Technical Anyone have pics of a SBC with tripower and a water pump riser ?
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Apr 10, 2019.
  1. Dino 64
    Dino 64
    from Virginia
    Title pretty much says it all !
    Thanks guys
  2. DDDenny
  3. Dino 64
    Dino 64
    from Virginia
    Thanks, that should keep me busy;)
  4. Dino 64
    Dino 64
    from Virginia
    Thanks but it’s kinda hard to see
  5. 48stude
    48stude
    What are you specifically wanting to see?
  6. Dino 64
    Dino 64
    from Virginia
    That ! Wow, beautiful job. I was concerned it would hide the tripower set, but it doesn’t.
    Thanks again for your reply
    jetnow1, 48stude and lothiandon1940 like this.
  7. billthx138
    billthx138
  8. Dino 64
    Dino 64
    from Virginia
    Thanks, looks great!^^^^^^^^
    lothiandon1940 likes this.
  9. Beautiful!
    Dino 64 likes this.
  10. Great examples shown...Good job(s)..... BUT- Let's ask a Q about having a slightly, or if not a warmed up engine- And I'm not referring to temperature....Like as we'de say "radical", with cam/compression.....
    How would/does the 6 pump do? I don't have this set up, but curious?
  11. fordflambe
    fordflambe
    You are over thinking it. There are many over-bored, cammed, multi-carb 6-cylinder motors out there that use that pump. Cooling a car is as much about water flow thru the engine and heads and proper T-stat/radiator as HP. If you are thinking of going that way, i suggest you see if Edelbrock or Flow Cooler offers the 6-cylinder pump in their "optimized/updated" version.
    Dont forget, moving the pump higher on the radiator allows you to better utilize the potential of the cooling capabilities of your 30's radiator. It orients the fan where it belongs in relation to the rad-core.
    I'm pushing 350-375 hp in my .060 over 350 and i have never had a problem.
    Dino 64 and lothiandon1940 like this.
  12. Alaska Model A
    Alaska Model A
    No issues with mine getting hot, but had to get a straight thermostat hsg. neck to clear the hose from the pump riser.
  13. wackdaddy
    wackdaddy
  14. deathrowdave
    deathrowdave
    from NKy
    They all look great , but I personally hate a chrome water neck , they will leak sooner or later .
  15. .....I'm with you, Dave. I think the chroming process tends to warp them slightly and you often fight leaks forever. I see where folks pile on the gasket maker to get them to seal and it runs outside the base looking funky. I try to save various housings with different outlet angles in case I need a particular one for a clearance issue. 20190414_065916.jpg
  16. Dino 64
    Dino 64
    from Virginia
    I think I’ll have to change water neck housings, thanks for the info.
  17. DDDenny
    Don
    I kind of have a thing for the factory Chevy hi-perf cast iron thermostat housings, these were used in the mid/late 60's, you won't have a problem with warpage/leaks on these.
    I seem to recall that Dorman makes replacements, not positive.
    I wanted to use one on the 350 in my Suburban but had to make this adapter to change the orientation. I removed the casting number on this one, wish I hadn't as these have become a little valuable to the musclecar restorers.
  18. deathrowdave
    deathrowdave
    from NKy
    A company named EverHot used to make nice cast replacements . I always changed to these on an engine build , never had one issue
