Projects 3rd Hand Scrap.
Discussion in 'Traditional Hot Rods' started by Internet, Jan 29, 2017.
  1. Richard, if he wants to run a folding top, I have a buddy here in D that would be happy to lend his templates and measurements for the frame. He did an outstanding job of it and it just looks right on his A rdstr P/U..
  2. Atwater Mike
    Atwater Mike
    I love 'old, cast-off parts'...as they are called by Street Rodders.
    A forging trumps a billet carving. Also trumps a casting. Especially one from the far East.
    Old stamped steel makes wonderful 'shapes'.
    A generous friend with a huge scrap pile is a friend indeed.
    King ford likes this.
  3. sloppy jalopies
    sloppy jalopies
    I now save all the usable sheetmetal cut offs...
    but nowadays I label them with a paint marker before i throw them onto the pile so I can remember what I cut it off from ...
    TBone69, koolkemp and bct like this.
  4. dumprat
    dumprat
    from b.c.
    No more updates on this?
  5. colineunson
    colineunson
    from Victoria
  6. colineunson
    colineunson
    from Victoria
    Truck has been on the road for a while. It made it out of the basement, was put togeather and registered.
    I just bought this truck (from the original builder) and plan to do a few changes to it as i go namely:
    Get the top done in black canvas
    I got 30-31 headlights to replace the small ones on there currently.
    Also got this hood i plan on running the top only.
    Other plans include some new rear tires (blackwalls)
    And other stuff as i go!
    Also: that door is the same door posted earlier but from the inside :)
    Squablow, brEad, Tim and 1 other person like this.
  7. 66gmc
    66gmc
    It's always good to see cast off junk transformed into a functional vehicle, but it's even better when it turns out as neat as your truck. Nice work!
    Sent from my SM-G950W using The H.A.M.B. mobile app
  8. 6sally6
    6sally6
    Your 'scrap-pile' makes mine look like a..... 'junk pile'! Nice look'in so far.
    Get well soon,
    6sally6
  9. rusty valley
    rusty valley
    with the truck tranny you should have a pto for a winch and make a wrecker boom. every growing boy should have a tow truck
  10. colineunson
    colineunson
    from Victoria
    Well shoot, had a cold snap
    Up here and popped a frost plug, also froze the water pump solid! A torch, new plug and some coolant later and i nursed it home!
    Going to swap out all the frost plugs to be safe!
  11. colineunson
    colineunson
    from Victoria
    Much needed nice A buckets added, plan to paint the hood top tomorrow and doing some other odds and ends
    Tim likes this.
  12. Tim
    Tim
    from KCMO
    Way better with those lights! Cool little rig.
    I’d thought about running a granny low like a reverse overdrive.
    Put highway friendly gears in the rear and start it in second, when you want to act like you’ve got 4:10’s in it at the stop light grudge match you stick it down into first
  13. colineunson
    colineunson
    from Victoria
    Exaclty how this one is driven hah!
    Latigo and Tim like this.
  14. Tim
    Tim
    from KCMO
  15. Like what you're doing to the RPU to make it a driven Ol' Skool hotrod. Too bad about the frozen coolant but then again Stuff Happens and you got off easy. Look forward to a ride when you get it back on the road and the weather warms up. Pinstripes add character LOL QuU2N5r6T8KfQHVYVXDiUg.jpg
  16. 41rodderz
    41rodderz
    from Oregon
    Inspirational:cool:. Now I have to go rub my chin and wonder if '32 Ford front fenders will work with a '34 International hood.:confused:. Add my gold metal flake steering wheel..... mmmmm the possibilities.
    blackjack and King ford like this.
  17. colineunson
    colineunson
    from Victoria
    CEDAEADB-7D19-4C32-9C76-C7A5B36F36A9.jpeg 22EC11AC-3C0D-4D2E-BBD7-5154A829B655.jpeg D8DAC13E-6B94-4389-BA91-66DA75878F30.jpeg 30C881EE-299E-4A9A-97F3-2A552344FDAF.jpeg More updates! Painted the hood and added an old ford wheel cap as a grill emblem i had lying around.
    Starting to take shape:)
    Tim likes this.
  18. King ford
    King ford
    from 08302
    Beer is proof GOD loves us and wants us to be happy!..( Benjamin Franklin)! Cool car built the " traditional way" ( with whatever is available cheap!) think I might have to upgrade the flex pipe headers at some point...
  19. colineunson
    colineunson
    from Victoria
    Small update:
    Got lights wired up!
    Tomorrow i will be pulling the motor and getting all the leaks taken care of! And then i will be wrapping the headers, that should be the next update stay tuned
    Tim likes this.
  20. manyolcars
    manyolcars
    1st post, 5th picture down. How wide is the rear axle or maybe I should ask which rear spring is that? My shackles are up against the backing plate
  21. colineunson
    colineunson
    from Victoria
    Its wide, wouldnt work on any shortened rear end.
  22. Headlights make it, especially with actual light coming out of them. Take the valve covers off and see how much crud there is.
  23. colineunson
    colineunson
    from Victoria
    Wanted to trace some leaks...
  24. colineunson
    colineunson
    from Victoria
    Then it escalated quickly...which turned into ordering a new clutch, surface flywheel, new ring gear, thermostat and housing gakset, rear main seal, pan seal, basically resealing everything.
    Also fan belt was too long wearing a groove in the lower rad hose so got a shorter fan belt, more of a bend on the hose (will post pics when its back together) 3EFF5D5E-1DFD-4861-9864-E47C05485163.jpeg 46E25DA9-003C-4A2E-A36B-4A97340E4857.jpeg 78783B22-C1B9-4C61-A162-8F8E282DAF1D.jpeg D70AFD88-656F-4469-B747-63E429EF33E7.jpeg 18678BB2-2460-456D-AA80-C3989B9D7862.jpeg 5027E1FE-0CF9-4613-8578-779649414CB4.jpeg D83F7D6D-6250-404F-8A1C-A23585F9DADA.jpeg 71A2E5FC-8ABC-4C9B-BCEA-5373795F82F0.jpeg 10169724-7070-484D-B384-86A56BC800E7.jpeg
    Also a shot of the old clutch up there, should last the season hopefully after all this
  25. colineunson
    colineunson
    from Victoria
    D1EAF507-E5F4-46A5-9B9A-4813B4E0E72E.jpeg Also winter rad flush (indoors as its freezing outside) for good measure, the inside of rad and block was caked in crud, including the block drain being plugged solid.
  26. Desmodromic
    Desmodromic
    Off Topic. - what does that expression "may 86" mean? I have a Toyota with the model name "86"; should I be concerned?
  27. Desmodromic
    Desmodromic
    I think you're trying to exploit "Internet's" challenged money-conversion capabilities. I think $500Cdn was about $380US. Nice try!
  28. Desmodromic
    Desmodromic
    Car and top are beautiful, but looks to be a factory roadster body. I'd be wary of any dimensions from offered plans, since this car is of entirely closed car derivation. Would be a good starting point however, with the differences accommodated.
  29. Desmodromic
    Desmodromic
    Presumably, you paid enough so builder could recoup some of his labor, say 10 or 20 bucks or so over his $65 investment.
    Really nice car, but I do have a concern that I apologize for mentioning. The rear end is obviously an open (non-torque-tube) type. In the early pictures, I didn't notice anything to prevent the rear end from rotating about its axis, under acceleration or braking, without depending on the lateral (fore and aft) stiffness of the spring. And regardless, such a fore and aft force places a large moment on the shackle support plate to axle housing weld, in the weak direction. This could be alleviated to a degree with some gussets in the fore-and-aft/vertical plane.
