Technical ***December 2018 Banger Meet - What Will Santa Bring***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 30, 2018.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    December 25th, Santa
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $31.00 for color, $24.00 for B/W (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. denis4x4
    denis4x4
    from Colorado
    Started this thread off last month talking about tube shocks on my CCPU. Had to rework the front lower mounts to get enough travel. Finished up last week and well worth the effort when it comes to ride and handling.
  3. Checked in for last time this year.
    J
  4. Crazydaddyo
    Crazydaddyo
    Just getting one word answers to my question. Is it done? No.
    Old Dawg likes this.
  5. noboD
    noboD
  6. V4F
    V4F
    from middle ca.
    damn , another year gone
  7. Shutter Speed
    Shutter Speed
    Can't tell you how many (mostly stock) Bangers I cross paths with up here are shockless.
    The times I've inquired about it, I've been asked.."Do you think they'd make a difference?"
    I think we had 1, maybe 2 sunny days this Nov...when it wasn't sunny, it was rainin or snowin...don't think I'll take the BNGR to cut a this year....Have a Bang-Up Christmas!
    Peace on alluya.
  8. Shutter Speed
    Shutter Speed
    (...cut a TREE, of course)
  9. winduptoy
    winduptoy
    I'm shocked....
    Sent from my XT1254 using The H.A.M.B. mobile app
  10. Binger
    Binger
    from wyoming
    Checking in for the month.
  11. Dan,
    asking if it is done is like asking for permission, always easier to ask for forgiveness..............
    Sorry to hear the news, J
    chryslerfan55 and Crazydaddyo like this.
  12. JT1930
    JT1930
    Checking in. 3 months of having the car I’ve done 1200 miles with my heavy foot behind this thing. Pulling the banger soon.
    - Whats the going rate on a banger that has been rebuilt with insert bearings for the mains? Selling radiator to transmission. Thanks.
  13. ROCKER77
    ROCKER77
    $928.64.... respectively
    JT1930 likes this.
  14. lake_harley
    lake_harley
    Well....if $928.64 is the going rate for a used, running, not-ready-to-blow, insert-bearing Model A engine, I'm ready to make a trip to R.I.
    Lynn
  15. JT1930
    JT1930
    Hahahhahah
    ROCKER77 likes this.
  16. lake_harley
    lake_harley
    Bu..bu...but, it's almost Christmas and I've been a good boy! :(
    Lynn
  17. lake_harley
    lake_harley
    Does anyone here run dual updraft Zenith carbs? Will they work with headers, or are the carbs in the way of the downtubes, primarily the center two?
    Lynn
    JT1930 likes this.
  18. JT1930
    JT1930
    0E96F5EC-BC81-409D-81BC-9209632302C6.jpeg I do. You have to run stock manifold. Or make a custom header but it would be pretty tight bends to get the inner cylinders to exhaust. I run tilly X carbs though.
  19. walls
    walls
    I don’t think there’s room.
    Reds makes headers for single down draft, but probably won’t work for duals.
    Otherwise, I’d guess you could split stock headers.
    I can’t remember where I got this pic, but it was probably from the hamb.
  20. Shutter Speed
    Shutter Speed
    I'll double that...and I'm close by.
    chryslerfan55 and JT1930 like this.
  21. lake_harley
    lake_harley
    Thanks for the photo JT1930. I figured the center two cylinder header tubes would have to be really tight, probably so tight it would have quite a negative effect, being more visual than beneficial. Two updrafts is a good look for sure...and I think Jim Brierely spoke well of that setup in his book. I'm unfamiliar with "tilly X" carbs....I'm curious what are they off of and/or what the throttle plate diameter is compared to a stock A Zenith? Looks like the carb throat of the rear carb is really close to the exhaust. Air cleaners or maybe just some screens?
    That's a pretty simple intake you posted, walls. I think I could knock one of those out in a couple hours.
    Thanks
    Lynn
  22. JT1930
    JT1930
    I have screens on my carbs. Either tillotson carbs or zeniths it will be close. Unless you find a Trojan intake I saw for sale a little while ago with two zeniths on it. I believe that updraft intake is a little further out from the motor.
  23. JT1930
    JT1930
  24. V4F
    V4F
    from middle ca.
    there is a guy on here (cant remember) that builds really nice intake & exhaust systems (custom) ……….
  25. lake_harley
    lake_harley
    That does look like it has a lot more room for header tubes, but it's a bit on the "steak" side of my self-imposed "hamburger" budget. If I'd decide I really want dual updrafts, more than likely I'll fab an intake and header. It can be tedious and time consuming, but it would also be rewarding to build.
    Lynn
  26. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Well, I know I could sure use a new exhaust, and hopefully get these damn E brake issues sorted, thinking i have a warped or bent backing plate for one of them, put the shoes on, had to clearance the hell out of the shoes, then try to tighten the drum and locked, back the nut off and turns again. So that's on my agenda hopefully this month. Then moving to steering ball replacements hopefully in January.
  27. MJW
    MJW
    from NJ
    1. PA. NJ. local HAMBERS group
    Do you mean BCCHOP here on the HAMB. He does custom headers and intakes and Gasser axles in Torrington CT.
    http://waccustoms.com
    chryslerfan55 and jerseyboy like this.
  28. burl
    burl
    from Minnesota
    Checking in. Really need to focus on this this winter and get it running and driving. contemplating a different cam after pulling the engine to clean up and seal with new gaskets. 28.jpg
    Jet96, chryslerfan55, flyin-t and 9 others like this.
  29. utahdodge
    utahdodge
    Hi guys, can a newbie horn in and ask a couple of quick questions? I picked up this ‘30 (I believe) five window coupe in a local auction a couple of weeks ago.
    . [​IMG]
    I am now collecting parts and am out of my knowledge “comfort zone”.
    An ad for a “model b Ford” out of an “old model a hot rod” showed up this week;
    I am super cheap, is $1200 a decent price? Can you tell if this is a “b”? Any help/advice is appreciated.
  30. studebakerjoe
    studebakerjoe
    Yes its a b. If you look closely you can see they have a plate bolted on where the fuel pump would go and the valve cover is taller.
