Technical spark plugs
Discussion in 'Traditional Hot Rods' started by jr Sackman, Apr 22, 2019.
  1. jr Sackman
    jr Sackman
    from cali
    i need help i got a 355 with camel hump heads what spark plug is the 1 to ues ?
  2. 427 sleeper
    427 sleeper
    Depends on the application. AC 43 or AC 44 is a good place to start.
  3. squirrel
    yeah, make sure they are gasket plugs, not taper seat.
    Truck64 likes this.
  4. jr Sackman
    jr Sackman
    from cali
    so r43ts can i use them ?
  5. 427 sleeper
    427 sleeper
    No. Just plain 'ok r43. TS stands for taper seat, you need gasketed.
    loudbang and Truck64 like this.
  6. jr Sackman
    jr Sackman
    from cali
    thank you
  7. 427 sleeper
    427 sleeper
  8. If you've got a choice, you might want to start out with a cooler heat range. Your final choice is going to depend on the rest of your build, your fuel system, tune-up and how the vehicle is driven.
    This will give you an idea of what you're looking for.
    loudbang, bedwards and 54BOMB like this.
  9. 54BOMB
    54BOMB
    It’s think the 44s are out of production, unless you look for NOS , I have R45S in my 327 with camel humps . Either way the R43S or R45S is right where you start .
  10. dave lewis
    dave lewis
    from Nampa ID
    I use # 303 autolite..
    Pretty cold plug.
    They are resistor plugs.
    Readily available at oreilleys, autozone, napa.
    They are catalog plugs for international V/8 trucks..
    Dave
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
