Technical Anyone drilled out their vega box's 2 lower threaded mounting holes??
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Apr 4, 2019.
  1. ...and just mounted the box to the bracket with nuts & bolts? :confused:
    It's a brand new Borgeson vega steering box and P&J mounting bracket welded to a '32 frame.
    The box's two lower mounting holes have 3/8"-16 threaded holes. I ran a tap through them and ran the bolts through a matching die, but the bolts still don't seem to engage and tighten. Instead, it's as if the threads are wobbly & stripped. :(
    Thanks, fellas.
  2. mark latham
    mark latham
    Are the bolts new and are you positive they are 3/8"-16?
    Just Gary likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    OK did some research. 10mm mounting holes is not 3/8" 10mm = 0.393701
  4. Fordors
    Fordors
    What brand of box? OEM Saginaw, or a Borgeson made on the factory tooling that they bought from GM actually has 7/16-14 threads. I can’t speak about the knock off vega’s they could be anything, even metric thread.
    If you really did want to drill out the threads make sure the casting has a flat surface where the nuts or bolt heads will rest, but if it’s a knock off cut your losses and throw it away.
    In looking at a GM Vega box clearance is tight for that but a machine shop could handle it for $$.
    Just Gary, 36-3window and Johnny Gee like this.
  5. 31aford
    31aford
    from az
    are you sure they are 3/8" I have two original boxes and they are 7/16 -14 threads on both of them
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Also 1.5 pitch is (near) equal to 16 threads per inch.
  7. lake_harley
    lake_harley
    X 3 on 7/16"
    Lynn
  8. 19Eddy30
    19Eddy30
    from VA
  9. tim troutman
    tim troutman
  10. WB69
    WB69
    from Kansas
    Yes
  11. lake_harley
    lake_harley
    Just Gary....BTW I too recently bought a Borgeson box for my '31 Model A. I read a lot of threads and comments about various re-pop Vega boxes and to me it sounded like the Borgeson box is a good unit and although not the least expensive out there it got generally good comments. It seemed like the best bang for my $$.
    Lynn
  12. My original vega box takes 7/16 coarse bolts
  13. Ok, guys. I just checked and 7/16"-14 fits MUCH better.:rolleyes:
    I'm feeling pretty stupid right now...:oops:
    I'll use new 7/16"-14 bolts. But if I boogered the threads too badly, guess the fall-back plan will be to drill out the holes like some of you've done.
    Thanks again.
    bct, Dino 64 and Johnny Gee like this.
  14. indyjps
    indyjps
    Thread guage is your friend, $5 and youre set. Glad you got it figured.
  15. Fordors
    Fordors
    Stupid? I’d say you are pretty smart for not falling for cheap is good enough and buying quality instead.
    Dino 64 and Just Gary like this.
  16. X-cpe
    X-cpe
    It isn't stupid until you don't apply the lesson. You were smart enough to realize you had a problem and come to the land of solutions.
