Technical ***January 2019 Banger Meet - New Banger Dreams***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jan 1, 2019.
  1. drtrcrV-8
    drtrcrV-8
    Go to your local welding supply : Their version of a "Dye Check Kit" will be one hell of a lot cheaper, &, once you learn how to use it properly, will be just as effective for most tests, with the advantage of not being limited to ferrous metals, unlike Magnaflux, which is.
  2. 5280A2
    5280A2
    Just finished reading about the "Heap" in the latest issue of Hot Rod Deluxe. Didn't know you had changed your name from Nelson to Wilson! Tell Brian B. to go-go-go.
  3. Jiminy
    Jiminy
  4. railcarmover
    railcarmover
    Been using dye-pen for years..handy cause its portable..magnaflux way more accurate.either way its nothing but a heartbreaker..
    Jet96, Old Dawg and BeaverMatt like this.
  5. s.e.charles
    s.e.charles
    hope this is the correct thread: I am interested in any modifications required to adapt a 4 banger to marine application. help appreciated.
  6. denis4x4
    denis4x4
    from Colorado
    There's a thread over at the Fordbarn right now on this subject
    s.e.charles likes this.
  7. IMG_1592.JPG Well got my B cover all painted up! Time to install it
  8. brjnelson
    brjnelson
    Hey Miles, wasint Brian Wilson in the beachboys??
    I did not know HRDeluxe needed filler to waste up print space about me and some car that is not a roadster or coupe ;)
    I will get a copy and look, Thanks
  9. 5280A2
    5280A2
    For what it's worth they spoke highly of Mr. Wilson and the Heap; had some pictures too!
  10. V4F
    V4F
    from middle ca.
    pulled my head for preventive maintaince , forgot how much you have to disconnect to do that . lots of time …. steve
  11. chambies
    chambies
    from ca
    Quick question regarding the single lock adjustable tappets... does any modifications need to be done to the block? Specifically, does the tappet guide need to be shortened in order to make room to put tools on the adjustable tappet?
    Thanks in advance!
  12. Should not need any mods.
  13. V4F
    V4F
    from middle ca.
    if you want to be able to adjust them without the rolling motor back & forth , yes cut the lifter blocks so lifters have clearance to adjust . much better than rolling motor back & forth to adjust .
  14. chambies
    chambies
    from ca
    Excellent. Thanks!
