Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. rusty rocket
    rusty rocket
    Got this in the mail today. It's a 1962 Chrysler six cylinder marine tach. I think it will look killer. Sort of breaks my 1950 cut off date. Shhhh don't tell anybody! image.jpg
    Jet96, brad2v, Stogy and 2 others like this.
  2. rusty rocket
    rusty rocket
    LSJUNIPER, Jet96, Tim and 8 others like this.
  3. Dakota Kid
    Dakota Kid
    BigO and jeepsterhemi like this.
  4. atch
    atch
    Probably not something you need to do, but I saw a sprint car that had "THINK!!!" printed in very large letters right above the tach. I'm guessing the car owner was tired of replacing engines.
  5. rusty rocket
    rusty rocket
    Sprint car drivers are a bit off !;) I,m not building this thing to be fast just more of the what the hell is that thing. If it will get me up to 50-60 mph I'll be happy.
    Stogy and jeepsterhemi like this.
  6. plym_46
    plym_46
    from central NY
    Peak HP was pulled at 3600, you can occasionally buzz them up to 4000 but it's a futile excercise. With such a light vehicle it might be easy to get it wound tighter than necessary. Might even give some thought to putting on rev limiter at 3900. You are dealing with a 4 5/8 stroke and quite a heavy piston.
    Atwater Mike likes this.
  7. You planning on putting a speedometer in there, or are you gonna figure that out by the rpm’s?
  8. rusty rocket
    rusty rocket
    Nope no speedo, will figure it out by the tach.
    brEad and jeepsterhemi like this.
  9. great job so far. Keep on keeping on!!!!
    jeepsterhemi likes this.
  10. rusty rocket
    rusty rocket
    image.jpg image.jpg image.jpg Been kicking around the thought of running a front nerf bar. Made a 3/8 rod rudamentry mockup to see what its going to look like. Whats everyones thoughts?
    brad2v, Tim, slv63 and 3 others like this.
  11. I like the idea! Love the grill shell and insert, too!
    Stogy likes this.
  12. phat rat
    phat rat
    With that small a diameter it gets lost in everything else. I think it would be ok larger if you painted the spring clamp parts black
    jebbesen, brad2v, SDhotrod and 2 others like this.
  13. rusty rocket
    rusty rocket
    I will build it out of 3/4 solid stock that I have, just want to see if I like the looks before I spend time building the real thing.
    brad2v, slv63, brEad and 1 other person like this.
  14. raven
    raven
    I think it compliments the front
    t
    Stogy likes this.
  15. afaulk
    afaulk
  16. That nerf will look ( . )( . )
    Jet96 and Stogy like this.
  17. AmishMike
    AmishMike
    U not planning to hit anyone - build from lightweight hollow tube. Love whole build
  18. Stogy
    Stogy
    :rolleyes:...works for me...some inspiration...;)
    @phat rat has a good suggestion with painting the spring bolts and plates to allow the Signature Bar to stand visually unobstructed...
    I also have leveled the top bar close to the top of the spring perch or flush with the tops of the perch bolt heads.
    brad2v, Cosmo49, Peanut 1959 and 2 others like this.
  19. rusty rocket
    rusty rocket
    So I only have to no votes, not that it matters. A buddy thinks it should be higher to protect the radiator like the old race cars. I not to keen on covering the grill.
    Stogy likes this.
  20. rusty rocket
    rusty rocket
    Stogy likes this.
  21. Stogy
    Stogy
    I think it looks great too...You are good at visualizing and creating Aesthetically Cool Vintage Detail...Love the brassy looking shocks...it all really works together...good job Rusty...
  22. Put me on the list of those in favor of it! I agree with Stogy’s suggestion of blacking out the spring bolts, for contrast.
    Stogy likes this.
  23. Stogy
    Stogy
    @phat rat suggested the blacking out I just executed his suggestion in the modded pic...but I'm with you in supporting it though Topolino...;)
  24. phat rat
    phat rat
    Stogys rendition is right on. Go for it. It's certainly a traditional thing
    Stogy likes this.
  25. bct
    bct
    I like it and it would be a fun project.
    Stogy likes this.
  26. I voted “yes”. I also understood that you were using light weight bar just to get a feel for how it would look and planned to make it beefier if you went forward. I’m not sure everyone caught that.
    @Stogy took your idea to the next level!
    Stogy likes this.
  27. rusty rocket
    rusty rocket
    I think so!
    Mmmm ( . )( . ) !!!!!
    Stogy, patmanta and cactus1 like this.
  28. rgdavid
    rgdavid
    A no vote from here,
    Doesnt go with the rear of the body and takes away the "lightness" of the front, looses the charm of seeing the front spring bracket.
  29. rwrj
    rwrj
    from SW Ga
    I like it. What if the top bar matched the curvature of the spring?
  30. Stogy
    Stogy
    I think in reality just about every angle you look at this front end the spring bracketry will be very visible and selectively blacked out it all still talks business.
    :rolleyes:...Those were kind of common it seems back in the day...Higher Yes but beefy and prominently proud and the back...I can't see it...
    Credit to Photographer, Owner
    46international and Cosmo49 like this.
