So are we to believe that the block, sump, head, crankshaft, cam, valve cover plus misc. parts are all newly fabricated parts?
To add some the engines I think are mounted nose to nose, cranks joined at the splines that the tower shaft and dist/oil pump drive gears are on, thus the mag drive..Possibly driving both cams with the one tower shaft..The spline areas are not the strong suit to handle power transfer from front crank to rear crank but builder probably beefed the area up..I have read that the tower shaft is pressed into the drive gear only and should be welded to handle increased two-cam loading...What a build; really cool thinking!!!!
I also would love to hear it run! just wonder about rpm, those things scream as a single 4 cyl engine! lots of thinking on that deal! my head hurts!
Awesome. Time to go watch some old video of Fangio at Monte Carlo. That tank is beatiful, I'll be impatiently waiting for updates.
There are craftsmen who can actually weld it all together and machine as needed to make one. Saw an article years ago about a V-12 made from 2 small-block Chevys.
Original displacement for Crosley was 44cu in, but I have no dimensions(bore/stroke) for this engine!
Very talented Individual , bet he doesn't set around in front of a tv much . Thank you for sharing . Looking forward for more information about his building of the car parts . Also your metal work. Herb Ottoway of Wichita Ks took 2 Indian 4 blocks , cut off the front cylinder of one block and the rear cylinder off the other one , welded them together making a 6 cylinder engine . He had a crank made for it . He called his bike the Super Chief.
Crosley @ 44 cu in is 2.5 bore x 2.250 stroke..Some post Crosley [Fageol/Crofton] may have had a 2.750 bore for 53 cu in...Homelite/Bearcat [last generation] @ 59 cu in is bore 2.750 x 2.500 stroke...
Well this one wasn’t built with a VISA card and a Summit catalog. Good on you guys! Greg Sent from my iPhone using H.A.M.B.
Think of a freight train. Or two guys pushing the same car. One big guy and one smaller. Thy both put in what they have. Nobody takes out.
This is poetry, just beautiful. Somebody should make this their signature. ^^^ Took the words right out of my mouth.
Seb Fontana: I know what the production Bore/Stroke numbers were, but was wondering what THIS engine was, that's my question. Until we are able to get more info on this build it's a good question. I really hope some pictures were taken during the engine build!!
Saw it on the Specials thread, Thanks. I'd love to hear the thing, I bet it sings. In 1959 my dad was taking me around the Feather River country where he spent most of the depression after riding a freight train from Texas. He introduced me to an old guy who ran a "shop" His dad started it as a blacksmith shop and foundry back in the gold rush days and it became a machine shop over time. Any way he showed me a V8 that he had made from two Model A engines. It was in some old truck they used to haul ore to a crusher/mill. I took pictures with my Brownie but have no idea where they are. So glad things like this get built and documented.
So how are the engines mated- I can see that the oilpan looks like one cast piece, but are the two cranks sleeved together, new crank, etc? This is a fantastic build, and has my mind spinning/buzzing with all kids of horrible ideas Just for fun, here's another one of my favorite Crosley modified engines;
I still haven’t gotten a chance to talk to Bob to see how they’re exactly connected together. I did snap a few more pictures of the bottom of the engine. Also one of where the mag enters the block. I think someone had asked about it earlier in the thread. Instagram: @39_deluxe
Chris, Thanks for the extra pics- looking forward to hearing what he did to mate the two cranks!... and the off-white paint, casting numbers, etc scream of Homlite blocks, so he's up to a whopping 118ci of high-revving fun
Holy hand job Batman!! This thing is like a Swiss watch, absolutely outstanding. Can't wait to see what you come up with for the body.
At the risk of high jacking this thread. I have a friend trying to find rod bearings for a Crosley two cylinder engine. Anyone have or know where to get them? Thanks, Gene.
