Customs 1952 Ford F1 Front End Change
Discussion in 'The Hokey Ass Message Board' started by Hank McDonald, Feb 21, 2019.
  1. Hank McDonald
    Hank McDonald
    Hi guys ... can a 1/2 ton 1952 F1 pick up accept the front end from a 3/4 ton 1952 F2 pick up?
    - hood
    - front fenders
    - engine bay panels
    - grille / etc.
    Thanks Hank
  2. bdynpnt
    bdynpnt
    Yes
    Sent from my SM-G965U using The H.A.M.B. mobile app
  3. Hank McDonald
    Hank McDonald
    Thanks - I understand the genders will have a wider wheel arch (potentially enable a bigger wheel diameter). Anything else to be cautious of as I’m about to buy the 3/4 ton front end
  4. Hank McDonald
    Hank McDonald
  5. chopndrop
    chopndrop
    Fenders have larger radius opening, all else is the same.
  6. 41rodderz
    41rodderz
    from Oregon
    Well you were just being politically correct with gender .:p
    RICH B, Texas Webb and King ford like this.
  7. King ford
    King ford
    from 08302
    What gender do you think your frontend " chooses to be ?"!
    slv63 and lothiandon1940 like this.
  8. PoTaToTrUcK
    PoTaToTrUcK
    Here they are side by side, you will need a large profile tile to fill the hole, 70 or 75 aspect ratio tire. the larger hole is over five (5) inches wider and the peak of the radius is taller. Don't forget 'free hats seldom fit'.
    Sent from my iPhone using The H.A.M.B. mobile app[/QUOTE]
    exterminator and barrnone50 like this.
  9. Dino 64
    Dino 64
    from Virginia
    My F1 had one F1 front fender and one F2 front fender. Yup they fit.
    jimgoetz and lothiandon1940 like this.
  10. bobj49f2
    bobj49f2
  11. Hank McDonald
    Hank McDonald
    Awesome response H.A.M.B. guys - comparison side by side is exactly what I needed to see ... appreciate the guidance.
    I have a mustang 5.0 engine in the 52 with a C6 Transmission with B&M shifter. Wondering what rations to have on a 9” rear end.
  12. Dino 64
    Dino 64
    from Virginia
    That would depend on your rear wheel diameter, but if you want a highway cruiser, go with about a 3.0 rear. If you want a quicker take off, go for a lower ratio.
  13. bdynpnt
    bdynpnt
    Or if you want both change out the c6 for an aod and put 3:73 or so gears in the rear
    Dino 64 likes this.
  14. Dino 64
    Dino 64
    from Virginia
    Or a C4, they are much smaller than an AOD or C6
  15. bdynpnt
    bdynpnt
    Point of aod is to have both lower gears for acceleration and to have the overdrive for cruising the C4 doesn't have that
    Dino 64 likes this.
  16. deathrowdave
    deathrowdave
    from NKy
    I was thinking the larger wheel opening started in an F4 and larger truck . F1 and F2 same sheetmetal front fenders . My F1 was a 302 roller engine , with a carb and a C4 with 3.25 gear rear axle . It worked fine for 70K on the clock when I sold it .
  17. bobj49f2
    bobj49f2
    F-1s have their own fenders, front and rear. F-2 through F-6 have the same front fenders.
    Dino 64 likes this.
