Projects Winter project- half ass 1956 F100
Discussion in 'The Hokey Ass Message Board' started by Chris, Jan 8, 2019.
  1. I got my tie rod and drag link tubes yesterday that my friend Darell made for me. The tie rod end on the steering arm must come in at the top as the tube hits the arm like I thought it would from the bottom. So will heat the arm and bend it down a little. I mocked the front end on it just to see what it would look like. I’m diggin the stance
    68E8B2F5-5FBE-443E-A7EA-C455E62B497F.jpeg 9FEEE22D-785E-40E6-A702-26220A385311.jpeg 21C1FD02-13E9-4E9E-906E-73D6D3A83188.jpeg 6118FA31-0F0D-45C2-A837-533460914500.jpeg F508674B-0C98-4D5B-B6F5-988EECBAA8F8.jpeg
    Stogy, Bandit Billy, dwollam and 8 others like this.
  2. I’m trying to figure out tire sizes. I think I’m going to step out of my comfort zone and run 15” tires...I generally run 16’s on everything. I don’t really know much on 15’s and what sizes generally look like. I had an H78 kicking around I put on it with my Lancer cap. I like it, it’s the height I envisioned. It measures right at 27”, so if I do run 15’s I think I’d run a 6.70 (which is 27.5” tall) up front and a little larger 8.20 in the rear.
    EBB7DBD4-A5C8-4FEB-BE8C-4BD65940FDE7.jpeg 3E05F8E7-4166-4AC5-9C0C-1280EEAB7CB5.jpeg E95D04A1-1434-448B-86C7-93C7D30A1FB2.png 038D648D-E594-424F-AD41-8B3E177EEE66.png
    Gasser 57, Stogy, dwollam and 11 others like this.
  3. catdad49
    catdad49
    It's hard to fill those wheelwells, but that looks plenty good. If you run the 8.20's on the rear it should give it a little bit of a rubber rake.
  4. Yes, I want a slight rake. I do not want it level or nose high at all. This is kind of my target stance, although mine be a hair lower
    UNCLECHET, Gasser 57, Stogy and 12 others like this.
  5. catdad49
    catdad49
    I will Love it!
    Stogy and loudbang like this.
  6. Today I got a lot of mind numbing chores done. Buttoned the front suspension together for good. I did end up heating and bending the steering arm a little and it lines up a lot more parallel with the bottom of the frame. Put the brakes together and got them bled. Fought brake hoses hitting the top of the king pin but finally got it worked out. Radiator seeps so it’s back off. Funny it was fine all last year. Finally tonight I mocked fenders back on it and laid the box on it and pushed it outside. As much as I want to run 15’s I think I’m going to end up the old reliable route of 16’s :D . It has 16’s out back and it looks better to me. It fills the fenders up more. I’ll put a set of decent looking tires and wheel off my other cars on it and see.
    0D5F10A9-43D0-47D9-B8B3-E561AA2C70E1.jpeg 083BAE92-F48A-4741-BCA7-5B40A5ED5DEA.jpeg 14B2A7C7-E937-4A9C-BAF2-1B8985B176ED.jpeg 1E13D068-8CA1-436A-A2C0-140B51809102.jpeg F40A613E-3370-4A6C-8A92-1F7DDD9D5A26.jpeg 92ABC3CB-CB93-4802-A8E8-70428AAF3448.jpeg
  7. OahuEli
    OahuEli
    from Hawaii
    The front wheel looks a lot better centered up. I never did find out why Ford had the wheels further back.
    Baumi and loudbang like this.
  8. willymakeit
    willymakeit
    How much clearance between tie rod and springs. I have a 57 axle with same springs.
  9. willymakeit
    willymakeit
    Nice truck. Read all of the posts. My 56 is close to same build. Only difference is sway bars, cross steer and 302 with truck 4 speed and 3.00 rear.
    Keep posting.
    loudbang and kidcampbell71 like this.
  10. Well shit. I think 16’s it is.
    A531B834-C794-46FC-A8BD-2C47129E5E90.jpeg EA9296FA-E0EE-41F9-A850-4033688139CD.jpeg 870C355E-F2B3-4D36-91E2-E224E3CBED4D.jpeg B8622D3E-272C-4A37-951E-E57D08C02C2E.jpeg
  11. JUNK ROD
    JUNK ROD
  12. the oil soup
    the oil soup
    from Tucson,AZ
    Nice ride!
