Technical Anyone here with SBC short water pump AND A/C?
Discussion in 'Traditional Customs' started by gsnort, Apr 18, 2019.
  1. gsnort
    gsnort
    Is there anyone with a small block chevy with a short water pump AND ALSO A/C? If so, how did you do it?
  2. mcsfabrication
    mcsfabrication
  3. buck 32
    buck 32
    from Maryland
    Speedway. Bill's hotrod Brackts
    barebones32, rfraze and gsnort like this.
  4. proartguy
    proartguy
    from Sparks, NV
    Bill’s Hot Rod Parts. Excellent quality.
  5. 57JoeFoMoPar
    57JoeFoMoPar
    I'll second Bill's brackets. The quality is very nice and they don't look cheesy or billety. The downside to them is that the plating is so nice they make some of the cheap brackets I have in my belt drive look really bad and will need to be sent out for better plating. Running a serpentine drive is absolutely out of the question, V-belts only. I'm running a Sanden compressor, short water pump, power steering, and GM 1 wire alternator.
  6. Larry W
    Larry W
    from kansas
    Alan Grove worked for me. Clean and simple.
  7. chargin03
    chargin03
  8. fastcar1953
    fastcar1953
    like the factory done it in the 60s. true-ss-chevy-ii-283-v8-swap-powerglide-auto-factory-ac-brand-new-paint-4.JPG
    427 sleeper, gsnort and Chavezk21 like this.
  9. Daddy_O
    Daddy_O
    As stated by others, Alan Grove.
    little red 50 and gsnort like this.
  10. gsnort
    gsnort
    Wow. Thank you all! I thought I was a goner.
  11. gimpyshotrods
    gimpyshotrods
    Just to reiterate, ALAN GROVE COMPONENTS!
  12. gsnort
    gsnort
    Keith at Alan Grove was very helpful. I forgot to mention in my original post that I also have power steering. No problem, according to Keith. Thanks everyone. Your help was very much appreciated.
  13. fastcar1953
    fastcar1953
    my 64 impala has power steering with 283 and factory offered a/c as a option. pulleys are available. keeping it traditional.
    gsnort likes this.
  14. 56sedandelivery
    56sedandelivery
    Almost everything from Alan Grove spaces the alternator/power steering pump/A-C compressor way too far out to the sides; nothing is compact, and it just looks too "industrial" (JMO). And, there has got to be a lot of "flippity-floppity" action with those L-O-N-G drive belts. I scoured that auction site we all know and love for brackets, and although short water pump stuff is harder to find, I found it there, and bought it. My DD truck is a collage of parts I've had on hand, and it's almost 40 years old now (I won't mention the actual years-rules and all). I figure the truck will outlive me! And I get "nice truck" from people all the time, and it's nothing special.
    I am Butch/56sedandelivery.
    gsnort and Russco like this.
  15. lonejacklarry
    lonejacklarry
    Another vote for Bill's Hot Rod parts. He has various layouts for narrow or low engine compartments.
    He even sends along prospective belt sizes so you are not completely in the dark, It avoids the working with rope or shoe strings.
    gsnort and rfraze like this.
  16. bob b.
    bob b.
    from peoria az.
    swap meet
    gsnort likes this.
  17. David Gersic
    David Gersic
    from DeKalb, IL
    I have the Alan Grove set (100R - A.C. / 200L - Alt.). Nice parts, very well made and solid. I have the early Corvette short water pump.
    Both come with a bunch of spacers and washers. You’ll need them to adjust where the brackets end up on your engine. Having to thread the bolts through a stack of spacers and washers annoyed me, so once I decided what needed to go where, I welded the spacers and washers to the brackets. Grind smooth and paint.
    The A/C bracket
    says that it clears tall valve covers, and that’s true, it does, but only if you put the valve cover on first, then the bracket. There isn’t enough clearance to get the valve cover on/off.
    There are two mounting holes on the top, where the intake bolts hold them. I cut the rear hole off, along with some of the bracket. Now I can get the valve cover on/off, just barely, without having to disturb the intake bolts.
    OFT and gsnort like this.
