Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. IMG_3303.JPG IMG_3307.JPG IMG_3315.JPG IMG_3316.JPG IMG_3321.JPG IMG_3324.JPG IMG_3323.JPG IMG_3311.JPG IMG_3328.JPG IMG_3329.JPG IMG_3330.JPG IMG_3331.JPG IMG_3297.JPG IMG_3346.JPG IMG_3347.JPG IMG_3348.JPG IMG_3349.JPG IMG_3350.JPG IMG_3351.JPG IMG_3352.JPG IMG_3353.JPG IMG_3358.JPG IMG_3359.JPG IMG_3360.JPG IMG_3361.JPG IMG_3363.JPG Next up - cam timing. Maybe if I put this here it won't take so long to remember how to do it next time.
    Gonna write this down here so next time it won't take a bunch of youtube videos to teach me how to do this again -
    1. Set the wheel to TDC
    2. Pop the cam gear off
    3. Read the cam card and find the intake opening at .050 number
    4. Rotate the cam to the Intake Open Before Top Dead center 2 .050 (use the black numbers for this step)
    5. Rotate the crank to the number - 33
    6. Spin the cam gear until you find a set of holes that line up (Milodon gears have a LOT of adjustability )
    7. Now we can check the Intake Centerline - white numbers
    8. The white numbers are using the nose of the cam. So locate the .050 reading before the cam nose and the .050 after the nose. Write down the two numbers. Add the two numbers together and divide by 2. It should read the Intake Centerline on the cam card (110 degrees)
    9. Loctite all the cam bolts
    Next the rocker stands get fitted with an oil restrictor. The hemi heads don't drain very fast so allowing unlimited oil into the valve covers can do bad things.
    Nick Smithberg sent set screws with an .060 hole. The stands need tapped to fit the restrictor.
    Then on to gasket fitting. The intake valves are way over the factory size so the gaskets need a notch.
    Next is the clay check to see if the valves clear everything. Put WD40 in the head or the clay will get stuck in all the wrong places ……
    Then move on to spraying Hylomar on the copper gaskets.
    Last step torque it all to 110 foot pounds.
    OahuEli, catdad49, racer-x and 6 others like this.
  2. I've been drilling the oil drain hole in the block and in the heads to 3/8"
    IMG_3364.JPG IMG_3366.JPG IMG_3367.JPG IMG_3368.JPG IMG_3369.JPG IMG_3372.JPG IMG_3373.JPG IMG_3374.JPG IMG_3376.JPG IMG_3377.JPG
  3. Brand Apart
    Brand Apart
    from Roswell GA
    April is toooo far off
    chryslerfan55, Dog_Patch and loudbang like this.
  4. savannahDan
    savannahDan
    Not if you're building to be ready for the first race! :eek:
  5. That's the truth - my plan is to still do a 3" axle drop and its mid February already .......
  6. Brand Apart
    Brand Apart
    from Roswell GA
    Yeah I thought of that right after I posted it. Can't wait for it though
  7. After dealing with 3 races with the rev limiter set too low last year and the water getting in the MSD box, decided to get the Vertex mag re-done. After the rebuild and new coil it should be kicking a decent spark.
    Almost time to set the DVR and watch the SEG destroy some stuff !!
    enloe, OahuEli, catdad49 and 3 others like this.
  8. For a vertex mag that a lot of power. I like the tach drive base. Those are hard to find.
    loudbang and Dog_Patch like this.
  9. DDDenny
    FIE, never heard of them Tony, though they are down the Interstate from me a bit.
    I actually was raised in that general area with some relates still down there.
    Dog_Patch likes this.
  10. dirty old man
    dirty old man
    I don't see any specs. for output @ cranking speeds, or for that matter, at wht rpm the figures they have are taken from.
    Maybe you should consider one of those 16V battery setups like the nirous door slammers use, if allowed. Would spin the engine faster.
  11. They have a coil and mag upgrade option and since it was already on the West Coast, why not get the works! The base was actually from a SBC mag and it was moved over to that Hemi base. The bad thing about it is the big hold down clamp won't fit. Last time I ran this, it used one of those big mag ring braces which was tight to the injection. We'll figure something out …..
    It says @2500 RPM up in the yellow box. The slow cranking from a couple years back was fixed with a giant Powermaster starter for mountain motors - forget which one right now - it spun fast all year, but if we start making rounds (one of these years) it would be good to have a 16v. Still thinking on that. Trying to remove the alternator this year. The fan was a 20amp and I found an 8amp. The water pump is about 4amps. Its really the fan that was killing the battery between rounds.
    enloe, catdad49 and loudbang like this.
  12. DDDenny
    Speaking of the West Coast.......hint, hint:D
    Would sure like to see some of you guys come out here!
  13. Tried to get this link to post like a YouTube video - this should still work ….
    Full Throttle Throwdown - Moonshiners - https://www.discovery.com/tv-shows/...xqoQ2LIizfL_RsPe2A6fBDsyToeJBydwBVpACRB6uQjaU
    Man I would love to come out to Bakersfield with a bunch of cars. The gas money to get there and back would be crazy.
