Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    daddio211, OFT and chop job like this.
  2. pennafxu
    pennafxu
    from Kentucky
    Finally after close a a decade I have a bonafide rolling chassis once again...
    [​IMG][​IMG][​IMG]
    LAROKE, daddio211, OFT and 3 others like this.
  3. pennafxu
    pennafxu
    from Kentucky
    A few other shots [​IMG][​IMG][​IMG][​IMG][​IMG]20190405/9893630f81ca144c91f9b68c216fe196.jpg[/IMG][​IMG]-cdn.com/20190405/50843bbc8a94ba5e9666c89e1a3e9e96.jpg[/IMG][​IMG][​IMG]
    patmanta and chop job like this.
  4. 1-SHOT
    1-SHOT
    from Denton
    I would be careful with the rear radius arms, i have seen then them wrap up and fail. Especially without running a torque tube. I would at putting more bracing in them just in case you get a little aggressive driving .
  5. pennafxu
    pennafxu
    from Kentucky
    Yes Sir,
    Thank you for the comment. I’m planning to do a whole lot of bracing on pretty much the whole frame and every gizzard and gut... fish plates, angle bracing, monocoque aluminum roll cage/body... this was just a quick celebratory moment that I can still do this with all that’s going on right now!!
    patmanta and nunattax like this.
  6. 1-SHOT
    1-SHOT
    from Denton
    I love these kind of builds
    pennafxu likes this.
  7. pennafxu
    pennafxu
    from Kentucky
    Setting up the panhard
    Need to cut old tacks...
    Will weld a bracket on the axle housing.
    [​IMG] Cutting off the old tacks
    patmanta likes this.
  8. pennafxu
    pennafxu
    from Kentucky
    [​IMG] smoothing out the brackets
    [​IMG][​IMG]
    Dressing the frame for a good welding result
  9. pennafxu
    pennafxu
    from Kentucky
  10. pennafxu
    pennafxu
    from Kentucky
  11. pennafxu
    pennafxu
    from Kentucky
    patmanta and daddio211 like this.
  12. pennafxu
    pennafxu
    from Kentucky
  13. pennafxu
    pennafxu
    from Kentucky
  14. pennafxu
    pennafxu
    from Kentucky
    patmanta, OFT and daddio211 like this.
  15. pennafxu
    pennafxu
    from Kentucky
    Bolted on the bracket
    Axle housing bracket
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Done for tonight. Need to massage the bracket a little then tack it in.
  16. Blues4U
    Blues4U
    from So Cal
    Panhard should be level
    Paul, patmanta, GuyW and 2 others like this.
  17. daddio211
    daddio211
    Glad to see you're back on this buddy!
    IG: daddio211
    FB: daddio211
  18. Yes, as level as possible, and as long as possible. The angle you have it at now is going to create quite a bind when the rear spring compresses.
  19. pennafxu
    pennafxu
    from Kentucky
    Sir,
    Do you mean horizontally parallel in regards to being even with the axle tube? If so should I lengthen the axle tube bracket or drop the frame bracket. The way it sits now the rear diff makes it difficult to overcome that structure. Should I bend my panhard bar? Any advice is appreciated...
    Whisky
    Sent from my iPhone using H.A.M.B.[​IMG]
    patmanta and Stogy like this.
  20. pennafxu
    pennafxu
    from Kentucky
    Sir,
    When you state as long as possible should I extend the threads on the bar? Please see above post and feel free to comment also...
    Stogy likes this.
  21. pennafxu
    pennafxu
    from Kentucky
    Thanks bro...
  22. Dick Stevens
    Dick Stevens
    The pivot points on both ends should be close to level so that when the suspension moves it doesn't try to force the rear end to move in relation to the frame and body! A bent panhard bar will not achieve this.
    pennafxu and Stogy like this.
  23. nunattax
    nunattax
    from IRELAND
    I suggest move the frame bracket out and lengthen it .lengthen the axle bracket and move it farther out until the panhard bar runs parallel to the axle and clears the spring mount as well, when the axle moves[​IMG]
  24. nunattax
    nunattax
    from IRELAND
  25.
    pennafxu, Blues4U and Stogy like this.
  26. DDDenny
    pennafxu and Tim_with_a_T like this.
  27. goldmountain
    goldmountain
    Started looking at your build when you were polishing the intake and thought it was rather boring, but then looked from the beginning where you started with a T tudor and was hooked. My suggestion is look up MacroMachines Homemade IndyCar on Youtube. The latest episode has him finishing up the wood mockup for the body on his boatail car. Might help give you ideas.
  28. pennafxu
    pennafxu
    from Kentucky
    Boy... after watching that video my panhard set up was way wrong... thanks guys for the help and links! I now need to find a sagitta calculator!
  29. pennafxu
    pennafxu
    from Kentucky
  30. DDDenny
    That is an early attempt Tim tried and it was reccomended he do something different.
    You might want to go back through his build thread and find the final version as it turned out real neat.
