Technical Pin hole in oil pan....
Discussion in 'The Hokey Ass Message Board' started by banditomerc, Nov 24, 2018.
  1. banditomerc
    banditomerc
    The oil pan finally developed a pinhole leaking oil I have to find replacement what's a good remedy to fill the hole I was thinking maybe J-B Weld or two-part epoxy what you guys think
    VANDENPLAS likes this.
  2. squirrel
    that would work, if you can get it clean. And stick some metal over the repair, too. A dime works well. :)
    jimmy bruns, rjones35, belair and 2 others like this.
  3. banditomerc
    banditomerc
    Thanks girl you're always a wealth of knowledge
  4. banditomerc
    banditomerc
    I meant squirrel LOL
    loudbang, Bandit Billy and squirrel like this.
  5. A penny would be cheaper and will fix a bigger hole. ;)
  6. DDDenny
    My first deep pan was a stocker with a sheetmetal band welded in (stick welded by friend).
    Could never get it to stop leaking around the weld, finally cleaned it real good and put a skim coat of Bondo on it, seemed to "fix" it.
  7. paul philliup
    paul philliup
    from ohio
    When I was working at a Chrysler dealer parts in 2007 we had a sintheic resident silicone. I have used this to stop leaks on race cars and after 13 years is still not leaking.
  8. A blind pop rivet. When we used to drill holes in torque converters and put them in the flush machine (back in the old days). When we were done we would use a blind pop rivet. Seals them up real nice. The first image below is a blind rivet, second image is a regular rivet.
  9. toxic waste
    toxic waste
    from Iowa
    How about low temp soft solder and map gas torch .
  10. harpo1313
    harpo1313
    from wareham,ma
    Marine tex works well also, two part, oil and gas resistant.
    loudbang, brigrat and ClarkH like this.
  11. i have sealed pin holes with just a short screw. the "peanut" screws, used for steel stud framing, work well.
  12. '51 Norm
    '51 Norm
    from colorado
    I have done this and it works. My oil pan had ben sitting on the ground and developed a bunch of pinholes. Since I didn't have the time or a place to work (we were in the middle of moving cross country) I used plumbers solder and a propane torch.
    Make sure to drain and clean the pan, but you knew that.
  13. foolthrottle
    foolthrottle
    I repaired a 331 hemi oil pan with JB weld after it "sprouted one" threw a rod, worked great.
  14. s55mercury66
    s55mercury66
    from SW Wyoming
    Guys, is it a good idea to put a torch to an oil pan that is still on the engine?
  15. toxic waste
    toxic waste
    from Iowa
    You must not know how to solder and how low the temp is.
  16. squirrel
    no, it's not a good idea....
    Rich S. and 3340 like this.
  17. Bugguts
    Bugguts
    I repaired the pan on my truck by brazing it. I drained oil and let it drip for a couple of days and then did my best to clean it further by spraying brake clean into the drain hole in the area of the leak.
    I did read on here somewhere to remove the valve cover breathers, so I did that too.
    After getting a decent amount of brazing rod melted on hole, I decided to add “ just a bit more”. All of a sudden,....BOOM! Smoke blew from the open drain hole and valve cover breather holes as well as the tail pipes. Thought someone fired a shotgun under the truck! I rolled out from under the truck with all my limbs and my hearing did eventually return. Next time, I think I will try something different, or at least use my air hose to slowly blow some air into engine while brazing to help remove explosive fumes. Just throwing this out as a warning.
    The brazing did stop the leak though.
    Rich S., loudbang, belair and 3 others like this.
  18. DDDenny
    See post #16.
    Rich S. likes this.
  19. Elcohaulic
    Elcohaulic
    I used a small screw temporarily for 10 years once..
  20. squirrel
    once I used the screw trick to get a (back of the block) freeze plug to stop leaking...in between time runs, and eliminations, at the drag strip. Pull the trans back just far enough to get it in, threw it back together, and made it to the first round in time.
    then a few weeks later, I fixed it properly.
    But JB weld lasts a long time, on repairs like this.
  21. Chances are a pan full of oil will probably be less dangerous than an empty one full of fumes. Oil pans can sometimes be a pain to remove. I'd try epoxy before brazing one.
    clem likes this.
  22. robracer1
    robracer1
    If it's a pin hole leak just clean with brake cleaner and use JB weld and be done with it, it's quick and simple.
    3340 and loudbang like this.
  23. rwrj
    rwrj
    from SW Ga
    I have used JB weld with a little piece of fiberglass cloth before. Drained the oil, let it drip for a day or so, cleaned with acetone and hand sanded with some 60 grit to give the JB some grip, squeegeed it into the cloth and onto the pan, then stuck it on there. Works fine so far, and kind of hard to see, unless you know what you're looking for.
  24. dan31
    dan31
    On an ot 7.3 ford I used Jb weld and a quarter . Didn't mind throwing all the extra money around ,nothings too good for my fleet.
    loudbang, anothercarguy and squirrel like this.
  25. lippy
    lippy
    from Ks
    Flex-seal? ;)
    belair likes this.
  26. seb fontana
    seb fontana
    from ct
    Por15 and some fiberglass cloth..13 yrs and leak has not returned..
    loudbang and belair like this.
  27. PoTaToTrUcK
    PoTaToTrUcK
    Had a buddy put a rock into through his oil pan while he was off roading, took a hockey puck and a Bic lighter and welded it up. Canadian Patent Pending.
  28. Look for a home heating oil tank sealer, looks like a big crayon and it works.
  29. Kerrynzl
    Kerrynzl
    That would've been entertaining for your neighbours.:D
    Use Argon/Co2 gas from a MIG welder to fill the crankcase while brazing.
    It is an inert gas and won't combust.
    I've done this to braze Oil Temp Sender bungs to an oil pan [you don't need to wait a couple of days]
    we did jack the car on an angle so any residue oil flowed away from where we were welding.
    '51 Norm and Bugguts like this.
  30. fortynut
    fortynut
    Something of mine gets a hole in the pan, my way of fixing the hole is to drain the oil, clean the gasket material off the block and put a replacement back on. Engine work and cranks, rods, cam, rockers and lifters are more expensive. Anything less is a crap shoot. Maybe that's not the answer to stopping the leak but, if you stop the problem for good, it's worth the time down to get it right and be done with it.
    Just Gary and clem like this.