  14. 1D72BB55-8D6E-48F7-86E2-EF4A24DE5F3A.jpeg 0D117653-AA5B-4C4B-AD77-1B0D15C796E4.jpeg 850F121A-B7DE-4A12-A189-3E5A412A0179.jpeg 72F5653B-5267-41EC-A91D-B63D8ED9BA00.jpeg 4B4BA059-0E34-4DA7-9480-BBF54F429064.jpeg AA967D4E-074A-4AF4-A25C-44913226B327.jpeg Here’s some funny back stories. Discovery channel asked us to come back to the track to re-shoot some pick up scenes - something they use to tie the scenes together after the rough draft- so I’m told. This was January and I didn’t have cast on my foot anymore. They asked can you get recasted? Well it just so happens that my orthopedic guy is a racecar nut. So Ronnie came over and made a new cast.
    jakespeed63, enloe, delray57 and 6 others like this.
  15. catdad49
    catdad49
    I see that your guard dog checked his work!
  16. @dirty old man called and gave me shit for not posting my axle swap pictures so here’s the new 3” drop WACC axle
    And a trip to Columbia SC to see Clutch!
    A9935EB3-1FAC-40E1-938C-092FE45C56BD.jpeg 0F2725BB-70EF-427A-B824-C2792425AF77.jpeg B90A14CC-1C52-4CA1-8C94-23383D4F65D1.jpeg C6B44CA9-974B-4738-A4B8-A36432485705.jpeg 7C506DB0-5EED-4A4D-BA3B-0042C0A2C912.jpeg D684C38E-01A9-4AD0-B352-8D76B46C5B3D.jpeg 2A65C947-CA22-4007-BF94-CCE36E2E4E45.jpeg F19511DB-2FF4-418C-9A63-1225DC2B5095.jpeg 430C12EC-A111-4925-9B23-36C069F523CC.jpeg C2180415-6309-4899-B5B0-6505522C3C53.jpeg 185F3533-689D-4120-8AC1-668DE61DB4F8.jpeg
    Tooth, enloe, Higgy's Henry and 8 others like this.
  17. Hope this sets up the way for some cool new toys …….
    HOT NEWS FROM HOT WHEELS!!!
    Just a few short months ago Mattel, Inc. contacted us to join in the efforts of their Hot Wheels DragStrip Demon series. The list of future possibilities are endless, but it begins with the SEGA logo on select Hot Wheels and packaging. Like any major project, it takes a lot of patience and time, but the contract is signed and we’re excited to see some finished products. It’s just another opportunity for many of us to rekindle those great childhood memories, as that iconic flamed logo begins to appear during the 2019 SEGA Season. #southeastgassers #hotwheels
    http://competitionplus.com/drag-rac...k9mDHZY_CIrKv2mtdSkWV6CJjXb3YtgLdqxpO3i7Dq6MI
    BigO, Chucky, jakespeed63 and 14 others like this.
  18. That is little kid dreams right there, great news indeed!
    Dog_Patch, OahuEli and loudbang like this.
  19. jim snow
    jim snow
    Gotta get me a Quick and Dirty hot wheels.
    PBRmeASAP, Dog_Patch and loudbang like this.
  20. woodhawg
    woodhawg
    1. S.F.C.C.
    Wow that could be a big deal!
    dirty old man, Dog_Patch and loudbang like this.
  21. Hang'emHigh
    Hang'emHigh
    I can already see the faces of SEGA on cereal boxes. :D
    Dog_Patch, dirty old man and loudbang like this.
  22. OahuEli
    OahuEli
    from Hawaii
    Wow, thats cool! Are the cars going to look like current SEGA cars or jut fit the time frame? Haven't bought Hot Wheels in decades but it looks like I might be adding to my dusty old collection.:D
  23. Brand Apart
    Brand Apart
    from Roswell GA
    Every kid's fantasy. So happy for you Quain & rest of the SEG.
    dirty old man, loudbang and Dog_Patch like this.
  24. Not sure where this will go yet. It would be cool to make a whole set of SEG cars but they didn't say they are going to do that yet - they licensed the logo. Hope they build a complete set - only about 100 cars to collect if that's the case.
    saltflats, catdad49 and loudbang like this.
  25. Hemi Joel
    Hemi Joel
    from Minnesota
    Tony, you don't need to do all that work on the head gasket. My motor's the same as yours, it has Nicks hot heads and needs the boar to be notched. I brought a gasket into Clark and he made a pattern that has the valve notch and eliminates all the holes that are not needed with the hotheads. Next time ask him about it. Good luck this year in your racing!
    Dog_Patch, loudbang and dirty old man like this.
  26. Interesting. I've ordered a bunch of gaskets from them but we never got into the details of the heads. @402BOSSMAN is working with SCE to get notched gaskets designed now.
    enloe and loudbang like this.
  27. dirty old man
    dirty old man
    How did the trial runs @ Paradise go?
  28. 7FD73DA3-7E7E-451C-872B-100CBEE2B156.jpeg D4353F53-5606-48C3-84DF-A48D55FE6655.jpeg 4E20A9D1-E3E1-45D9-892A-2145926CC9DD.jpeg
    Well they call it testing for a reason right?
  29. Just got off the phone with Johnny and the crank polished up fine. He’s fitting bearings this time just in case. We had over 100 psi of oil pressure last year and I changed the bypass spring to drop it to 80. Going back to 100psi and it should be back in the car this weekend.
    If you saw the discovery channel show, I cut the foot hook off on the gas pedal so my cast on my broken foot would fit. Well the throttle stuck open and I used the hand control to shut it off. Probably was a little too slow on the shutoff. New pedal is getting installed. And a rev limiter.
  30. dirty old man
    dirty old man
