Hot Rods Let's talk Cadillac 331's, 365 and 390's
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 7, 2016.
  1. Roothawg
    Roothawg
    Let us know what you find out.
    ls1yj, loudbang and Moriarity like this.
  2. Torkwrench
    Torkwrench
    Thanks for the info. I'll definitely be checking this out.
    ls1yj and loudbang like this.
  3. Roothawg
    Roothawg
  4. Roothawg
    Roothawg
  5. falconsprint63
    falconsprint63
    from Mayberry
    Wow this is only the second alluminum 4bbl intake I've seen. And the last one was a boat intake. I"d have been all over it for $255 and I don't have a cad motor at the moment!
    Sent from my SM-G950U using The H.A.M.B. mobile app
  6. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    does anyone know if the balancer on a 56 365 will work on a 54 331? 49-62 the same?
  7. c322348
    c322348
    49-56 is 363-1726
    57 is 363-1727
    58-62 is 363-1728 without A/C and 363-1729 with A/C
    All part numbers are without the pulley.
    winduptoy, loudbang, Tuck and 2 others like this.
  8. Roothawg
    Roothawg
    I didn't really want a conversation piece. I wouldn't have used it on anything, so I moved on.
    loudbang and ls1yj like this.
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Thank you!!
  10. falconsprint63
    falconsprint63
    from Mayberry
    I looked for years for an aluminum 4bbl. I'm not really in the market for conversation pieces either, but i'd totally have set that back for a future build. I know I'll have another cad eventually
    winduptoy likes this.
  11. Roothawg
    Roothawg
    E75C5185-190B-4E5E-B16A-5153CB53771D.jpeg Got some good news tonight from Offy.
  12. MOTOV8N
    MOTOV8N
    from Manitoba
    winduptoy and loudbang like this.
  13. Pete
    Pete
    I saw that,,,,so stoked!
    winduptoy, loudbang and Roothawg like this.
  14. Roothawg
    Roothawg
    That’s gonna kill the holy grail collectors and eBay profiteers.
    I’ve been holding off taking the 390 to the machine shop, because I thought they would never actually finish. I bet they are glad to go to production, just so I will shut up.
    rust, loudbang, razoo lew and 3 others like this.
  15. ls1yj
    ls1yj
    from Kentucky
  16. Roothawg
    Roothawg
    I doubt it. I think the Offy is the best looking 3x2 ever made for any engine.
    winduptoy, Tuck, rust and 2 others like this.
  17. Roothawg
    Roothawg
  18. 42merc
    42merc
    The 390 Cad in my '40 contains an "Isky 270".
    Other than a 650 Holley & an aluminum wheel it's a stock build.
    Stock with the cam & 10:1 plus compression makes it a nice torque motor, great mid range, like the ad says.
    With that said after reading your posts, this isn't the cam for you, not enough noise at the tailpipe.
    Dangerousdan, WTF really and Roothawg like this.
  19. Roothawg
    Roothawg
    I don’t know if it will handle too much more with the limitations on the valve springs. Maybe a beehive spring would help?
    Post up a video of the exhaust notes!
  20. What valve springs and retainers are you using with the Isky 270?
  21. 42merc
    42merc
    With the Isky 270, I used new stock springs with a .060 shim.
    Retainers are stock with the umbrellas cut off.
    Guides are cut to use good seals plus gain clearance for the retainer at full lift.
    Works for me.
  22. Thanks! I have Isky springs for mine, but haven't gotten around to dealing with the retainers yet...
  23. Roothawg
    Roothawg
  24. Roothawg
    Roothawg
  25. Roothawg
    Roothawg
  26. Roothawg
    Roothawg
  27. RAT "T"
    RAT "T"
    HELLO,
    I'M LOOKING FOR SOME BLOCK DIMENSIONS TO BUILD A SCALE REPLICA OF AN EARLY CADILLAC ENGINE 49-62, WOULD ANYONE KNOW THE LENGTH & WIDTH OF THE OIL PAN SURFACE, VALLEY PAN SURFACE & THE HEIGHT OF THE BLOCK FROM THOSE TWO SURFACES?
    ANY INFO WOULD BE GREATLY APPRECIATED
    THANK YOU
  28. Oil pan surface is 22” x 11-1/8”
    Valley cover surface is 18 -1/2” x 6-1/4”
    Height between the two is 8-3/4”
    Let me know if you need any more dimensions.
    winduptoy, loudbang and kadillackid like this.
  29. RAT "T"
    RAT "T"
    THANK YOU, SENT YOU A PM
  30. boo
    boo
    from stuart,fl.
    maby i missed the post but..i have a stock 1955 331 cad eng that i am putting in my 34 rdst w/edelbrok 3x2, its bored for 3 ford carbs, i have 3 97 carbs when running w/progressive link, with just the center carb be enough or will it run lean??? manifold has a large enough carb base area that i could drill for rochesters if need be. running a 1960's ford hd b/w overdrive and 4.11 rear . ?????
