Projects ‘31 av8 coupe build
Discussion in 'Traditional Hot Rods' started by kustomitch, Nov 17, 2018.
  1. kustomitch
    kustomitch
    from Monson MA
    Started working on the k member tonight. First picture is how I got it. Got the legs off and the center welded back together. Then I started cutting it to fit the frame. Ran out of welding gas so I’ll have to get back to it tomorrow.
    Stogy and brEad like this.
  2. Boulderdash
    Boulderdash
    Following this avidly, loving the look and style your going for.
    Question: did you weld the roof chop from the inside or outside?
  3. sloppy jalopies
    sloppy jalopies
    I have an inner trunk lid panel if you are looking to reskin one... it is used... DSCN2941.JPG DSCN2940.JPG
    brEad and Stogy like this.
  4. Beautiful Iron
    Beautiful Iron
    from Upstate NY
  5. kustomitch
    kustomitch
    from Monson MA
    Thank you. The chop is welded from the outside.
    Stogy likes this.
  6. chiro
    chiro
    You might want to try this guy for your spring in the rear. I used him a number of years ago for my reversed eye rear main leaf. Very nice guy and seriously knowledgeable. Plus, he's close to you (relatively). I drove up from Long Island to pick mine up at his facility.
    Andy
    https://www.jalopyjournal.com/forum...lowering-spring-bolt-in-american-made.961937/
    Stogy and 100% Matt like this.
  7. kustomitch
    kustomitch
    from Monson MA
    My lid isn’t to terrible. Inside is in better shape than the outside. I think I’m going to just patch it. I appreciate it though.
    Stogy likes this.
  8. kustomitch
    kustomitch
    from Monson MA
    Thanks dude
  9. kustomitch
    kustomitch
    from Monson MA
    Yes I know Matt. Good guy. I’ll be heading to pick up my spring this weekend I believe. Using his spring perches too.
  10. cederholm
    cederholm
    Awesome build! Gonna keep an eye on this!.
    My grandfather has a machine shop in Holyoke Mass back in the 30's. My understanding is that he converted an old water-wheel powered wood working shop into a diesel powered machine shop that still utilized the overhead pulley system. Of course that was long ago - I think the old shop is now a restaurant.
    ~ Carl
    Stogy likes this.
  11. kustomitch
    kustomitch
    from Monson MA
    Thanks!
    Love hearing about stuff like that. Lots of cool old buildings in Holyoke that are now getting repurposed. We rent part of an old warehouse shop there for skateboarding.
    cederholm and Stogy like this.
  12. kustomitch
    kustomitch
    from Monson MA
    So I got the k member cut up, tacked together, and fitted in the frame. Also started making motor mounts. They are not quite finished yet but I wanted to make them look like something that could be factory. More on those tomorrow. The new radiator also came in. Need to figure mounts for it.
    Stogy, brEad and greaser like this.
  13. kustomitch
    kustomitch
    from Monson MA
    Got the motor mounts finished up for the most part. There will be a spacer on top of the plate to get the motor where it needs to be. Just waiting on the wheels and tires to figure that out. I’m a little out of practice on my welding but it’s starting to come back.
    48fordnut and brEad like this.
  14. kustomitch
    kustomitch
    from Monson MA
    I got the k legs carved out tonight. Going to head to my buddy’s shop tomorrow to make a pattern off the ends of his k legs as mine were gone.
    Stogy, kadillackid and brEad like this.
  15. Looking good - I like the motor mounts!
    Stogy likes this.
  16. nunattax
    nunattax
    from IRELAND
  17. kustomitch
    kustomitch
    from Monson MA
    Thanks!
  18. kustomitch
    kustomitch
    from Monson MA
    Thank you!
  19. kustomitch
    kustomitch
    from Monson MA
    So today I got got the car all put back together. Motor and trans all mounted up and I like the the stance with the oldyankeespeedco spring. Threw the hood on to see what it looked like. I think it’ll stay.
    FlatJan, wheeldog57, m.ralph and 14 others like this.
  20. Vic Walter
    Vic Walter
    ya, with hood !!
    kustomitch and nunattax like this.
  21. kustomitch
    kustomitch
    from Monson MA
    Back to doing more work on the body now. I got the original rumble lid fitted back on so I can patch it and working on the wheel wells. My headlight repair kit came in as well so I was able to get the 32 lights together. Shifter top also came in.
    Stogy, Shadow Creek, brEad and 3 others like this.
  22. kustomitch
    kustomitch
    from Monson MA
    Got both headlights mocked up. Still need some tweaking on the stands. Also started working on the wheel wells finally since I’ve decided I won’t be stepping the frame up. Drivers side needs quite a bit of work still especially with the way that terrible corner patch panel lined up with the bead.
    Rathbone, Stogy, brEad and 2 others like this.
  23. Really love the look of your A! Makes me reconsider my plans for my future model A project. I’ve been planning it low, no hood, unchannelled, unchopped but yours at a less altered height, chopped, with the hood - killer!
  24. Beautiful Iron
    Beautiful Iron
    from Upstate NY
    Coming along awesome mitch, good work
  25. kustomitch
    kustomitch
    from Monson MA
    Thanks! There’s so many ways to build them
  26. kustomitch
    kustomitch
    from Monson MA
    Thanks man!
  27. Here's my 30 with a full hood and duce grill. 4" chop. Seems to work. Good luck with yours. 20180211_134202.jpeg
    Sent from my SM-J727V using The H.A.M.B. mobile app
    Rathbone, Stogy, akoutlaw and 4 others like this.
  28. kustomitch
    kustomitch
    from Monson MA
    Looks awesome! Very similar to what I’m doing here. Thanks
  29. akoutlaw
    akoutlaw
    Exactly what I am doing. Looks perfect!
    kustomitch and Lilred36 like this.
  30. kustomitch
    kustomitch
    from Monson MA
    I’ve been busy with customer cars but I’m back on it. The warm weather is giving me some motivation. I got the inner door welded in and then finished up the lower skin I was making.
