Technical Spline Cutting (Moser says no)
Discussion in 'Traditional Hot Rods' started by JT1930, Mar 18, 2019.
  1. JT1930
    JT1930
    HAMB’ers who else does spline cutting. I need my f150 trans main shaft turned and milled to my Model A 6 spline. Moser engineering told me they can’t do this but others have had it done by them in the past.
    8F3338BC-0C4F-4BB9-AE08-434D3BD88840.jpeg A893D0EC-3846-46F6-B0F6-93D6FD071657.jpeg
  2. Mr48chev
    The shaft may be hardened to the point where it isn't productive to turn it down and machine new splines. I've seen a few pieces off industrial equipmemt that were that way when I sent them in to be worked on and the shop said that the steel had been hardened to the point that they couldn't machine it.
    If it is just something they don't want to deal with though a good job shop machine shop should be able to handle it.
    rpm56 likes this.
  3. JT1930
    JT1930
    Mr 48. I see. I’m going to a industrial machine shop today and see what they can do. They’ll be turning my model A flywheel down so I’ll give them a try.
  4. Mr48chev
    It should be pretty much standard procedure if the shaft is machineable.
  5. Beanscoot
    Beanscoot
    When I worked at a transmission shop I learnt the "trick" of roughly removing the hardened surface of the shaft with an angle grinder while the shaft turned slowly in the lathe, then machining.
    I think it was on a TH400 shaft though, maybe the Ford is through hardened?
  6. burl
    burl
    from Minnesota
    Depends on how hard it is.We machine materials up to about 60 rc.Not sure if that piece is hardened through or just case hardened.Makes big difference.Theres ways to machine harder material like edm and grinding we do that as well.
  7. JT1930
    JT1930
    Thanks for the info everyone.
    I did cut it with a cut off wheel and it went fairly easy.
  8. F&J
    F&J
    have you run a hand file on that cut ?
  9. JT1930
    JT1930
    F&J no but I can when I get home.
  10. big john d
    big john d
    from ma
    i have had axles resplined at mitchel drivetrain service on rt 20 off 146 in ma very happy with the end result 15087546502
    JT1930 and kidcampbell71 like this.
  11. F&J
    F&J
    Or if you still have the scrap piece you cut off, try drilling a 3/16 or 1/4 hole in the center of the cut?
    JT1930 and Hnstray like this.
  12. FrozenMerc
    FrozenMerc
    Try JDM Machine in Staples, Minnesota.
    They just cut some tapered internal splines in a pitman arm for a bus (48' Motor Coach, actually) application for the company I work for. I know they also do external splines. They did a very good job.
    kidcampbell71 likes this.
  13. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Cook’s Machine Works, Los Angeles... been doing it for 80 yrs, call Paul or Jim....they could help you out.
    323-268-6571.
  14. Big John D gave you a good source, and it is not that far from you.
    JT1930 likes this.
  15. dreracecar
    dreracecar
    from so-cal
    You mean "COOK's"
    Cyclone Kevin and Atwater Mike like this.
  16. Atwater Mike
    Atwater Mike
    Good machine shop has tooling and tool speed to overcome hard metals...
    Old machine shop had broaching machines and were restricted to some Rockwell bumps.
  17. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Sorry, Fixed it.....Fat thumbs :).
  18. JT1930
    JT1930
    I’d say it’s case hardened. I can drill the inside of the shaft. The outside is a bit harder.
    F&J likes this.
