  1. BadAPP13
    BadAPP13
  2. straykatkustoms
    straykatkustoms
    That is one bad Ford!
    Stebo27, biggeorge, 54delray and 3 others like this.
  3. BadAPP13
    BadAPP13
    Thanks. I am pretty fond of her. :D 20190416_200423.jpg 20190416_200455.jpg
    Stebo27, 1947knuck, brEad and 11 others like this.
  4. mgtstumpy
    mgtstumpy
    Barn find, homemade Studebaker fastback that was posted on other HAMB threads.
    Local GM Holden converted into a convertible using Vauxhall Vagabond parts. These were only produced in 4 door sedans, panel van (Sedan delivery) or utes; no wagons, 2 door pillared or pillarless sedans, convertibles or hardtops. Lots of work to make it look OEM. An interstate restorer friend has a similar car. Being a unibody there was significant under strengthening, utes used a full frame similar to modern subframe connectors
    Stebo27, 1947knuck, brEad and 8 others like this.
  5. straykatkustoms
    straykatkustoms
  6. straykatkustoms
    straykatkustoms
  7. I really dig the mild custom work on that 56 Chevy.
  8. wicarnut
    wicarnut
  9. wicarnut
    wicarnut
  10. AChopped1950ford
    AChopped1950ford
    54delray and chryslerfan55 like this.
  11. straykatkustoms
    straykatkustoms
    They are kustom cut outs on the top part of a '52 Caddy bumper. Used a 48 Chevy taillights with a red plexiglass covers. Had to end up using LED's so it was bright enough to shine through the plexiglass. Thanks for the kind words.
  12. AChopped1950ford
    AChopped1950ford
    Ok , I think I have it, you used the part of the bumper between under the tail light and top of bumper, then cut out for your lens ? am I correct ? very cool idea. Do you have and pictures of the build process I can see ?
    chryslerfan55, 54delray and OG lil E like this.
  13. @37hotrod here are couple pics of your Merc. First two pics are the Mid Century Mercury club show Kenosha, WI, June '83. You can see the MCMC plaque hanging off the rear truly being a drag plaque.
    Next pic is also the Mid Century Merc club show, Kenosha but in May of '90
  14. wicarnut
    wicarnut
  15. straykatkustoms
    straykatkustoms
  16. straykatkustoms
    straykatkustoms
  17. 'Mo
    'Mo
    Jimmy Summers' '40 Merc
    (Photo: Donn Lowe)
    (Below) Hand-made grille is a work of Art!
    Note inverted side cove, two piece windshield.
  18. 'Mo
    'Mo
    Early Forties Custom. Almost certainly by Frank Kurtis.
    (tagged as a 1933 Plymouth roadster on the Old Motor)
    Frank Kurtis....
    (CCC)
    1947knuck, BigO, biggeorge and 13 others like this.
  19. AChopped1950ford
    AChopped1950ford
  20. AChopped1950ford
    AChopped1950ford
  21. wicarnut
    wicarnut
  22. mgtstumpy
    mgtstumpy
  23. @drdave Thanks! You are the man.
    drdave likes this.
  24. wicarnut
    wicarnut
  25. wicarnut
    wicarnut
  26. wicarnut
    wicarnut
  27. wicarnut
    wicarnut
  28. Moriarity
    Moriarity
    SUPER MODERATOR
  29. ramblin dan
    ramblin dan
