Technical 4-71 on a 327
Discussion in 'The Hokey Ass Message Board' started by 1twisted1, Mar 17, 2019.
  1. 1twisted1
    1twisted1
    Ok as some might have seen in my other post, I'm the proud new owner of a GMC 471 with Cragar V-belt Drive and SBC Wieand Intake.
    This setup is going into my 52 Chevy build that I was planning on running a 283 in. So now the reason for this post, the 283 block I was planning on using is cracked and not worth fixing.
    How would the 4-71 work on a 327 30over so 331?, My fear is it would be to small for the motor. Should I just find another 283 to use?
  2. The 4-71 was the blower most commonly used on the street way back when. It is more then enough blower for the average small block.
    ottoman, Hombre, Tim and 3 others like this.
  3. 4 x 71 = 284 cu inches. What's the ratio on your drive setup? Sounds like that little sweetheart would be great, driven 1:1 on your street 327!
    61Cruiser, loudbang and 1twisted1 like this.
  4. Deuces
    Deuces
    Spin the blower faster with a smaller blower pulley to gain more boost....
  5. 1twisted1
    1twisted1
    Drive ratio just happen to be 1:1 with my pulley setup. 20190316_173416.jpg
    -Brent-, 61Cruiser, catdad49 and 5 others like this.
  6. AngleDrive
    AngleDrive
    from Florida
    What are you planning to do with this car? Street, drag, both?
  7. 1twisted1
    1twisted1
    Car will be a vintage 50'-60's street car, so only drag racing will be light to light
    61Cruiser, loudbang and Deuces like this.
  8. Fordors
    Fordors
    Is it just the photo, or is the crank pulley a smaller diameter than the blower pulley? It looks like those underdrive the blower. What are diameters of pulleys?
  9. AngleDrive
    AngleDrive
    from Florida
    Ok, combustion chamber size and cam choice plus cubic inches have a direct effect on boost. You are going to be in the 8 to 1 range with your 1 to 1 set up. I'll get my folder out and give you the specs on what I did to my 283 with a similar set up.
  10. AngleDrive
    AngleDrive
    from Florida
    Thought the same thing
  11. Russco
    Russco
    from Central IL
    I ran that exact set up (471 on a 331 SBC weiand intake but with a 2” Gilmer belt instead of the v belt drive you have) for many years. 6% underdriven sometimes then 6% overdriven at others, it ran pretty good, ran on pump gas, was very streetable and a blast to drive.
  12. 1twisted1
    1twisted1
    loudbang and chevy57dude like this.
  13. 1twisted1
    1twisted1
    That sir is 100% BAD ASS!!!!!!! the fact your auto-crossing that bad boy is just flat out COOL!!!!!!!
    continentaljohn and loudbang like this.
  14. Fordors
    Fordors
    The camera might lie, but the tape measure will not.
  15. 1twisted1
    1twisted1
    Well thits build just keeps getting better, went and picked up the motor and 400 bucks and 2hrs later I'm home.
    GOTTA love what I found as a head number
    20190317_201417.jpg 20190317_195938.jpg .
    xsquiden, catdad49, loudbang and 2 others like this.
  16. 1twisted1
    1twisted1
    Thank You Sir, That would be greatly appreciated.
  17. belair
    belair
    Want, want, want. Congrats.
  18. catdad49
    catdad49
    Caprice............? No Way!
  19. 1twisted1
    1twisted1
    Looks to be a nice 327/275 motor from a full size.
    Block
    3858174 - BLOCK CASTING NUMBER.
    E206 - BLOCK CASTING DATE
    F0607HCH - ENGINE ASSEMBLY DATE/SUFFIX CODE
    Heads
    3890462 - HEAD CASTING NUMBER
    F16 - HEAD CASTING DATE
    Deuces and loudbang like this.
  20. J. A. Miller
    J. A. Miller
    from Central NY
    Those are good heads - they came with either 1.94 or 2.02 valves. You can't tell until you measure them. My 327/275 motor had the 1.94s. Great little engine - be greater with that 4-71!
  21. catdad49
    catdad49
    Hey twisted, it's kind of any running joke around here that "any" 327 came out of a Corvette! With the right components and compression ratio this one should serve you well with that 4-71. Good Luck.
    Deuces, loudbang and 1twisted1 like this.
  22. 1twisted1
    1twisted1
    Yup 1.94s and by the looks of it the motors never been apart . Still stock bore & pistons 20190318_154748.jpg 20190318_154417.jpg
  23. Nice score STOCK bore even...….
    Deuces likes this.
  24. I read that on the internet also
    ALL 327's listed was from a Vette...
    If its on the internet it must be true !
    catdad49 and 427 sleeper like this.
  25. lumpy 63
    lumpy 63
    It's been apart for sure because the steel shim head gaskets are long gone...But if it's standard bore it's a great find:cool:
  26. 1twisted1
    1twisted1
    Would these be the gaskets your referring too? 20190319_155507.jpg 20190319_155520.jpg
  27. patsurf
    patsurf
    loudbang and 427 sleeper like this.
  28. 1twisted1
    1twisted1
    Stock as they come. Little under due to carbon. Cylinders 8 & 2
  29. 19Eddy30
    19Eddy30
    from VA
    1-1 set up with 4-71 on 330 cid will be around 5 psi of boost , you will need 850-950 cfm's of carb
    Draw threw blower Like cfm's ,
    your Boost plus static compression ratio under 13-1 you will be ok on pump 93-94 ,
    Its all in how you tune .
    No need to O ring (good fepro gasket#1004) might be 400 gasket , but a felpro wire ring
    Arp bolts or studs
    nor duble key way , small 327 Balancer hub ,belts will probably slip even with 3
    Mild port clean up , those heads are 1.194
    Small cam change ,
    About 32-33 total degrees with 15 -23 degres at idle
    2-1/2- to 2-3/4 inch exhaust.
    I have ran 10-5 forged pistons with 8 pounds boots
    8mm belt ( no slip ) & No blower hub . Cast crank
    Over 20,000 miles .
    On OLD pump formula /blend but not on new blend .
    3,200 pound car 107 mph 1/8 @ 6:60 8 inch wide Radial tire 28 tall 3:55 gear 2,200-2,500 stall
    6,500rpm's
