Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. farmer12
    farmer12
    Alternator bracket is painted and installed for the very last time.
    Dog_Patch, Plung, Hogman and 13 others like this.
  2. farmer12
    farmer12
    Meanwhile at the paint shop.....the dashboard is nearly ready to receive some colour.
    Dog_Patch, Plung, Hogman and 6 others like this.
  3. Great pic from the front. Looks real tough. Those guys at the RDW ( testing station ) will shit themselves :oops:.
    31chevymike and loudbang like this.
  4. farmer12
    farmer12
    Dashboard has been painted, came out looking great. While my painter is busy painting, I'm getting ready to install the Airride compressor/components.
    Dog_Patch, Plung, Hogman and 8 others like this.
  5. speed v8
    speed v8
    It's great to see you're making some good progress Eric.
    Car, loudbang and farmer12 like this.
  6. farmer12
    farmer12
    Thank you speed v8. I hope to make even some more progress this week!
    Car, loudbang and 31chevymike like this.
  7. farmer12
    farmer12
    After quite some work, the air suspension works! The bags are getting stretched for the first time, hence the squeaking noise I presume. After a few more tests, we found out that the whole system was maintaining pressure. No leaks!
    Dog_Patch, Plung, Hogman and 10 others like this.
  8. exterminator
    exterminator
    Your car is so sweet - you should nickname it candy!
  9. hemi v8
    hemi v8
    Great vid! Best custom I've seen in a long time
  10. farmer12
    farmer12
    Thanks!
    Or candy apple black? ;)
    Thank you sir, it's appreciated!
  11. BuiltFerComfort
    BuiltFerComfort
    I think I’m the first one to subscribe to your YouTube channel. Hoping for more...
    Car, farmer12, loudbang and 1 other person like this.
  12. That black still looks wet and deep, like it has 6 coats of clear on it. But I believe you mentioned
    it's Single stage?
    Car, 31chevymike and loudbang like this.
  13. RodStRace
    RodStRace
    He did Base Coat Clear Coat (BC/CC), not single stage. Go back 4 pages and the base looked great too before sanding.
    Dog_Patch, Plung, Hogman and 7 others like this.
  14. Fabber McGee
    Fabber McGee
    Skilled body men, they sure got it straight.
  15. dutchrod
    dutchrod
  16. RodStRace
    RodStRace
    That picture I reposted shows 1. the roof section that is joined and leaded (at the factory) to 2. the quarter, that 3. has the body line and trim holes along that 'E' part of the light reflection, which they then welded 4. the rear fender to and filled the seam. Look at that reflection and realize every part is a compound curve made of 70+ year old sheetmetal in 3 different stampings. Oh, and it was chopped too!
    He bought it chopped, but had to fix it. Here's a pic from page 6, I think, when it was first stripped. Now look at that reflection![​IMG]
  17. farmer12
    farmer12
    The above picture is indeed how I discovered it. (underneath the bondo). The picture below shows how it turned out after replacing all the (spliced) metal and using lead for the final stage in order to get the lines perfect. Quite a change.....
    Dog_Patch, Plung, Hogman and 11 others like this.
  18. farmer12
    farmer12
    More shall be added mr number 1 subscriber!
    It indeed has come out perfect. And like RodStRace said, it a BC/CC step. Two coats of black and two coats of clear.(and a lot of sanding in between!)
  19. farmer12
    farmer12
    They sure did! Just got a picture from one of the (Portugees) guys doing his magic on the doors and deck lid. This will all be painted this week.
  20. farmer12
    farmer12
    Thank you dutchrod!
  21. RodStRace
    RodStRace
    farmer12, I didn't want anyone to think that the roof I reposted was UNDER that gorgeous finish, just how much work was put in!
    Your picture shows the work much better! I should have searched more to find that one.
    Of course, anyone that has gone through this thread knows that no shortcuts were taken and it's all top notch work throughout!
    I'm so glad you have returned to finish this amazing car and story.
    31chevymike, Car, j hansen and 2 others like this.
  22. farmer12
    farmer12
    I know what you meant! No problems. Just wanted to make sure that the rest of the world wouldn't get confused.;)
    Thank you for the positive comments, it is always appreciated.
  23. farmer12
    farmer12
    I'm probably the only guy that will spend nearly two hours fitting two taillights on a car....continuously mounting/dismounting, adjusting etc until perfect. But hey, it's done.
    Plung, Hogman, mgtstumpy and 7 others like this.
  24. farmer12
    farmer12
  25. Car
    Car
    from the desert
    "Perfection" should be your middle name!;) Great work as usual.
  26. damn fine work, Eric! :)
  27. Peanut 1959
    Peanut 1959
    I love the "gravity defeat" option. I didn't think that was available until the '42 model year...
  28. farmer12
    farmer12
    Thank you Car
    Thanks Carsten! Things are definitely on a roll again. I'm spending a fair amount of time on the Plymouth at the moment, loving it. And the missus doesn't even mind....
    You are correct. But as luck would have it, this happened to be one of the test cars.;););)
  29. farmer12
    farmer12
    Caught in the act.(installing taillights). One of the shop owners was on a short vacation to the south of France and was checking out his security system, probably making sure everyone was working.;) Something about big brother... LMAO. (All guys here at he shop are awesome btw!)
    Plung, Hogman, mgtstumpy and 6 others like this.
  30. farmer12
    farmer12
    Work is progressing great on the electrical system, just a few things to do. Nearly ready for the dashboard!
