Technical pressure plate - rebuild or new?
Discussion in 'Traditional Hot Rods' started by cederholm, May 6, 2019.
  1. cederholm
    cederholm
    I have a decent pressure plate for my 8BA. It could use a resurfacing but otherwise seems fine. I need a new clutch and flywheel, as my flywheel is 11" and I'd like a smaller one.
    Should I look into having it rebuilt or just buy new? This is for an A V8
  2. Bursonaw
    Bursonaw
    I just had mine rebuilt at Fort Wayne Clutch. They did a great job, they even dynamic balanced the pressure plate as part of the rebuild. I went the rebuild route because I have heard of some issues with new pressure plates and clutches on one of the forums. The Borg and Beck presser plates are the better style, but I haven’t seen any new replacement for those so a rebuild may be your only option.
    Sent from my iPad using Tapatalk
    cederholm likes this.
  3. speedshifter
    speedshifter
    I also speak highly of Ft. Wayne Clutch. Their rebuilts are much better than new press plates. I believe new ones are made in China. I have a Ft. Wayne 9" Long press plate & disc ,13 lb alu flywheel behind a hopped up 324 Olds in a 24000 lb roadster. It does not slip. Why 9"? The instant acceleration of the engine when you rev it up in neutral sounds cool. An engineer told me a 8" Borg & Beck press plate, maybe modified, will hold most v8 engines. Greg
    egads and cederholm like this.
  4. AngleDrive
    AngleDrive
    from Florida
    Fort Wayne Clutch
  5. cederholm
    cederholm
    You guys never steer me wrong, I'll check them out.
    Second question, the pressure plate I have is 9", but I only have an 11" flywheel. Should I have it drilled or buy a new 9"? Or send everything to Fort Wayne?
  6. These guys are out in Suffolk county, I had them rebuild a truck clutch for me years back. They have expanded their services since and have a good rep.
    http://www.falconauto.com/
  7. solidaxle
    solidaxle
    from Upstate,NY
    Have you considered shaving a couple pounds off the flywheel? Lite cars like less mass rotating at start. They will rev up quicker.
  8. PHIL COOPY
    PHIL COOPY
    Fort Wayne Clutch.....
  9. egads
    egads
    Can we see a picture of your 12 ton roadster? :eek::D:D
    swervyjoe, Montana1 and cederholm like this.
  10. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    For my Flathead to T5 conversion customers I stopped selling the Chinese junk available from the wholesalers and started sending my customers to Fort Wayne Clutch, (talk to Leo) no problems.
    cederholm and sidevalve8ba like this.
  11. Bearcat_V8
    Bearcat_V8
    from Dexter, MI
    I will put in a good word for Clutch Dynamics in Lansing Michigan. I had them do a clutch, pressure plate and fly wheel for me. They did a great job at a very reasonable price, probably less than a third the price of a new one.
  12. deathrowdave
    deathrowdave
    from NKy
    Nothing is made as it used to be . Anytime I can rebuild an old part there is never any question as to which way to go . Just think aren’t you rebuilding the complete car , if you don’t like that why didn’t you buy a new car and carry on
  13. 4BD4BE50-D77E-4E60-9A3D-950D9491F359.jpeg 4265678E-32CC-492C-BA46-62A1664CB488.jpeg I also run a 9 in clutch in all my flathead powered hot rods. Years ago, I had a 48 Ford prefect(4dr Anglia) that ran 14’s with a 284 Flatmotor and a Muncie 4 spd. I would power shift the Muncie thru all 4 speeds and that little 9 in clutch never let me down!
