Let's see some sheet metal shaping
Discussion in 'The Hokey Ass Message Board' started by jhnarial, Sep 16, 2008.
  1. cornfieldcustoms
    cornfieldcustoms
    been working on some air plane parts the past couple days. i am teaching a class for a couple guys from the US air force museum Wright Patterson restoration department so i wanted to get familiar with some air craft stuff
    going to make some pieces for a B-17 bomber engine cowl
    making the paper patter
    after some shrinking and stretching
    after some blending and and forming
    shining up nice while working on planishing the panel out
    working on a little reverse curve section of a wing fairing
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  3. car doctor
    car doctor
    14894509641931588976588.jpg IMG_20180610_131105.jpg IMG_20180610_125659.jpg IMG_20180610_125508.jpg IMG_20180610_125643.jpg IMG_20180610_131521.jpg Rear corner fill in piece for my 32 hi-boy and floor, running boards and rear roll pan for my Willy's pick-up. Also rear window garnish moulding for the willys
    MP&C, toreadorxlt, Happydaze and 10 others like this.
  4. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    Nice work on that floor.
    loudbang and car doctor like this.
  5. loudbang and car doctor like this.
  6. Marty Strode
    Marty Strode
    Air intake scoop for Bonneville Lakester. I will posts pics when I get it mounted. IMG_1771.JPG IMG_1772.JPG IMG_1780.JPG IMG_1783.JPG IMG_1808.JPG IMG_1809.JPG IMG_1810.JPG IMG_1811.JPG IMG_1812.JPG
  7. Joe McGlynn
    Joe McGlynn
    Very Nice! What was your process? Looks like a lancaster-style shrinker along the edges that get welded and wheeling to raise the sides?
    The round stock at the front gives it a really nicely finished edge.
  8. That looks really nice great work Marty thank you for sharing how you made it. Hobo Jim
  9. Marty Strode
    Marty Strode
    I started tuck shrinking and getting the general shape on the stump, with my modified softball bat, followed by using a slapper on a dome. Then came the wheeling to finalize the shape and roll out the lumps. IMG_1360.JPG
    MP&C, brEad, HiSpoke and 1 other person like this.
  10. alwaysamopar
    alwaysamopar
    So much talent here. Thanks for posting processes and pics.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  11. Fabber McGee
    Fabber McGee
    Wow, I thought that scoop was a lot bigger than it is until I noticed the spring clamp. Must only be 6 or 7 inches tall, huh?
  12. Marty Strode
    Marty Strode
    Good guess, it's 7" tall and 11" long. I am working on the base right now, pics to come.
    JOYFLEA and loudbang like this.
  13. oj
    oj
    Sometimes things fall into place and I thought I'd take a pic. 010.JPG 002 (4).JPG
    bct, fauj, 36 ROKIT and 10 others like this.
  14. Dino 64
    Dino 64
    from Virginia
    Lookin good OJ
    loudbang and oj like this.
  15. CoolHand
    CoolHand
    Alliance Vendor
    Damned fine result, sir.
    loudbang and Dino 64 like this.
  16. oj
    oj
    Thanks, I'm welding it in right now and developing the piece that goes to the front. But I really was astonished when I set that big panel in there and just those two little clamps held it pefect, I thought 'goddamn' and took the pic.
  17. CoolHand
    CoolHand
    Alliance Vendor
    If at first you do succeed, try to hide your astonishment. ;)
  18. toreadorxlt
    toreadorxlt
    from Nashua, NH
    Built me a power hammer and heres the first panel off of it. Still so much to learn, looking forward to it. 2.jpg 1a.jpg skin.jpg
  19. Nice work Steve! You should turn out some nice panels with that!
    loudbang and toreadorxlt like this.
  20. CoolHand
    CoolHand
    Alliance Vendor
    VERY nicely done, sir.
    You've definitely got some hours in fabricating that beast.
    Excellent result.
  21. mgermca
    mgermca
    Steve Shepard you do cool shit. ;)
  22. Never2low
    Never2low
    Sweet Jebus!:eek:
  23. loudbang and Dino 64 like this.
  24. patsurf
    patsurf
  25. toreadorxlt
    toreadorxlt
    from Nashua, NH
    Thank you for the nice words everybody.
    Here’s a very quick video of it running.
  26. loudbang, toreadorxlt and biggeorge like this.
  27. bundoc bob
    bundoc bob
    This is surely the place where artisans hang out. So much skill and
    pushing of the envelope. The mention of B-17s earlier jogged my memory
    of an old, WW2 era aircraft fuselage building book [sadly lost forever now] that had quite a bit about rubber block die forming, where a wooden pattern was covered by a suitable size/gauge of aluminum sheet in a press and a thick block of fairly hard rubber was lowered over it and pressure was applied. Anybody ever tried this?
    loudbang and biggeorge like this.
  28. MP&C
    MP&C
    I have a couple radius bends to do in fabricating an AC condenser bracket, so a piece of 1/2" 4130 was added to the Magnetic Brake die.. This will help keep things from moving, and it is welded on what is usually the back side, so no interference otherwise...
    This will be the mounting flange to the radiator..
    1" rod is used to form the radius on the side "covers"
    A test fit before we cut out the gaping hole for air flow....
    The center hole is cut out and a flange tipped for wrapping a 3/16" rod for wire edge. This should add plenty of strength, if the 16 GA wasn't enough..
    Our anvil we made up for stretching the metal in the corners for tipping..
    A "rough" demonstration of how the corners are stretched/tipped for the wired edge. Sorry for the sound issues, the iPhone seems to want to do a noise cancellation throughout filming.... :mad:
    Wire edging complete:
  29. Robert , love that little hammer ! Great work as usual . Blue
    loudbang and MP&C like this.
  30. MP&C
    MP&C
    It does a nice job of stretching areas like that corner. An eBay find, iirc.
