They almost look like clearance lights from an 18 wheeler. Sent from my SM-G955U using The H.A.M.B. mobile app
1946-48 Olds 66 or 76/8 series, same my 46 sedanette Sent from my SM-G950F using The H.A.M.B. mobile app
Yep I was just getting ready to answer! Didn’t they use them in 1942 as well? Sent from my iPhone using The H.A.M.B. mobile app
Very similar, the ones I've seen have small raised pressings in the edges however for the purpose of the exercise, 1942 is in the mix
They are 42 to 47 Olds taillights. 48 changed. As a kid, I was impressed with Jim Travis' yellow 29 roadster with this setup. When I built my roadster, I looked for a good set for my 32. It took 8 pair to get 2 undamaged frames. I checked an old junk yard once and the owner said " I don't have any more. Totem hot rodders bought them up years ago!". If you find a pair, get the bulb sockets also. They are different and nothing modern will fit.
I like them, they fit the bottom panel on a model A just right. And they are not the same old teardrop 39 ford lights that everyone has. Sent from my iPhone using The H.A.M.B. mobile app
