I ain't saying I have bad luck, but I could walk through a storm of poontang and get slapped in the face by a dick
    Tomincanada, Hemi511, LowKat and 3 others like this.
  6. Bandit Billy
    Bandit Billy
    I have to say that is a pretty radiator!
    LowKat likes this.
  7. Moon50F3
    Moon50F3
    That was funnier that shit!
    Tomincanada likes this.
  8. 62rebel
    62rebel
    I can't take credit for it, somebody a lot funnier than me got rich saying it
  9. Hemi511
    Hemi511
  10. 62rebel
    62rebel
    Did my best to seal up the leaks I mentioned. Hopefully it works sufficiently well for another eight months.
  11. David Gersic
    David Gersic
    from DeKalb, IL
    A quick lunchtime run to the transmission shop, picked up my 37 with now a correctly working transmission, and drove home before it started raining again.
  12. brianf31
    brianf31
    Tried to replace a lifter in my 351C without pulling off the intake. Of course it had to be one in the middle, just beyond the large access holes.
  13. GreaserJosh13
    GreaserJosh13
    from Chino
    Ha ha ha ha ha ha ha!!!!! I seriously laughed out loud at this & then tried explaining to my wife why I was laughing. She chuckled, but didn’t find it nearly as funny as I did. I’m still laughing about this & it’s been a couple hours since I first read it. Thanks for making my day even better. Great post.
  14. southcross2631
    southcross2631
    I fixed the fog lights on my motorcycle and had to rode test them. It was a beautiful Tn. day.
    Got back and installed my switches and starter button on my Morris Minor Gasser project.
  15. Binkman
    Binkman
    Today I hung a rear bumper on my '34 P/U project.
    I had to make irons because the '34 panel irons I bought would not work.
    Remake irons, relocate tail lights because the bumper hid the license plate, etc.
    10 hrs total.
  16. gearhead1600
    gearhead1600
    Well got that desk done in 4 coats ( who would have thought )
    Hot wheels cars mounted
    Broke a screw in one of the cars , no big deal it was a Jetta or something that looks like it [​IMG][​IMG][​IMG]sure hope the little guy likes it
    Finished the day listening to
    End of the line by
    Traveling Wilburys
    Tomincanada, 40two, Latigo and 3 others like this.
  17. Great looking truck, what are the details on it, sits nice.
  18. Hemi511
    Hemi511
    Update: Recessed firewall, finally got room to put the rad in the engine bay where it belongs. 20190503_154800~2.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
    gearhead1600 and swade41 like this.
  19. 62rebel
    62rebel
    Well, it rained last night and the seal job seemed to do the trick. I have to admit I threw the PO under the bus about the window seals; he didn't pull them off, just the front edges where the vent windows close up against the roof are gone (a known failure spot). "Sorry, dude." Anyway, now I can seal up the floor without creating water bowls.
  20. ...thanks, it's running a 292 Chevy six inline/350 turbo trans,Nova sub and rear,...finally got it out of the shop after 4 years since starting to build it,..have other old vehicles so wasn't in any hurry .
    40two, OLSKOOL57, thehazguy and 3 others like this.
  21. jimmy six
    jimmy six
    Finally replaced the 160* thermostat with the correct 170* in my 56 Y-Block. Permatex#2 is always a pain...NPS had the right one....
    gearhead1600 likes this.
  22. David Gersic
    David Gersic
    from DeKalb, IL
    Washed last year’s dirt, grime and brake dust off between rain storms. Need to wax it still, in preparation for this year’s dirt, grime and brake dust.
  23. SOHC427
    SOHC427
    Installed longer studs, in my M/W Axles, put together, I side, of the Rotor, and bearing preload set, and took a Glamour Shot of the power, for my 40 Willys build, and I was able to finish the rear floaters. 59926825_10214622841669526_7948233587118047232_n.jpg 59615182_10214622768507697_5782574578119213056_n.jpg 59639511_10214622768187689_6944641738841522176_n.jpg
  24. saltflats
    saltflats
    from Missouri
    ^^^ You don't play fare. :D
    Max Gearhead and SOHC427 like this.
  25. SOHC427
    SOHC427
    Why start now?? Hhahahha
    saltflats and WTF really like this.
  26. jimmy six
    jimmy six
    Kinda confused on your use of "floaters" Unless I'm just seeing it wrong or not up on Mark Williams rears... We run floater axles on our dirt car and the hubs are on the housing with large nuts and double bearings The axles have splines on each end.
    SOHC427 likes this.
  27. Pulled the heads on a Ford engine to check for cracks. DSCF4936.JPG DSCF4937.JPG
    leon bee likes this.
  28. SOHC427
    SOHC427
    Comp engineering set up...
  29. JJ’s66
    JJ’s66
    After a 12 hour day of work I went home and started looking online for a new reason to start building that little 327 sbc I have sitting in the shed. Not that the wife will let me buy anything else since my Ford is in the paint shop and my second truck is sitting in the garage waiting until I finish the first one. We can still day dream right ??? Lol! Hope everyone has a great Mother’s Day with there loved ones this weekend. Remember without moms we wouldn’t be here today enjoying what we love to do.
    The37Kid, Tooth and chevy57dude like this.
    Set about to polish the door panel stainless I picked up at Carlisle. Sawed a Grove in a 2x4 to hold the pieces while sanding. Just push the mounting spikes into the groove and clamp it to the bench. 400 grit first, needed something lower but didn't have any for the test piece. It was very hard to get the deepest scratches out. Then 600. Had some 1500, 1557484575643798802495.jpg Then staves 1, 2, and 3 polishing on the trusty drill press. Dedicated buff for each grit and clean 'em with a screwdriver is the extent of my knowledge on this. Oh, and don't slip!