  18. Russco
    Russco
    from Central IL
    81A2B40E-99F3-48B2-822E-9FC91474B8D0.jpeg CED05D81-0F0E-4455-9061-4D48718CDBCA.jpeg 21179EC2-AF07-479D-8769-061E1C4D5453.jpeg F078CE88-D56E-41D3-92C3-8F1542A2BFC0.jpeg
    I did a bunch of checking around and went with Bill’s set up on my 40. I can easily take the valve covers off and the alt and compressor are not hanging way out the side. For my application this was the best option yours may be different.
    OFT, gsnort and rfraze like this.
  19. Pooch
    Pooch
    from Oklahoma
    Bills
    gsnort likes this.
  20. 56sedandelivery
    56sedandelivery
    Looks like the same bracket I bought off of E-Bay, only probably a little cheaper and un-named parts. I still have't gotten around to installing the A/C in my DD Truck; maybe one of these days when the heat gets unbearable around here. I am Butch/56sedandelivery.
    gsnort likes this.
  21. fiftyv8
    fiftyv8
    from CO & WA
    I owned a 1967 GMC pickup about 10 years ago with a 327 SBC engine plus a/c and I broke down once on the highway near Ritzville WA with a water pump failure.
    When it came to getting a replacement I was surprised to learn that there is not only a long and short water pump for a SBC engine but also an intermediate pump which the GMC was running.
    I am not sure how common they were, but it may and an extra dimension to your thinking should you need to consider another alternative...
    gsnort likes this.
  22. David Gersic
    David Gersic
    from DeKalb, IL
    I dunno. Any closer to the center and I’d be hitting the radiator hose.
    little red 50, OFT and gsnort like this.
  23. 56sedandelivery
    56sedandelivery
    ^^^Very nice setup^^^. Looking at the Alan Grove site, when I was looking for options, almost everything listed had large, spaced out brackets, and really long drive belts. As I said in my statement, "ALMOST EVERYTHING" from Alan Grove Components spaces the alternator/power steering pump/A-C compressor way too far out to the sides. Almost everything, and not everything; frankly, in looking at the site, it does't make the parts well thought out, although yours most definitely is. I can't say anything more than that. I am Butch/56sedandelivery.
    David Gersic and gsnort like this.
  24. David Gersic
    David Gersic
    from DeKalb, IL
    A lot of them do look wide. Clearing low hoods with wide engine compartments? My 37 doesn’t have a lot of room up front, but it all does fit in there.
    gsnort likes this.
  25. olscrounger
    olscrounger
    Have done a lot of 40's with ac and short pump small block-always use Bill's HotRod brackets-just did a 39 woody the same setup.. On trifives I have used both Bill's and Alan Grove brackets
    gsnort likes this.
  26. donno
    donno
    How in the pluturbian hell did you find parts in Rittzville? Or did they come from Spokane or Moses Hole.?
    gsnort likes this.
  27. fiftyv8
    fiftyv8
    from CO & WA
    It ended up being an overnight stay and was great.
    I found myself staying across the road in a Motel from the railroad yards and in one of the rail sheds was the Ritzville Old Car guys meeting, which I was invited to attend, I felt very welcome and had a great night there.
    The tow truck guy who hauled me in from the highway tried to get me repaired in the local garage, but the guy there was less than helpful, so the tow truck guy ended up ordering my parts and installing them the next day.
    He had all the tools and a decent meal and couple of bucks covered his needs.
    What a guy and we both enjoyed fooling around with the water pump swap.
    Even the local Motel folks were great and very accommodating.
    I can not speak highly enough about this small town and its friendly attitude.
    I do intend to revisit this town one day when I am in the area.
    Obviously, it is off the highway and most folks just drive right on by as I had intended, but a turn of fate saw me towed in and it was a good an experience as one could hope for considering I had broken down...
    So remember the name Ritzville WA not too far from Spokane.
    Oh and the burgers were pretty darn good as well...
  28. buck 32
    buck 32
    from Maryland
    20170122_110743.jpg Bill's Brackets
    gsnort likes this.
  29. MMM1693
    MMM1693
    I used the Bills bracket system in my 48 with 327 short pump and early heads and both alt and a/c were mounted inboard like Dave's
    gsnort likes this.
