Auctions
LSR PACKAGE - 1928 ROADSTER - B/GR
Discussion in 'Cars For Sale' started by TIME TRAVELLER, Mar 15, 2019.
  1. City: MILLGROVE
    State: International (Australia, Canada, etc...)
    Price: $35,000 US
    1928 FORD B/GR roadster land speed race car # 261
    - Feature car Rod & Custom July 2002 and Canadian Hot Rods January 2011
    - Has run 196 mph at Bonneville
    - Former ECTA record holder at 168 mph
    - SFI 15 fire suit, gloves, boots, brand new Racequip full face helmet SA2015 with Defender
    neck restraint
    - All steel body on 1932 frame
    - Stainless fasteners for most of build
    - Louvered pans flush to frame from bell housing to rear of tranny and from tranny to
    differential
    - New dual aluminum radiators mounted horizontal to the bottom of the frame with 4 electric
    fans
    - 2 batteries mounted in the trunk floor
    - Fresh Buick nailhead motor:
    - 4.25” bore x 3.78 stroke (429 cu in.)
    - Block and heads ground smooth, polished, powdercoated
    - Offset ground crank (.147” stroker)
    - Weaver single stage oil pump, Oberg filter
    - 1” crankshaft girdle
    - Custom 7 qt. oil pan
    - Romac damper
    - Oliver 6.8” rods
    - Diamond pistons, 15.5:1 cr
    - Solid roller cam (.580” lift, duration 266o @ .050”)
    - 11” aluminum flywheel, ceramic clutch, custom scattershield
    - Owner built mechanical fuel injection
    - 150-0 and 150-1 pumps
    - Nozzles for gas or alcohol
    - All ARP bolts & studs
    - Heads with 1.94”/1.5” stainless valves with 7/32” stems, 1.700” valve height, aluminum
    roller rockers, 5/16” Smith Bros. pushrods
    - 2 Muncie M20 transmissions:
    - One with all 4 gears, other one with 3rd and 4th only (Bonneville)
    - Chev 10 bolt rearend (ratios 2.14, 2.29, 2.41, 2.56), racing axles-
    - Wildwood calipers with 12” rotors,
    - 1 set stainless zoomies, 1 set tuned stepped headers with merge collectors
    - Goodyear #1961 front runners, 1 pair M/T ET street radials 275/60x15 for asphalt, all with
    Moon discs
    - Chassis Engineering 4” drop front axle, narrowed 4”
    - Parachute, 2 x 5lb Halon and 1 x 5lb Cold Fire bottles
    TRAILER
    2013 Streamline 16 foot “V” nose
    - Like new (1 trip to Bonneville, 2 trips to Wilmingtown, Ohio)
    Go 195 mph for $35,000 US – roadster and trailer! I’m located near Hamilton, Ontario.
    I also have numerous Buick nailhead race engine parts
    Contact: Gary Weldon 20190307_132857.jpg 20190310_171830.jpg PICKUP & ROADSTER AT BONNEVILLE.jpg ROADSTER AT BONNEVILLE-LIGHT.jpg
    Phone: (905) 689-8757 before 10pm EST
    e/Mail: [email protected]
  2. BUMP-THIS IS A GOOD DEAL GUYS!!
    plan9 likes this.
  3. BUMP AGAIN. THE SUBURBAN IS SOLD BUT THE ROADSTER AND TRAILER ARE STILL AVAILABLE - $35,00 US.
  4. Still here. This is a really good deal if you want to go LSR racing with a turn key car.
  5. Bonneville is just around the corner!!
  6. Bonneville is a "go" this summer - here's your ride!
    Marshall Myler likes this.
  7. You still have a chance - bump! Check out Gary's new book, based on his extensive experience with Buick Nailheads.
    "Buick Nailhead: How to Rebuild and Modify 1953-1966" by Gary Weldon, available on Amazon.
