Technical Road Draft Tube Question...
Discussion in 'The Hokey Ass Message Board' started by stillkruzn, Apr 2, 2019.
  1. stillkruzn
    stillkruzn
    from Conway, AR
    Hey guys, got a quick question for you...
    I will admit, I am not really a Chevy guy, but I bought a 36 Chevy 2 dr Sedan that has a '67 283 in it. The road draft tube is still on the back of the block behind the distributor. I do have a PCV valve in one of the valve covers also.
    What is the best way to plug this tube? I know that it would probably be better to remove it completely and plug the block, but in the mean time, what are ways this has been done?
  2. oldiron 440
    oldiron 440
    With out it plugged your probably pulling dirty air into the motor through the draft tube with the PCV hooked up.
    Hollywood-East likes this.
  3. stillkruzn
    stillkruzn
    from Conway, AR
    That's why I am asking how others have plugged it. I know it needs it.
  4. Mine is plugged with a brass freeze plug.
  5. Hollywood-East
    Hollywood-East
    I've seen rubber expansion plug's if you can't get a freeze plug in...
  6. Doublepumper
    Doublepumper
    from WA-OR, USA
    How about one of the rubber expandable freeze plugs? You could plug the end of the tube in place or remove the tube and plug the block. If you do this with a PCV in a valve cover you need to vent the other cover to the air cleaner for cross flow.
    Man, I type slow ;)
  7. Seems to me it would be easier to remove the tube. Put the PCV in place of the tube, and then put a breather where the PCV was. You can do all this without jacking up the car and crawling under it. ;)
    427 sleeper likes this.
  8. There’s a elbow that takes the place of the road draft tube (has the center bolt also). Bolt that on, run an in-line pcv to the carb and ditch the valve cover one. This way you can run solid valve covers.....don’t forget the breather cap for oil fill tube.
    Rich S. and Doublepumper like this.
  9. stillkruzn
    stillkruzn
    from Conway, AR
    Can I run a breather cap on both sides by doing it this way?? This is what’s in the block right now.
  10. Tickety Boo
    Tickety Boo
    from Wisconsin
    Keep that and run an inline pcv to the carburetor, like oldtimer said. ;)
  11. Hold on...That one slipped by me. 67 283 would have a PCV..Not a road draft tube..Back to 63, and '59 in Ca. I think.
    Yep, you're not a Chevy guy. LOL
    jimmy six likes this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    This is one of those "we need photo's thread". Before it becomes a breather here, here and here, oh!, and one more there.
  13. Yes.
    The later blocks had a tube from the valve cover to the air cleaner.
  14. LBH
    LBH
    Do not plug the road draft tube !! Take a piece or 1/2" or 3/4" hose and run it back as far as you want (mine is just before the rear bumper) and install a K & N filter on it. The motor's crankcase needs as source of air at idle, and when you are off idle the PCV valve is closed and the exit route for the blow by is through the road draft tube ..... without it you will be pressurizing the crank case and that is bad ...........
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    This is what a road draft tube really looks like.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Op say's he's running breathers out of the valve covers.
  17. stillkruzn
    stillkruzn
    from Conway, AR
    I fessed up to that right at the beginning. Not afraid to admit it.
