Motion Pictures Small block engines, Picture thread
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Dec 18, 2018.
  1. loner2, enloe, 31hotrodguy and 2 others like this.
  2. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    327 in a 34 ford, Larry
    loner2, loner1, cruiserjohn76 and 4 others like this.
  3. loudbang
  4. loudbang
  5. Cool to see some SB Chev script covers that don't say Corvette! :cool::rolleyes: JW
  6. DDDenny
    Like this.
  7. sdluck
    sdluck
  8. edcodesign
    edcodesign
  9. No, the cast alloy ones, I run the original 283 type on my 301. JW
    31hotrodguy and loudbang like this.
  10. loudbang
  11. I'm trying to make mine look old school and "neglected" even though it almost all new inside...
  12. heres probably the cleanest one I have put together- for a 1981 cutlass I had. It was an L82 vette 350, summit 1102 cam and lifter set, edelbrock performer intake, street demon 625 carb, 305 heads that I ported and polished and gasket matched, and a retro tri- air cleaner with finned valve covers. cutty motor.jpg
    loner2, Stebo27, loner1 and 5 others like this.
  13. loudbang
  14. loudbang and Deuces like this.
  15. Some of the various small blocks my grandfather CJ and I have built over the years for our various cars.
    11807738_708355709293848_908801816563569475_o.jpg 44445879_2649462485067489_372218208221921280_o.jpg
    The current one in the works:
    loner2, vetteguy402, Stebo27 and 12 others like this.
  16. Baron
    Baron
    The 1962 327 going in my Deuce Rdstr. 44122134_543489956076242_5777002102865788928_o.jpg
    loner2, Stebo27, enloe and 12 others like this.
  17. roadster1923
    roadster1923
    from Girard PA
  18. roadster1923
    roadster1923
    from Girard PA
  19. had a tri power 350 100_6182.jpg in my 32 with geardrive lakes headers, dart heads, crane cam, pentronics distributor
    loner2, Stebo27, loner1 and 8 others like this.
  20. catdad49
    catdad49
    loner2, Stebo27, loner1 and 7 others like this.
  21. loudbang
    1955 265 Corvette. they not the green color like a regular 265?
    1957 283 270 HP
    loner2, Stebo27, enloe and 8 others like this.
  22. Shadow Creek
    Shadow Creek
    @roadster1923 - is this one of your projects? Looks to be a well grafted subframe on a Chevy tophat frame if I’m not mistaken, but I’m mainly curious which headers those are and how they fit. Think they would have enough clearance if it was still the original frame? I’ve got a 39 Chevy and am looking for ideas for headers. Thanks.
  23. roadster1923
    roadster1923
    from Girard PA
    Yes, that is my 37 Chevy coupe project and it is a 1969 Nova sub-frame graft to the original frame. I reinforced the sheetmetal bottom cover with 1/8th inch plate steel. The headers are Patriot Clipster headers and they seem to have plenty of clearance. If you need close-up pictures or measurements send me a P/M. Thanks for the kind remarks!
    Steve
    Shadow Creek and loudbang like this.
  24. loudbang
    Engine in the Garlits museum
    loner2, Stebo27, enloe and 9 others like this.
  25. loudbang
  26. Jalopy Joker
    Jalopy Joker
  27. MotorBike Mike
    MotorBike Mike
    My built little small block in my '55 Stepside
    [​IMG] [​IMG]
  28. Dooley
    Dooley
    from Buffalo NY
  29. loudbang
  30. loudbang
    Alan Smith slide injection
    loner2, mad mechanic, Stebo27 and 9 others like this.
