Hot Rods Bomber Seat Build
Discussion in 'The Hokey Ass Message Board' started by Ratspit, Apr 24, 2019.
  1. Ratspit
    Ratspit
    I am in the process of building a 34 pickup and wanted a set of bomber seats. After looking around at what was on the market I decided to try my hand at building a set. The seats are loosely based of the Schick Johnson seat used in a P51 Mustang.
    First step was to sign up for a free trial of Autocad so that I could produce templates. After a bunch of mock ups I finally settled on a design and off the drawings went to be laser cut. I decided to use .065" aluminum which made for a very sturdy seat. Once I got them back all I needed to do was bend a few pieces, flare a few holes, and buck a whole lot of rivets. I still haven't decided on the edge detail. I'd like to match the channel that was used on the original seat but that will be really hard to bend. I might use a piece of round stock and slot it. It should be much easier to follow the curve of the sides.
    Here is a cost breakdown.
    Autocad - Free trial
    Laser cutting - $425 (which includes .065" 5056)
    Aluminum hat channel - $80 (eagle-aluminum.com) Part #3571
    Rivet Gun - $50 (Ebay, used)
    Tools - $30 Clecos, bucking bar, and rivet sets ( yardstore.com , used)
    Flaring punches - $200 Allstar 1.5" and 2.5"
    Rivets - $25 (aircraftspruce.com)
    If anyone is interested in the CAD drawings I'd be happy to forward them.
    20190123_171141_resized_1.jpg 20190316_152456_resized_1.jpg 20190316_152500_resized_1.jpg 20190316_152520_resized_1.jpg 20190319_180915_resized_1.jpg 20190320_174221_resized_1.jpg 20190320_174228_resized_1.jpg 20190320_174249_resized_1.jpg 20190330_115844_resized_1.jpg 20190330_115852_resized_1.jpg 20190422_071157_resized.jpg 20190422_071219_resized.jpg thumbnail_20190321_173953.jpg
    Just Gary, RICH B, bct and 8 others like this.
  2. Stogy
    Stogy
    Ain't that just the Bomb...er seats...:D...Really great job @Ratspit...you have to be pretty happy with those...;)
    So you have a bit of work still left to wrap them up but your making it look easy which it isn't...but yes not an uncommon item in postwar hotrods...
    That very nice of you to offer up things for others. I'd say you could produce those and sell them...I mean others do but you seem to have a knack for it.
    I look forward and I'm sure many others to your completed product. Are you making adjustable tracks?
  3. Wow, that is well done. The thought of perfection comes to mind:D
    Stogy and loudbang like this.
  4. Ratspit
    Ratspit
    Yup, I definitely have a bit more work to finish up the seats. The plan is to do a faux patina finish to get a well used look, and make some canvas cushions. Fixed mounts to preserve as much head/leg room as possible.
  5. Bugguts
    Bugguts
    Those look great! Its a shame to cover up all that work with a pad, but more comfortable.
  6. rusty_bits
    rusty_bits
    Hello Ratspit, great job and I would be interested in the CAD drawings if you would not mind. regards
  7. Malcolm
    Malcolm
    from Nebraska
    Nice work! I don't recall the name of the product, but are you planning to apply the olive drab green finish and patina that?
  8. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Bullet holes.....?
  9. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    For a finish on my last 2 builds using Frank Wallic bomber seats I've painted them with 2 good coats of satin black Krylon and when really dry highlighted the edges and rivets with a fine scotch pad. Gave the entire seat a brushed finish with wear areas.
    Stogy likes this.
  10. Stogy
    Stogy
    @Ratspit, Aluminum technically needs (at least in aircraft) alodine before paint for corrosion and adhesion. I suppose many paints are formulated to do that...did you or are you planning that process...obviously Hotrods aren't airplanes but adhesion is important.
    Ever thought of polishing it?
    I was looking at a vintage Jalopy Racer yesterday that had an aviation seat in it. So yes they are an interesting period addition to vintage Hotrods that's a given.
    Just Gary likes this.
  11. MrMike
    MrMike
    I as well, would be interested in a copy of the Cad drawings, thanks in advance.
    Stogy likes this.
  12. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Stogy likes this.
  13. Speed~On
    Speed~On
    Your seats look great, nice work.
  14. george cato
    george cato
    These look fantastic!
    I am definitely interested in the CAD file if ya got it!
    Stogy likes this.
  15. brady1929
    brady1929
    They look great. What are you going to do with the edges? I wish I knew how to make a "j" shaped piece of aluminum to rivet around the edge.
  16. Ratspit
    Ratspit
    I'd really like to match the patina on the original Schick-Johnson seat.
  17. Ratspit
    Ratspit
    A "J" shaped riveted edge would be perfect but I don't know how to bend it to follow the curves.
  18. Ratspit
    Ratspit
    I think a faux patina along the lines of either of these seats would be perfect bomber seat 1.jpg bomber seat 2.jpg
    Jim the Sweep, Just Gary and Stogy like this.
  19. Learned to rivet in the Navy. Wasn't much use where I was stationed. Only a/c was caused by sloppy ground crews. You've done a great job. Every time I see these seats I want to build a few myself. The pleasure of driving my neighbors crazy with a rivet gun would be worth the effort.
    Would also be pleased to have a set of the CAD drwgs.
    Thank you,
    Richard
    Stogy likes this.
  20. Very nice work! Add me to the list for a set of cad drawings. Thank you! Hobo Jim
    Stogy likes this.
  21. NICE JOB on the seats...….
    Wish I had a 2nd to go with my P51 seat that came in my 34 Ford P/U when I got it....
    kidcampbell71 and Stogy like this.
  22. Ratspit
    Ratspit
    Ok, now I'm truly jealous.
    Stogy likes this.
  23. flatheadgary
    flatheadgary
    from boron,ca
    you might look into making hammer form blocks for the edge part.
    Stogy likes this.
  24. boutlaw
    boutlaw
    Ratspit, excellent job, they look great....PM sent
  25. Ratspit
    Ratspit
    I've had some requests for the seat designs so I thought it might make more sense to post the files here for anyone who wants them. The PDFs are scaled at 1:1 and each is set up to print on a 24"x36" sheet of paper. 3 are for dimensions only. The other 4 are the templates.
    Stogy likes this.
  26. uncleandy 65
    uncleandy 65
    They look great, I would hate to think how much time you have in them.
  27. Stogy
    Stogy
    @Ratspit...:confused:...and I thought a name like Stogy refering to ole cigar butt was gross but I think your's captures that flavor very well too...:D
    Joking aside that's very kind of you to share this with us...;)
    brady1929 likes this.
  28. brady1929
    brady1929
    Yes, Pete is a great guy. I couldn't find a printer. So he printed them for me and put them in a tube. And is shipping them to me. And when I tried to send him extra money, he sent it back and said use it for your hot rod.
    There just aren't a lot of people left in this world who would do that, and I really appreciate it. Thanks again Pete.
    brEad and kidcampbell71 like this.
  29. Hemispherical51
    Hemispherical51
    Wow, this is nice work and excellent photos of the build. I have a 31 roadster pick up bodied, Lakes modified inspired rod. that I am currently working on and have been looking to build my own bomber seats. If you are willing to share the cad drawings, this would certainly save some time and be totally amazing and very generous thing to do. Cheers Pete Smith
  30. Johan Anderson
    Johan Anderson
    Hello Peter
    Really like your seat is it still possible to have the CAD for it? It would be nice in my 31 Ford projekt.
