Projects Dagel's 29 Model A SDN from junk and castoffs
Discussion in 'Traditional Hot Rods' started by Gasser1, Mar 20, 2018.
  1. Working on the rear kick up on the frame.
    Normal the top is parall to the frame.
    This would mean the rear seat would need to be raised at the frount to make it comfortably(flat seat is not).
    I may run the top of the kick up down 2" at the rear.
    This wouldn't also slope the rear seat down at the back 2" giving more head room.
    3"X3/16 band used for trans tunnel sloped on drivers side so I have a little more room for the gas pedal.
    brEad likes this.
  2. Let the fun start
    Welded the body mounts to the frame and pulled the body.
    Got the frame level again
    Installed the kick up got them squared up and level
    Now need to weld them.the top of the kick up runs down hill 2"for them seat bottem
  3. I seam to go thru a lot of 1/4"plate.
    Air bag mounts are nothing fancy just simple pc cut from 1/4"steel
    Lower mounts installed
    Bags set on
    Upper mount again real simple they will tie in to trailer hitch
    brEad likes this.
  4. I know not very traditional but I want it low and our roads suck
    Bags on
    About 7" of travel that should save the belley pan from fretting beat up on the street
  5. I have been slacking off 3 week vacation now time to get back to the MODEL A.
    So far Everthing but 1/2" of the master clyinder bracket is above the frame.
    Rear kick ups are in and body back on frame so I can do the subframe under the seat.
    Also go the u support for the rear axle to trave in installed.
    Better shot of the u there 2"x1/4".
    20181019_125836_Film3.jpg Need floor under seat yet. Lots of wielding and trimming to do once Everthing is fit.then blow it apart clean up the brackets.finish the welds.bead blast and paint.
    Another shot of the u
    And this is at ride height.
    brEad likes this.
  6. More of that cut-fit-welding going on.
    Using 11ga sheet metal to fill floor. Resesing it 1/4" for the sound dreading and Dynamate.
    brEad likes this.
  7. As I said in the beginning I would work on it about 2 hr a day 14 hr each week to see just how long it takes to build.I have had a vacation and spent 20 days in mn with family problem. Just like everyone runs in to.
    Now I'm back and working the floors.
    I'm cutting 12ga inserts to fit in side the 1x2 tubing . way heavier then it needs to be but I know it will last 100years and if I get in an accident it's that much safer.
    There getting welded in solid from the top only.
    Just as you get going we all seam to run out of parts. I ran out of 12ga so on to the tunnel it is 14ga which is the heaviest I can do with my brake.
    I will mark the loops and drill holes to spot weld the tunnel to the loops.
    I will also weld the bottem of the tunnel solid to the 1x3 tubing
  8. Building the floor under the rear seat.
    Lots of boaring work.
    There will be 2 body mounts at the rear
    Sides will get welded to the tubs
    And braces will go down to the u the axle rider in in the tubs
    Hopfule I can pack a battery, air tank,sway bar,shocked,and panhard rod under the rear seat it will be tight.
    brEad likes this.
  9. I am so bored with this stuff.why does it seam to take forever to do the floor.
    More pc filled in
    brEad likes this.
  10. Nailhead A-V8
    Nailhead A-V8
    Hmm if the roads suck and you're worried about flexing/cracking...right now it appears as if the entire rear clip is held on by just the wall thickness of your tubing??... I'm sure you're just at the mock up stage and intend to properly cut 45's, fully butt weld, and diamond plate over the rear kickup joints ...
  11. Kikups are at 30deg they are just tacked they will get fishplated when I weld the chassis up.
    I was worried abouts around clearance we have 4" ballad (nobs/lane dividers)plus speed bumps 3" tall and 24 " wide the with of the street. So ground clearance is a problem around here that's the reason for the bags. There should be no flex or twist when done. Main rails are 2x4x1/4"
  12. Getting closer need rear kick up and fire wall yet then I can move on.
    brEad likes this.
  13. Mike Colemire
    Mike Colemire
    Really nice fab work. Looking better all the time.
  14. 6sally6
    6sally6
    I can almost smell the welding smoke!!:rolleyes:
    Keep at it.......GOOD work.
    6sally6
  15. Time for the fire wall
    20181121_130836_Film3.jpg unbolt the top cut the sides levin 3/8" to weld to
    Throw it on the floor and cuse it for cutting you
    Start trimming the edges
    Cut up some cardboard for a pattern
    Make sure it can be put in
    Tape The pattern to make it stiff an make sure it will go in in one pc
    Now it's time for the hard part
    Turning thus pc of 16 ga in to the cardboard templet.
  16. Mike Colemire
    Mike Colemire
    I screwed up, I haven't took mine out yet and I done cussed it several times. Doing a great job.
  17. You can't cuss them till you get them out it just makes them fight harder.lol
    brEad likes this.
  18. Mike Colemire
    Mike Colemire
    The guy that worked on mine only had 1 tool, a hatchet, I think it was dull at that.
  19. Konan1184
    Konan1184
  20. Konan1184
    Konan1184
  21. Its bent and put the engineering back in looks like it's right So out with the engine again and finle trimming band welding
    brEad likes this.
  22. Same old story cut weld grind.
    I will us the stock fuel tank I am going to move the sediment/fuel filter to the drivers side since the fuel pump on the yblock is on the drivers side.
    Bolted in the top like ford did it. I left 1/4" of the stock fire wall on the car and welded the new fire wall to it.
    That way it can come out in the future if needed.
    Adding some bracing for strength.
    The comers will be rebuilt with 1x2 tubing.
  23. Structer back in on driver side
    Structure made out of 1x2 tubing
    Same thing on passanger side some 1x2 x14gtubing.
    Plate over it with 11g
    A little grinding and the front Conner are done. Now to the flaired/curved trans tunnel
  25. Well the fire wall has been a pain but its done now and then engine is back in.
    Nailhead A-V8 and brEad like this.
  26. sloppy jalopies
    sloppy jalopies
    These model A body to bumper brace brackets are easy to find, drill out the rivet and one bracket does both cowl sides...
  27. You fight with stuff and think you have it all figured out.
    Wrong
    Got to put the brake pedal, clutch pedal and trans fork in place to work out the z-bar .just not enough room. The brake arm hits the clutch fork.
    So how do you fix it?.
    Me I went with a duel master clyinder set up like we use on stock cars with a balance rod. 1" bore for frount brakes 7/8" for the rear.
    The balance rod allowes you to adjust the system like a adjustable properation valve.
    Clutch is 7/8" master clyinder and 7/8" push slave clyinder with 1.4 " travel.
    They will be floor mount pedals with master clyinder out side.
    Good thing is more room to run the exhaust.
    The bad I have to modify the new fire wall
    I'M BLEEDING MONEY NOW!
    I did not have any thing like this laying around but nothing $400 dollar won't fix good thing it's christmass
  28. So I get cash for Christmas and decided to spend it on a 32 grill and shell$200 for China grill will work for me.
    It fit the radiator I bought last year.
    Other then shipping damage looks good.
    Now it has to go back and Hopfull FedEx won't let the rain dear play on the next one
  29. Some people have requested more Piture here they are 20181219_081918_Film3.jpg 20181219_081807_Film3.jpg 20181219_081953_Film3.jpg 20181219_081941_Film3.jpg 20181219_081918_Film3.jpg 20181219_081859_Film3.jpg 20181219_081923_Film3.jpg 20181219_081946_Film3.jpg 20181219_081758_Film3.jpg 20181219_081910_Film3.jpg
