Technical 1953 ford Blinker wiring
Discussion in 'The Hokey Ass Message Board' started by Boden, May 6, 2019.
  1. Boden
    Boden
    I am done wiring most stuff accept the blinkers. I am wondering if anyone knows what color the wire is that comes out of the column to the flasher relay?
  2. 24riverview
    24riverview
  3. greybeard360
    greybeard360
    Do not forget to add blinker fluid when done. You can find some at www.kalecoauto.com if your local store doesn't carry it.
  4. Boden
    Boden
    Oh. Good. I almost forgot. What DOT does a 1953 ford customline Tudor sedan take.
  5. Boden
    Boden
  6. s55mercury66
    s55mercury66
    from SW Wyoming
    Blue dot for '53 :)
  7. morac41
    morac41
    A lot of people get confused with stop light blinkers ..stop light switch wire runs to the steering column as well as the blinker can..
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. coilover
    coilover
    from Texas
    Hook up power feed wire and have another jumper for the brake light switch feed. Move handle to left turn position. Touch each wire with a test light and TWO will light the light. Activate brake light feed and one of the two wire will light the light---that's the left rear. The other is the left front. Repeat for right side.
  10. Boden
    Boden
    I understand what you mean. So put power to the column and turn the switch and see what wire is hot. But I have no idea what wire is the power feed wire. They are all just hanging. And isn't the power feed wire just the flasher relay for the blinkers?
