Projects Dads 32 tudor build
Discussion in 'Traditional Hot Rods' started by FlyingRN, Nov 29, 2018.
  1. FlyingRN
    FlyingRN
    My last post asked about opinions on how to (re)build my dads 32. Finally got her back down to Florida and am getting to work. Looks like we are going to be removing the mustang II dad installed in the 80's and install the 4" dropped chrome I-beam I picked up this past weekend at the Turkey run in Daytona. Also got a new vega box, and all the various bits to go with the swap. Here's a few pictures of the disassembly. IMG_20181128_090859_654.jpeg IMG_20181128_090859_655.jpeg IMG_20181128_090859_656.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
    Scooterville, brEad, Tim and 3 others like this.
  2. Time to start cutting the ugly out. HRP
    barrnone50 and FlyingRN like this.
  3. 40Standard
    40Standard
    from Indy
    looks like a nice solid project. always wanted a 32 sedan
    FlyingRN likes this.
  4. rusty rocket
    rusty rocket
    What are you going to do with the ribbed top, leave it or put an insert back on?
  5. FlyingRN
    FlyingRN
    For now, it'll stay. Its a suburban roof, fits well but all of the original wood work is still up there.
    brEad likes this.
  6. flatford39
    flatford39
    Good call on the roof. I would leave it as well. I think it looks pretty normal.
  7. FlyingRN
    FlyingRN
    The JW Rod garage frame builders kit showed up this afternoon. Couldn't resist doing a quit mockup. Excited to get started on the new frame! 20181207_190855.jpeg 20181207_190907.jpeg
  8. guy1unico
    guy1unico
    Try your very hardest not to put that Chevy in there.
    WB69, Texas Webb and barrnone50 like this.
  9. Run the Chevy. Neat build you’ve got going there.
    MAD 034, mcsfabrication and FlyingRN like this.
  10. FlyingRN
    FlyingRN
    Why not? Its a brand new motor, its looks great, makes good power, I can fix anything that goes wrong with it at any auto parts store and its already built!
  11. guy1unico
    guy1unico
    Ford in a Ford is a great rule of thumb.
    WB69, BigO and greener200 like this.
  12. Mike Colemire
    Mike Colemire
    Or put a ford in it and spend twice as much.
  13. sloppy jalopies
    sloppy jalopies
    Didn't buy the JW ROD GARAGE kit, but just the rails...
    they look good, 11 Ga. ... spreader bar and body bolt tiedown holes only...
    ford guy, the way God and Henry intended it...
    go fly go !
  14. I think not, I would have to say it's 3:1 Chevy vs Ford in Hot Rods. Just the way it is and not trying to stir anything up.
    da34guy and FlyingRN like this.
  15. Professor Fate.
    Professor Fate.
    Anything wrong with the original frame?
  16. I am interested in the old frame if you are going to part with it. PM me about it and what you would want for it.
    Thanks Dennis
  17. Thought the plan was to trim off the unwanted items on your frame, and traditionalize it. What made you go with the JW parts?
  18. FlyingRN
    FlyingRN
    No, its just not the direction we want to go now.
  19. FlyingRN
    FlyingRN
    I think its easier to start with brand new rails than to cut off everything that was already done. The original frame is complete, partially boxed and would work fine for someone that would like to slap in a sbc, bolt on a body and go cruising.
    392
    Nice score. Should be great thread.
    chryslerfan55 and FlyingRN like this.
  21. scotti32
    scotti32
    Good start
  22. FlyingRN
    FlyingRN
    Dad and I made some progress on the JW frame builders kit today. We had ordered about a hundred dollars worth of 5/16 18 & 1/4 20 weld in cage nuts from McMaster Carr for all of the body mount, fender, running boards and hood hold down bolts that will be inaccessible when the frame is boxed. Spent a full day getting them all in! I wiped everything with laquer thinner and ospho before I painted the inside of the frame rails to help control any rust. Then he helped me line up the boxing plates. All thats left now is to do the perimeter weld for the boxing plates before we jig it up for the cross members. 20190113_125309.jpeg 20190113_153541.jpeg 20190113_182101.jpeg
  23. alchemy
    alchemy
    Hey bud, I'd jig that frame up before welding anything on it. Most repro rails require a bunch of tweaking to be up to Ford specs. I'd hate to see you installing everything and then drop a body on top that won't fit.
    verno30 and Just Gary like this.
  24. FlyingRN
    FlyingRN
    Yeah, that's what I said in my post, I need to jig it to start installing my cross members. All I have is spec sheets, anyone know someone with a 32 frame jig in Florida? I called Clark Hot Rods in Daytona, but the only phone number I could find listed went to a real estate company and they didn't return my call.
  25. alchemy
    alchemy
    You should jig it before you weld in the boxing plates too.
  26. I assume the new frame doesn't have a number. Work that problem with your local DMV before you do anything else.
    Charlie Stephens
    gimpyshotrods and chryslerfan55 like this.
  27. FlyingRN
    FlyingRN
    Dad's owned this car since 1974, he's had the car titled in his name since then.
  28. RoddyB34
    RoddyB34
    Keep the Chevy and the Muncie,,,,
  29. 343w
    343w
    I'm following your build along, mine has been on hold for a couple of years while collecting parts and health reasons. Looks like you've got a good start for a slick tudor.
  30. alchemy
    alchemy
    He may have the title, but the new frame won't have the number on it. Many (most) states want to see a number stamped by Henry Ford on either the frame rail or the transmission to verify it's the correct car to match the paper. Dad may never sell the car and need it inspected, but if the car is in an accident the insurance company won't pay if the correct number can't be verified.
    gimpyshotrods likes this.
