Hot Rods The Truth behind these weird & unknown Flathead Heads?
Discussion in 'The Hokey Ass Message Board' started by Johns Rod & Custom, Feb 7, 2019.
    An Excerpt from Dean Batchelor’s Book The American Hot Rod (Page 85)
    One outstanding exception I can think of were some heads made in the 1930’s by Art Sparks. These 21 stud heads (actually 24 Stud) were water-cooled over the valves, and had fins similar to those on a motorcycle cylinder – running transversely instead of lengthwise over the cylinders. Art explained to me that he wanted a different rate of heat dissipation for the valves and pistons, and this was his way of accomplishing that
    Deuces, kadillackid, Muttley and 10 others like this.
  2. seb fontana
    seb fontana
    from ct
    Just to mention there are 8 spark plugs per head though in the pic only four are wired..
  3. belair
    belair
  4. SR100
    SR100
  5. khead47
    khead47
    Bronze ???
    Deuces and loudbang like this.
  6. quickchangeV8
    quickchangeV8
    Looks like these heads are no longer unknown. Johns Rod & Custom - thanks for posting. I wonder if a set of these heads still exist, or if the set in the photo were the only set of these heads that were ever cast and are long gone.
  7. 5window
    5window
    It would be fascinating to learn how he planned to fire 16 plugs off a flathead electrical system.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    ^^^ Prolly use one of Kong Jackson's distributors...just a guess.
  9. Bandit Billy
    Bandit Billy
    those air cooled fins and possibly redundant plugs may mean that was intended for aircraft use? Just speculatin
    Deuces, loudbang and 5window like this.
  10. seb fontana
    seb fontana
    from ct
    Pratt&Whitney did make a Radial engine that was a flathead! Saw a cylinder barrel and head at their on site museum..Angled valves similar to a Harly 45..Since the head bolts were loose I took them out and removed the head; very nice valve/combustion design..Don't remember what engine series or maybe several; the Flathead version was called The Small Overall Diameter Option..I imagine the horsepower output was about 30% less than the radial version and was a few pounds lighter..
  11. RichFox
    RichFox
    The common way was to use a Nash straight eight distributor as the Nash was a twin p-lug engine from the factory. Here was my way. Inexpensive and direct way to fire twin plugs. new ply. jpg.JPG
  12. seb fontana
    seb fontana
    from ct
    What are the distributors? Any mech adv.?
  13. RichFox
    RichFox
    I used Pinto distributors. I have done it with others, I did one with Mallory distributors for a Chrysler outboard for an odd fire Chevy V6 for Al Liest. The Pinto are stock with the exception of advance springs being changed for a more rapid advance. Head shown also takes water from around the exhaust valves, but then just flows back to the holding tank. Water doesn't actually flow around in the head.
    GuyW likes this.
  14. seb fontana
    seb fontana
    from ct
    Pinto, what I thought might be..I was thinking of machining one to fit a Crosley, just to get a larger platform..Looks like you have points..I would need advance curve to start at 750 and be in by 2000 rpm, and handle 4k [dist] rpm..Possible?
  15. RichFox
    RichFox
    I don't know why not. I can absolutely attest to them running well past 8000 at the crank. They are Bosch distributors and use the same points rotor and cap as an air cooled VW. So parts are going to be around for a long time.
    seb fontana likes this.
  16. the37thstreet
    the37thstreet
    What happened to the topic ? Flatheads
  17. RichFox
    RichFox
    Flatheads with twin plug heads. Use distributors. 5window asked how that was done. So now he knows two ways at least. What does your post add to the discussion?
    5window, Blue One, Halfdozen and 8 others like this.
  18. Boden
    Boden
    There so this special cap
    That has 16 plug wires coming out of it. Pretty crazy for back on the day.
  19. drtrcrV-8
    drtrcrV-8
    On my Crosley in the mid '60s I used a stock Crosley distributor & points with a 6v Lincoln coil & condenser & was spinning way over 10K at the crank(not to steal thread, but to add to a previous comment)
  20. Fortunateson
    Fortunateson
    I have a couple of sets of original Eddie Meyer heads and they are cast for two plugs per cylinder but mine were machined for a single plug per cylinder. So it must have been done...
  21. Boden
    Boden
    That's what it is called. I saw a picture of it once and I was blown away.
  22. tubman
    tubman
    Of course, there is the guy in Australia who makes the special front cover for an 8BA that allows two distributors to be run. I have pictures and videos of it running on my other computer back in Minnesota. It's a real clever set up with the primary electrics in one distributor only. The points in the first distributor activate two coils, and the second distributor is just that; it distributes the secondary voltage to the second set of plugs. That way, there is only one set of points and one advance mechanism to worry about. I am very impressed with his set up, and would have one on my "Hot Rod" motor if I could afford it. I am saving my pennies.
    Hnstray likes this.
  23. tubman
    tubman
    Things are fine with me. The only down side of your twin distributor setup is that you have to have the dual plug heads too!:rolleyes:
  24. Commodoreswab
    Commodoreswab
    from West TN
    Any thoughts on making Zephyr heads?
  25. Blue One
    Blue One
    from Alberta
    I’d like to see your response to this comment and this thread.
    In the thread Where have all the independents gone
    @alchemy said:
    I had my dash panel ripped off by an Australian guy. He bought one of mine and is making EXACT copies and selling them.
    And this:
    Yes he is a member. I only sold my dash panels to members of the HAMB. His name is Terry Wills and goes by Elco Heads on the HAMB. Check out the last page of this thread:https://www.jalopyjournal.com/forum...l-i-did-for-my-32.441108/page-6#post-12915542
    Sounds to me like you’re a real scum bag and have been shamelessly ripping off other guys stuff and just ignoring any static raised about it.
    I’m wondering how @Ryan might feel about the situation if he knows about it.
    If it’s all true then I don’t think you should be free to keep posting and promoting your stuff here.
    C69A likes this.
  26. alchemy
    alchemy
    Change the thread title to: Rare Art Sparks Heads Soon to be Available From Australia
  27. Ryan
    Ryan
    ADMINISTRATOR
    I'm just learning about all this ripping shit off stuff... Bummed... I'm gonna attempt to get the other side of the story. If your stuff has been copied/stolen, drop me a line.
    GuyW likes this.
  28. Thought I would give this thread a bump with a new detailed photo of the 'SPARKS' heads from the late 40s, likely '47, scanned from negative. You can see someone ground down the fins o_O:(:mad:
