Projects 1955 Chevy Southeast Gassers Build
Discussion in 'Traditional Hot Rods' started by Zak Hall, Oct 29, 2017.
  1. Zak Hall
    Zak Hall
    16C38BC5-4E0F-4444-B6E4-1CA016CBFE11.jpeg 25D0020D-7EFE-47A3-903E-596D90BB9EF2.jpeg 64045E6D-C8D9-4F9D-B6DF-00CC50FDBE53.jpeg B8BC0C87-DB77-4760-9B04-5A4FD7303687.jpeg Got the front part of the tunnel rolled and shaped. Popped a couple rivets in it to start fitting the rear straightaway on the tunnel. The tunnel will be put in with dzus fasteners to make it removable. I am loving how the tinwork is turning out. Probably my favorite part of building the car so far.
  2. loudbang
    Super fine job on the tin work.
    enloe, Bowtie Coupe and Zak Hall like this.
  3. Zak Hall
    Zak Hall
    2F0726C7-C244-4F35-A505-A507B63E4DD3.jpeg DB7C150A-4044-426B-8D37-00E4B5421C56.jpeg 50A0D3D5-EF26-4325-95ED-0B87F66E0C5D.jpeg C7E6C293-EEF6-494F-859A-2087E2086B91.jpeg Got the rear piece of the tunnel made up today. Gonna have to pull the drivetrain now so we can get access to put the dzus fasteners in for the tunnel and the tinwork will be pretty much finished other than door panels.
  4. dirty old man
    dirty old man
    Damn nice job, Zak. You have many talents.
  5. Zak Hall
    Zak Hall
    Thanks! I’m still learning but I really enjoy it.
    -Brent-, Bowtie Coupe and loudbang like this.
  6. Zak Hall
    Zak Hall
    6696D6E0-E4D1-4064-8D93-C373547C0B39.jpeg 723DB9DF-6179-4EDF-ACAB-EC6B1D196744.jpeg 09DCFFD3-A716-402B-9A6E-6AAFCA2C2CDD.jpeg 2DD3DF51-F74D-4F47-9A60-9B6291637E39.jpeg E3EDBC9B-5C5B-4EF6-B97E-1C9475A168D1.jpeg 6E2EAECC-E9A1-4398-94B0-FCDB9C223BBB.jpeg Got the tunnel pieces both dzus’d in and finished, got the little box made to clear the clutch fork/linkage, and got the back piece cut out and fitted to the tunnel. Really like the way the tinwork looks.
  7. Zak Hall
    Zak Hall
    F6E9B8E0-E4D9-47BC-A068-448A614E8913.jpeg 0F6F020E-03B9-42EE-8F85-92DF7A8E1129.jpeg 6EF20952-9473-4F08-AEE6-45B6B6DE149B.jpeg A8D5F5DA-9DBA-441B-B0E3-8496FEB3C510.jpeg Got the steering through the firewall and mounted, got the clutch linkage through the firewall and hooked up, and got the master cylinder through the firewall and mounted. Getting ready to pull the drivetrain tomorrow and start running brake lines. Starting to get excited about it.
  8. Zak Hall
    Zak Hall
    6CFA519E-CBA4-4977-9451-4BDDF7A9D07D.jpeg B992AA89-A90E-498B-AEB9-FD7E5D51EAB1.jpeg Got the motor out to clean up and put this aluminum flywheel and lighter pressure plate on it. Also had to get access to add a couple more dzus fasteners.
  9. Zak Hall
    Zak Hall
    99E011FC-7E4C-4E8D-8FE5-F9812869CD40.jpeg A7F03DE7-17A1-41AD-8790-B5DB3DAA9086.jpeg 1DD63DA5-DF6C-405A-B489-D51FCEBEE17C.jpeg 0C08A3F4-F05F-4AEF-B628-1E564B147823.jpeg B894DFD5-16EB-4377-B6DF-835EE450EB1C.jpeg BBFFC165-BDB6-458A-B4C2-27A3A943179D.jpeg AE1B779E-8BE6-4B6C-88D5-165CD1D3F01B.jpeg Got the brake lines ran. Gonna bleed them now and it’ll be one step closer!
  10. 427 sleeper
    427 sleeper
    Beautiful work! You'll be shakin' it down before you know it!
  11. Zak Hall
    Zak Hall
    Thanks! Hopefully March we’ll have weather that will cooperate with us to test!
    Oldioron, loudbang and Bowtie Coupe like this.
  12. Zak Hall
    Zak Hall
    BA4DA869-774C-41CC-B7D6-CDF5C1938BF3.jpeg Got the brakes bled and finished up, and punched some holes in the front engine plate. Gonna finish welding a couple engine tabs and such, and put the engine and transmission back in after I clean up the engine. Hopefully start wiring this weekend maybe.
  13. Zak Hall
    Zak Hall
    968420FF-483D-424E-983B-98326B51F613.jpeg 23D7097F-D1A2-4328-9943-C78916AD5CFE.jpeg 518FB200-6246-4C80-A322-1C27D3B506D7.jpeg 4D4D63EC-89EF-41C8-B787-6A2464E8F4DA.jpeg A42CC3B4-20BB-492A-BCA7-B01D90840522.jpeg 7DF5C605-28E0-466D-BBE4-AAD7732B602E.jpeg Got the front plate finished up. Also changed the tabs, didn’t like the aluminum spacers and added a side tab on each side to help hold the big block. And got the engine, trans, and driveline installed, for hopefully the last time for a while. Got the lightweight aluminum flywheel on too, along with the lighter base pressure, pressure plate. Really excited to see this thing coming together.
    -Brent-, oldiron 440, Baron and 12 others like this.
  14. Zak Hall
    Zak Hall
    C055C1F9-E8F3-46F2-84D8-DE540BE6C07C.jpeg 2EF6C62E-6712-440B-91DD-5D5A14C05F9D.jpeg 1B743BBF-8423-445A-9692-F4B87200E6D9.jpeg CE8A17BC-38B8-403F-BA03-2963B584C0C7.jpeg Starting on the door panels. Gotta cut some aces panels in them for the latches so I can service them without having to remove the whole panel, and then I can rivet the panels in and the tinwork will be pretty much complete.
  15. DDDenny
    Very tidy!
    Zak Hall likes this.
  16. 6sally6
    6sally6
    I would have guessed.....you have done "a little":rolleyes: sheet metal work in your life?!! Nice work....
    6sally6
    Hang'emHigh and Zak Hall like this.
  17. Zak Hall
    Zak Hall
    Dad was a layout man and sheet metal worker for years. He’s teaching me how to do it, and make it look right!
    Baron, jim snow, tonkadawg and 9 others like this.
  18. Zak Hall
    Zak Hall
    7C866380-5D06-4F20-B0FC-CC38A67BDC14.jpeg 26439F7C-6C23-4754-89FD-C2634D5561E8.jpeg 3E930F4D-F711-43CD-8A0E-C02005A8D179.jpeg 51D9AB2D-1259-4C23-B567-672822FDC6DE.jpeg BE4CA53F-01B3-41EB-80DE-91D8211F118A.jpeg 4337249B-8D90-41C1-9814-DE19613A15E8.jpeg
    Got the outlets changed on the radiator to the bigger ones for a Chevy, got the front strap welded on, and painted it all SEGA legal black. Radiator is done and ready to be hooked up. Also got the access panels cut in the passenger side door panel and got it riveted in today too. Gonna make the drivers side panel tomorrow and get it in. List is getting shorter and shorter. Seems like the car is 90% finished, and I only have 50% left to do.
    -Brent-, oldiron 440, Baron and 15 others like this.
  19. Zak Hall
    Zak Hall
    197B405F-EF46-45C2-B535-0FC59E58CF03.jpeg FA309A0F-7FBB-4C9B-A3FE-9FF41DAA0569.jpeg 25184C65-E80E-4F16-B6BF-84D5D6472DBC.jpeg 1BD83031-EA02-465E-B6F9-54C331E73611.jpeg 4C466186-8905-4E49-8119-1058DA340713.jpeg E3722A09-89DF-4FC9-B67A-12596C66D532.jpeg D5AB9BD0-C9B2-4D51-9E76-F0BCB56D89A3.jpeg
    Spent the day finishing up the door panels. Put the access panels in, got the interior door latch (release) finished up, and got inside door pull handles put on. Other than putting the seat covers on and mounting the gauges, the interior is done.
  20. Butch M
    Butch M
  21. saltflats
    saltflats
    from Missouri
    Looks like a nice office.
  22. loudbang
    Good planning to put in those access panels. :)
    enloe, Hombre, Zak Hall and 3 others like this.
  23. Zak Hall
    Zak Hall
    D562EB20-F1D1-4B9E-A0E1-5563A9ECFD44.jpeg 6F2A96F5-55B9-4621-8052-81906EAB015D.jpeg The last pieces of tinwork are in. Put panels in the trunk floor to give it a finished look and keep from trapping so much air in the trunk. Still have to put the dzus fasteners in so I can remove the panels, but this is the finished look.
  24. dirty old man
    dirty old man
    Nice looking tin work Zak. As someone who has done a bit of this " back inna day" on dirt oval cars, I can really appreciate your fine workmanship here.
  25. greaser
    greaser
  26. loudbang
    Very CLEAN looking installation nice work. :)
    Zak Hall and Bowtie Coupe like this.
  27. Zak Hall
    Zak Hall
    D7518357-3AB8-4396-A437-AF4BAA580B0B.jpeg Tune in February 27th at 10pm Eastern time to watch the premier of The Southeast Gassers on Discovery Channel! It’s going to be a show you won’t want to miss!
    Oldioron, tonkadawg, loudbang and 4 others like this.
  28. Zak Hall
    Zak Hall
    71182EB8-CC8D-4E39-8242-D2F7FBF1F623.jpeg B9D839A5-C17F-425D-B624-AA32E8391C02.jpeg 53B726AD-6C6A-4FB5-A48D-152428F5F94A.jpeg FD1DC2E0-8966-45FF-BAA2-B99496DD2B9C.jpeg 03F2AE75-D1FA-42FC-9CAF-D4A98EAFCC7D.jpeg The right weight rear springs came in today so I put them in. Now it’s down more in the back and looks right. Also got the tach and other gauges mounted.
  29. 56sedandelivery
    56sedandelivery
    Looks real nice! What's in the upper left, at the top of the A-pillar, by the roll cage? I've got a name for the car; The Garden Gnome; every time I see your Dad, that's what he looks like to me (not meant to offend!). How about painting the roof so it looks like a Confederate flag? I look back on page one of this thread, and what the car looks like now; HUGE transition; you do good work. Keep up, and keep posting. I am Butch/56sedandelivery.
  30. Butch M
    Butch M
    looks real cool