  13. I am not sure, but can measure. It has plenty of clearance. I am running dropped tie rod ends
  14. dwollam
    dwollam
    Chris, are those red wheels and wide whites 16"? Are the flipper caps 16" too? Where can I get some of those caps and would they work on my 4" and 4 1/2" '40 Ford wheels on my avatar?
    Thanks,
    Dave
  15. They are 16's, and yes those caps are 16's. Old aftermarket caps. Can't help you with finding them, I searched for a long time for them. They are on 4" and 4.5" in these pictures
    Stogy, loudbang and dwollam like this.
  16. dwollam
    dwollam
    Chris, your truck really needs 15's and you need to sell me the 16's! :D
    Dave
  17. Sorry Dave haha! If you knew what I paid for those caps, you may think I was crazy anyways!
    Stogy, loudbang and porkshop like this.
  18. Atwater Mike
    Atwater Mike
    Story from the old monthly Ford newsletters, "Ford Times":
    Sometime in late '52, Ford Motor Co rolled its first F100s out of the door. The Steward motioned for the Porter to make a 'U' turn. When the Porter failed to make the 'U', and stopped to back up, the Steward Pink-sheeted the truck and the next 9 back.
    Production stopped (!) while the line manager went back up the prod line to see where the springs could be changed for a shorter wheelbase...('Set-back front axle has been a 'staple' for trucks all sizes, for maneuverability since late '30s)
    So, the front axles on ALL F100s is 1.25" rearward. I always thought it looked like a mistake, too.
    I read this piece in 1978. I also had moved the front axle forward on my F100 in '72, one of the first mods I made.
    catdad49, Gasser 57, Stogy and 3 others like this.
  19. alchemy
    alchemy
    Now my truck won't make a U turn? That may take some gettin used to.
    Stogy, OahuEli and loudbang like this.
  20. Those 15" Big Ford bolt pattern Ansen 5 spokes I have would look great !:D
    But the 16" look even better ! cool truck...
  21. Rob, are you selling those 5 spokes?
  22. kind of on the fence right now about them. just bought new center caps a few months back. I have those 16 " steel rims I bought from you for wide whites.
  23. Well winter has turned to spring and spring is almost summer lol. But that’s ok with me, I’m giving the 56 a little more love then I originally anticipated. Hopping to get it on the road this year, but with all summers activities I’m not going to try and rush it. I ran into a snafu with the radiator. It was junk as was the spare I had. I searched for one for a month and finally bought a (gasp) new aluminum radiator, I’m not a huge fan, but this one looks decent once I painted it black. So it’s back running. I also put my SW gauges under the dash to help monitor the tire smoker 223
    016671C9-86EB-426F-A3E4-44234469EA58.jpeg F7EAA596-C704-4047-92AB-6E9693181D00.jpeg
  24. How far ahead did you move the axle? And did you move the spring hangers forward or just the axle on the spring pack?
  25. Glad you painted the radiator..so many guys miss that!
  26. I just moved the axle forward, 1.5"
    Stogy, flyin-t and loudbang like this.
  27. You probably forgot about this thread, I know I did. I haven’t touched this truck In about a year. I got to where I needed to start fixing the rust in the floors and enthusiasm Petered out. I bought some other trucks, worked on them, the wheel goes round and round. I even thought about selling this 56, but that would require that I work on it. So it sat. Over this past weekend I looked at it and decided to dig it out. So I got it outside, cleaned all the parts out of it, and cut a bad section of floor out. This truck came with a nice pair of new floor pans, I will trim them to fit and install them. The drivers side is by far the worst side. I need to fix the very bottom edge of the toe board before I start the floor repair. I got the trans tunnel out, which took a lot of drilling the screws that held it in. Scrubbed the whole inside and back in the inner cowl area.
    Hooked the battery up, it cranked a couple times and fired to life. Kind of amazing as it sat so long. So I backed it out the driveway and got a picture with it’s year younger sibling. Hopefully I can keep this momentum going, I kind of forgot all the neat shit I have for this 56....
    6B379279-79AE-4A83-9627-AA31AE0D5AE0.jpeg 1514D4E6-BD8E-44B6-94EE-581AAF89E274.jpeg 05550EEE-CEEF-41BF-98D0-A5947C458DD6.jpeg
  28. jhexide
    jhexide
    looks good,keep at it
  29. I think it was a Type-O from the drafting table. Once in production they just left it instead of admitting they made a mistake.
  30. 60 Special
    60 Special
    from Omaha Ne.
    I think I read somewhere that Ford did it on purpose, to tighten up the turning radius.
