Original 1932 Ford Frame with Pickup Title 1932 Ford original frame. Frame was checked in the frame jig at The Barillaro Speed Emporium and is square. The K-member has never been out of the frame. The center of the rear cross member was replaced with center of another 32 cross member. The front cross member was replaced with an original 32 cross member. It was put in with rivets and tigged for extra strength. It has been painted with epoxy primer. This frame has some pitting. The worst is on the reveal on the passenger side. Structurally the frame is good but it could use some cosmetic work. The title is a signed open title from Ohio that matches the #'s on the frame. $3,000 Call 865-755-7019
