Projects 54 Ford Customline daily driver
Discussion in 'Traditional Customs' started by Shane Spencer, Jul 24, 2016.
  1. Shane Spencer
    Shane Spencer
    I still have the receipt in my emails. Im thinking its not the headlight switch though, why would the head and tail terminal be dead on both ? Makes no sense to me
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Bowtie Coupe likes this.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Autozone part# 1firewall.JPG Dorman 85801 $2.99 each
  4. Shane Spencer
    Shane Spencer
    When i take my tail light wire that goes to the switch, and run 12v to it all my tail lights work. Same with the dimmer power wire, when i run 12v to that my headlights are working fine now. Ive tested the headlights and taillights using the wires at the switch and everything works perfect, but the headlight and tail light terminal on the switch are dead. All the grounds and pigtails are working fine
  5. AldeanFan
    AldeanFan
    Silly question,
    Is there power to the switch?
    The first car i wired, I reversed the power and dash lights wires and blew the fuse, no power to the switch.
  6. Shane Spencer
    Shane Spencer
    Yea, i have the power at the switch, the brake terminal, park light terminal and dash lights/rheostat all work perfect. To test the headlights and tail lights, ive been putting there wires to the terminals that i know are working (brake, park light, and dash light) and all my tail lights, and headlights work fine. But the designated headlight and tail light terminals on the switch dont give me anything. The new switch i just got did the same exact thing which makes me think maybe theres something im missing. Whats the chances two switches have the same two dead terminals? And the first switch that was originally in the car used to work fine. I must be missing something
  7. AldeanFan
    AldeanFan
    Is the headlight switch a switched ground for headlights?
    Strange that two switches do the same thing.
  8. Shane Spencer
    Shane Spencer
    Headlights have a ground at the back of the bulb, relay is also grounded. Someone else previously said the switch shouldnt have to be grounded, and my park lights work fine. Not sure
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    1firewall.JPG With the Rebel harness all the wires are marked as to placement,are there any left over ? And just for an experiment try using this diagram since you are running that aftermarket turn signal switch.
  10. mopacltd
    mopacltd
    The first car I owned was a '54, but a mordoor
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    Have you won the wiring challenge yet ?
  12. Shane Spencer
    Shane Spencer
    Ive been working 12’s all week. Really only have the weekends to work on it. Should be back at it tomorrow
    brEad and JeffB2 like this.
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    Updates on the switch wiring ? Hoping you solved the mystery ;)
  14. Shane Spencer
    Shane Spencer
    I havent had time to get to the car yet. Just shipped a model a body to australia this weekend, and working 12’s every weekday. Soon though !
  15. Shane Spencer
    Shane Spencer
    Hey yall, sorry for the lack of updates. Went on a trip out west and been working a lot of overtime
    THE WIRING ISSUE IS SOLVED!
    Talked to a tech at Rebel, and he found a spare diagram that was hand drawn in there files, apparently for our cars. Wired it up and everything works well. Heres how its layed out....
    Left side back to front is - Park, Power, Dimmer
    Right side back to front is - Taillights, Jumper wire from power terminal, Dash lights
    I whipped up a bracket for my brake light switch
    Shot some paint on it
    Also got my turn signal wire cover on. Turned out nice. Gonna swap the hex head screw for a buttonhead and paint it brown
    Got the tie rods and drag links all cotter pinned and greased. I think i forgot to order a bushing for the pitman arm to the drag link, i just have a bent washer thing there. Gotta be missing something...
    The 39 guy, JeffB2 and Bowtie Coupe like this.
  16. Shane Spencer
    Shane Spencer
    Also if anyones interested, i have a newport electric wiper motor for sale for 52-54 fords. Pretty much brand new. Asking $180, they are $219 new
    Firedup likes this.
  17. REBEL43
    REBEL43
    from TENNESSEE
    It's looking good! I talked to you on the wiring tech. Anytime you guys have a question, just give us a call. We have shelves full of diagrams and tech books, not to mention all the stuff rolling around in our heads. That's what we're here for, 423-263-5399 or [email protected]
  18. Shane Spencer
    Shane Spencer
    Thanks again man ! Ill be giving you a call about the signals and brake switch again when i get a chance
    Peanut 1959 likes this.
  19. Shane Spencer
    Shane Spencer
    Finally got my lights working 100%. Brakes and all. Thanks to Rebel Wire for all the tech help
  20. greaser 35
    greaser 35
    from FRANCE
    :cool: KOOL!!!!!!!!
  21. Shane Spencer
    Shane Spencer
    Sorry for the major lack of progress fellas. Lifes been busy as all hell this year.
    I just got around to doing the front seat bottom today. Few wrinkles but turned out decent, still need to paint and pinstripe the side covers for the seat. Does anyone know how to disassemble the split backs for the bench. Im not sure how the new upholstery is supposed to be installed. You can see it just wraps around the bottom of the seat and tucks into a seam. Also, any tips on the stainless strips on the seat backs ?
    40FORDPU, brEad and The 39 guy like this.
  22. Nice work on the wiring, I may have the same terminals jumped on my '59 HL switch. I got a new one when I did my harness a couple of years back.
  23. Shane Spencer
    Shane Spencer
    Figured out the seat backs, wasnt too complicated. The fit on the covers is so so but it turned out fairly decent. Got the drivers side to do and everything will pretty much be ready to go in the interior
  24. Firedup
    Firedup
    from Oregon
    Got any pictures of it. I was looking at those the other day. I may be interested.
  25. Shane Spencer
    Shane Spencer
    I have it posted in the classified section. Check my threads out and youll find it. Theres pictures in the ad
  26. brokedownbiker
    brokedownbiker
    I'm late to the party here but I've got to say- nice work you're doing! I see that you are installing your seat covers, where did you source them? I've got a couple of cars in need of some new covers.
    olscrounger likes this.
  27. belair
    belair
    So much good work and good taste... congrats.
    brEad likes this.
  28. Shane Spencer
    Shane Spencer
    Thanks guys, seat covers came from EZBOY, which is now owned by lebarron bonney i believe. As did all the material for the door panels, kicks etc and then i made my own door cards and covered those. The fitment on theyre seat covers isnt 100 percent perfect but it saves alot of money over taking it to a super legit upholstery shop. They have tons of seat designs and colors available
  29. Shane Spencer
    Shane Spencer
    Busy as hell all weekend but i managed to make some time for the car. Finished the front seat for the most part, heres a shot of the OG ‘54 interior under the crappy tweed covers that were on the seat
    Front seat backs in for good
    Better shot of the under side of the backs
    Stripped the paint on the front seat tins
    Sanded and primed
    Gonna hit a few spots with filler then paint em and lay down some stripes to accent the stamping in the sides of them
  30. brokedownbiker
    brokedownbiker
    Thanks for the upholstery info Shane. The interior on your car looks fantastic, you've done a great job- on the whole car, not just the interior; your car is much more than just a daily driver.
    Bowtie Coupe and Peanut 1959 like this.
