I have a 8" Ford rear end that I rebuilt 20 years ago. Axle bearings, seals, all new brakes, wheel cylinders, etc. It's been in dry storage in my (So Cal) garage. I'm planning to add fluids and run it but wondering if the wheel cylinder seals, etc. will still be good? Run them or as cheap as they are, install new ones?
I would at least take them apart and plan on installing a new rubber kit in them. Old rubber tends to stick to metal if its stored dry very long. You may take them apart and find out they are fine, but I would at least have to look. Gene
run it. its probably real rubber instead of the crap they sell us now. ever heard of new wheel clys leaking?
I'd pop 'em open and look. I wouldn't worry about the rubber, but surface rust is a possibility. Be easy to clean out now, before it embeds in the rubber.
New wheel cylinders are less than 10 bucks apiece. To each his own, but if it were mine I'd change them now rather than take the chance of having to change the cylinders and the shoes, and clean up the mess, after the axle is under the car.
I would put kits in them they are so cheap. Recently did the same with another project that, like yours, I did the brakes on then never finished. It had been sitting 10 or 15 years so I replaced all rubber parts in the brake system including flex hoses and replaced the brake shoes for good measure. While I was at it I put on a double master cylinder to replace the single it came with. 1966 Dodge Coronet. Don't take chances on your brakes.
I like to fill NOS wheel cylinders with brake fluid and let 'em soak overnight before install, Bleeding and putting them through the paces. Don't know if it does any good but it won't hurt anything.
Not sure this should be a question. Just because there in your shop doesn't mean moisture could not still creep in and started to rust. I would replace them with new. Peace of mind cost the price of two wheel cylinders .
I'll open them up and see how they look, though you guys are right in that they're cheap. Rock Auto has AC Delco Pro, Raybestos, and Wagner new cylinders for about $6. Prefer domestic. Anyone know off hand if these brands are still USA made? I'd rather run the 20 year old Wagner's than new China brake components.
With RockAuto they give you what they have on hand, from dealer closeouts or whatever. I bought 4 and they were from 3 different countries.
