Technical Best progressive dual quad linkage??
Discussion in 'The Hokey Ass Message Board' started by 34Larry, Apr 14, 2019.
  1. 34Larry
    34Larry
    I'm installing new Edelebrock dual quads (if they ever get here). The linkage I have been running looks to be of sixties or seventies vintage. It works just fine and I planned on still using it but then I thought there is better out there and so was wondering what advise I could get from the real users and experts on this, not advertising hype from the builders of such. So any suggestions and help is of course really appreciated. Edelebrocks looks pretty nice, but there are others that I don't know about out there also.
    I'll include a shot here of what I have been running, (don't laugh it seems to work just fine, but lives in a time warp for sure.)
    Deuces likes this.
  2. egads
    egads
    What's wrong with straight linkage? Have done several and they run great. ( Thanks to Carbking's website )
    LINKAGE SETUPS - STREET
    There are basically two styles of linkage: (A) solid, and (B) progressive.
    Solid linkage has all carburetors operating simultaneously, while progressive linkage utilizes a “primary” carburetor which functions all of the time, and one or more “secondary” carburetors that do not function until certain criteria or met. This criteria may be: (A) a certain RPM, (B) a certain opening of the primary carburetor throttle, or (C) a certain value of engine vacuum.
    And the intake manifold MAY REQUIRE solid linkage. To run progressive linkage, there MUST be equalization ports connecting the plenums sufficiently large to feed the cylinders not directly connected to the plenum of the primary carburetor(s).
    This selection will cause as many arguments as the brand of carburetors used (later). FOR BEST STREET PERFORMANCE, VERY DIFFICULT TO BEAT SOLID LINKAGE!
    Historically, the first (I think) progressive linkage setup was the 1941 Buick compound carburetion. Because of the lack of normal driving performance and low fuel economy, many (most?) of these compound carburetion systems were removed, and replaced with single carb setups. And in fact, Buick totally discontinued the compound carburetion after only two years.
    Fast forward to the mid-1950’s and the horsepower wars, plus the emergence of local dragstrips throughout the country. The racing sanctioning bodies often would allow internal engine modifications (camshaft, compression, etc.) but REQUIRE the use of the original carburetor(s). Thus the car manufacturers would offer twin 4-barrel setups with progressive linkage so that they could use carburetors THAT WERE TOO LARGE FOR NORMAL DRIVING. During normal street use, the engine would run only on the primary carb, and engage the secondary carb only under “spirited” street driving; BUT the larger carbs were present to provide sufficient airflow for engine modifications of larger camshafts, increased compression, etc. Street drivability with progressive linkage will never be as crisp as using solid linkage.
    swade41 likes this.
  3. mrhp
    mrhp
    from MICHIGAN
    I have tried both, and straight linkage is more responsive by far. If tuned properly just as good on fuel.
    swade41 and egads like this.
  4. carbking
    carbking
    Correctly SELECT and tune the carbs, and straight is better on fuel.
    Far more important than straight or progressive linkage is the selection of the carburetors.
    Jon.
    egads likes this.
  5. wvenfield
    wvenfield
    I see nothing wrong with the set up as is. Simple, easy and it works.
  6. 4speed411
    4speed411
    Happy with the linkage Edelbrock sells to go with their carbs IMG_20190314_192710.jpg
    Deuces likes this.
  7. egads
    egads
    I did not say there is anything "wrong" with his current setup, just another, and cheaper, way to do it.
  8. lostone
    lostone
    from kansas
    I agree with above, there's nothing wrong with what you have now.
    To me it fits the style of the old hemi and carbs.
  9. buck 32
    buck 32
    from Maryland
    I made my own. I've run progressive and solid. If the car is light enough and tuned right you can't beat solid.
  10. egads
    egads
    two two's running solid linkage [​IMG]
    Deuces likes this.
  11. jimmy six
    jimmy six
    Made mine out of some Ford FE and the rest? Not too available for a Y-Block automatic foot feed. image.jpeg
    Deuces likes this.
  12. G-son
    G-son
    from Sweden
    If you want a more progressive control of the throttle even on a straight linkage you could put a progressive cam for the cable on the carb. It has a large radius where the cable lies at small throttle openings = a small cable movement turns the throttle shaft a little, while the "full throttle area" of the cam has a smaller diameter = the same amount of wire pull gives a bigger change in how much the shaft turns.
    Gives you more precise control on small throttle openings, without causing you to have to move the pedal very long to get all the way from idle to full throttle.
    Deuces and jimmy six like this.
  13. 34Larry
    34Larry
    Ah shiiiiiit!!!!!!!!!!!!!!!!!!!! I answered with a long post about how much I appreciated everyone who answered this, did a lot of research on the carbs, intake, suppliers, and decided to stay with what I have, went to post it, and wasn't log in. Went to log in and blew the whole post. So thanks again everone, at least my research gave me a great education
    Deuces, egads and wvenfield like this.
  14. G-son
    G-son
    from Sweden
    Ctrl-A followed by ctrl-C are great keyboard commands on sites that does that, after you write the text but before trying to post it. (First one marks the entire text, second copies it, if you lose it you just paste it again using ctrl-V.)
  15. robracer1
    robracer1
    With the Edelbrock 2x4 linkage check the Heim or Rod end joints if there is a plastic insert between the casing and the ball swivel and your engine overheats for a period of time the plastic will warp and your throttle will stick and you will have to blip the gas pedal for it to go to idle.
    From then after when your engine warms up on warm days it will stick on cool to cold day not as bad, the fix are new Heim joints the old style metal to metal, It took me 6 mouths to figure out and it was no fun going anything over 30 mph or faster and taking foot off gas and the sucker keeps going
  16. bchctybob
    bchctybob
    I'm with Buck. The Edelbrock linkage works nice but is bulky and just doesn't look right on early style cars. After years of running progressive linkage I'm becoming a Carbking convert. After some tinkering, my roadster responded well to direct linkage. My Olds 324 will get 2 x 4 with direct linkage. A piece of stainless rod, two nice Heim joints and some nice bolts, what could be simpler.
    buck 32, Shadow Creek and egads like this.
  17. Blues4U
    Blues4U
    from So Cal
    So, correct me if I'm wrong, but if making the transition from progressive to solid linkage, both carbs need the idle circuit and air/fuel adjustment screws, right?
  18. jimmy six
    jimmy six
    Yes.... I idle on both just like the 245 & 270 hp SBC's and like them at about 1/2 throttle on the rear carb the front comes in and has a much quicker ratio making both wide open when the foot feed hits the carpet.. It has been working fine for almost 5 years....
    collector, jnaki and Shadow Creek like this.
  19. carbking
    carbking
    If one uses straight linkage, VERY EASY to make your own.
    If one uses progressive linkage, fairly easy to make your own.
    Much of the enjoyment of owning and modifying vehicles is doing the work oneself.
    Jon
  20. 34Larry
    34Larry
    If, you'll excuse my ignorance, Heim joints? (I seem to say that a lot these days, turning 80 this Friday and I use that excuse a lot also), what is Heim joint? Pic please.
    egads likes this.
  21. egads
    egads
    These little thingy's[​IMG]
    seb fontana likes this.
  22. robracer1
    robracer1
    Larry its also called a rod end bearing
    again if your joints have a plastic insert, throw them away it is very DANGEROUS when you are not expecting your throttle to stick
    got new one's at ACE is the place.
    egads likes this.
  23. I have three cars with 2x4 setups and all with straight one to one linkage, all with heim ends and brass bushings. 20190417_004653.jpg
  24. 34Larry
    34Larry
    Oh I have always known these as rod end bearings. Thanks
    egads likes this.
