Why another project.. ? Just Happened to find an Engine..! "You know I got these 47 brakes lying around for a while" ..let's do it. (rear brake lines in) You're Correct - The Rears are up side down!...clears the spring. The Fronts are tilted back about 30° ish.... AND we're going 12V --- using an Austin positive gnd. Generator...(looks cool) Original starter should be OK w. 12V...? Sent from my SM-G930T using The H.A.M.B. mobile app
Thanks Man.. That's what i figured...lotso steel lower current....better start? Ahoogas speed up a bunch!
Just found out that I have: 1939 - 1942 backing plates in the rear. 1946 - 1948 backing plates in the front. Wheel Cylinders, Springs, Drums = the same. Shoes & Hardware = Different. Learn something new every day!
Tried to order Drums for the rear.... No one have 'em! ......Mac's "Maybe February". Luckily i found some on the rock... Front Setup - have to replace hubs... Thanks Lloyd!!..saved my okole Man! ...His cool rides. Sent from my SM-G930V using The H.A.M.B. mobile app
My 30 Roadster on an Austin chassis No worries... it's just storage. Sent from my SM-G930T using The H.A.M.B. mobile app
What some people will do to their poor cars.... Luckily it was on the back side! Sent from my SM-G930T using The H.A.M.B. mobile app
12V + ground Austin Generator w. LUCAS bakelite voltage regulator. Sent from my SM-G930V using The H.A.M.B. mobile app
Oh...and a Magneti Marelli Coil for good meassure... Sent from my SM-G930V using The H.A.M.B. mobile app
Aloha Mario! I'm over in Cali, but will be in Hawaii in May! I'll be bringing my camera gear as I'm shooting a wedding. Let's meetup and do a photoshoot!
Hi Dude Tommy here... That sounds like a possibility...(it's hard for me to plan next week but) Are you shooting for somebody/thing or yourself? Any Hot Rod shoots B 4? I should have my 2 Jalopy's running by then...Or I'm a complete dud! Talk to You Later! Tommy
Drums and backing plates cut by my buddy "Bondo" Well done sir! Sent from my SM-G930T using The H.A.M.B. mobile app
first drive in a while... "New" Engine runs Great! Generator + LUCAS regulator 12.5 V... right on! New brakes stops on a dime! & mycket POS Dodge Magum started today.... Life's GOOD! Sent from my SM-G930T using The H.A.M.B. mobile app
Home Again... Fun Drive! Runs good .. little smoky from the crank case pipe...freshly honed... Sent from my SM-G930T using The H.A.M.B. mobile app
Smoke fix...I'm thinking of installing a PCV valve using the windshield wiper port on the intake - with a bleed valve on the opposite side of the block so it doesn't suck the end seals dry...just gets the smoke out... if that project doesn't work i might have to work on the Rings..? Sent from my SM-G930T using The H.A.M.B. mobile app
had a tired 302, blew by... replaced the pcv valve and ran the other oil filler cap with a hose port and then ran it into the base of the air cleaner... never saw any more blow by... not a model a but you might find a way to make it work on your banger... ….. $0.02
Till now I've always done mostly 99.9% of all work myself at my garage. (Not forgetting my buddies that helped tow cars, lift out / in engines etc.!!!) Since I got a 7-4 to go to everyday . And other things to do it's hard the get $#!+ done sometimes Bondo helped me out a bunch with the sedan!.. Would have taken a lot longer on my own. & It was fun to have someone that knows what Hellsinki they're doing to but head and work with. Thanks Buddy! Sent from my SM-G930T using The H.A.M.B. mobile app
Together: It fulfills two different styles, w. the same main idea..."Try No Buy Stuff - Use Old Stuff! Mo Bettah!" + One's a lot easier / faster to build!!! Different Fun! Sent from my SM-G930T using The H.A.M.B. mobile app
BLOW BY...BUY BUY? Brass Can from Svedala... But! It won't work without a PCV valve! Shhhhhhh! Sent from my SM-G930T using The H.A.M.B. mobile app
Drilled, Rolled Copper Shet metal., Soldered really nice! Sent from my SM-G930T using The H.A.M.B. mobile app
Couldn't find a Halogen kit for 32 Essex terraplane. Cut original lenses out and flanges on new lenses... Sent from my SM-G930T using The H.A.M.B. mobile app
